Hugo
Revision as of 13:38, 18 March 2012 by Jsturm (talk | contribs)
Hugo
Release status: experimental
Hugo is a parametric derivate of the Printrbot.
Dual-licensed under Creative Commons Attribution-ShareAlike 3.0 (CC BY-SA) [1] and LGPL v2 or later [2].
This is Hugo. Named after Hugo de Vries who introduced the term "mutation".
The entire design is done in OpenSCAD and all files are hosted on https://github.com/kr2/Hugo.
It is a derivative of the original Printrbot by abdrumm, but all parts are redesigned and improved.
Some Improvements are:
- Nut traps everywhere
- Optional cross braces
- Centered y belt
- Carriage with 3 bearings
- Belt tensioner for x and y Belts
- Additional base in y direction
Instructions
There is a H-Assembly.scad, which is not perfect but shows a complete setup of the printer. To view this H-Assembly.scad I recommend to use the actual developer release of OpenScad e.g. [3] and to set the value for "Turn off render at ... elements" [edit->Preferences] to a higher value (I use 200000).
There are several prebuilt .stl files to discover and to put your own assembly together or you build your own via OpenSCAD.
In general if you print H-Set1.stl and H-Set2.stl you should have all mandatory parts to build the printer. If you also print H-Set3.stl you should be able to setup the entire printer with reinforcements as shown in H-Assembly.scad. The H-Set7_PLA.stl contains all necessary linear bearings plus some extra, in case some come out in bad quality. This bearings should be printed in PLA because it is harder then ABS.
Bill of Materials
Basic Printed Parts
Quantity Picture Description Material DownloadLink
1 H-BaseSet.png Base Set PLA / ABS
0 H-BaseLeft.png Base Left PLA / ABS
0 H-BaseRight.png Base Right PLA / ABS
1 H-Y-BeltDivert.png Y-Belt Divert PLA / ABS
1 BearingGuideSet.png Bearing Guide Set PLA / ABS
0 BearingGuide.png Bearing Guide PLA / ABS
1 50px Y-Belt Clamp Set PLA / ABS
1 H-Y-BeltClamp.png Y-Belt Clamp PLA / ABS
1 50px Y-Bar End PLA / ABS
1 H-X-End.png X-End Set PLA / ABS
0 H-X-EndMotor.png X-End Motor PLA / ABS
0 H-X-EndIdler.png X-End Idler PLA / ABS
0 X-Carriage.png X-Carriage PLA / ABS
0 H-ExtruderMount.png X-Etruder Mount PLA / ABS
1 50px Bar Clamp Set PLA / ABS
0 50px Bar Clamp PLA / ABS
1 50px Y-End Foot Set PLA / ABS
1 50px Z Cupling Set PLA / ABS
0 50px Z Cupplig PLA / ABS
0 H-Set1.png Print Set 1 PLA / ABS
0 H-Set2.png Print Set2 PLA / ABS
Electric and Elektronic
to be done
Nuts and Bolds
to be done
Sources
Bar clamp: Bar clamp by Josef Průša [4]
Bearing Guide: Bearing Guide by GregFrost [5]
Also some modules and metric files from the two above.
Extruder: Greg's Wade reloaded - Guidler, Tilt Screws, Fishbone Gears by jonaskuehling [6]
Printrbot: THE Printrbot by abdrumm [7]
Thanks to all of them.
