HuxleyXAxis
General
This page and its peers should guide you through assembling a RepRap Huxley from the TechZone kit, or from parts you have printed which are the same as the TechZone parts. It is a work in progress, and needs some help, feel free to edit this document to add comments of you your own, or contact us [here] and send us messages asking us for better clarification or details.
I am starting by posting the pictures I have, and over the next few days, I will fill in the instructions and detials (24 Dec 2010)
Thanks,
Lambert (TechZone R&D/Support/Documenter)
You can access this page and it's peers (for the other parts of the Huxley assembly from the Main Huxley page or from the TechZone Huxley Page
Whene assembling the X Axis, assemble the parts just finger tight, and into aproximate areas. When it is all together, we will fix things by measurements, and tighten them up.
X Carriage
On the left is a picture of the parts used to make the top unit:** (1) X Carriage - from the printed parts set ** (1) 180 side of the X Carriage - from the printed parts set ** (1) 360 side of the X Carriage/Bushing Clamp - from the printed parts set ** (1) Graphite filled Bronze bushing ** (6) 3mmX30mm bolts ** (4) 3mmX20mm bolts ** (16) 3mm washers ** (10) 3mm nyloc nuts ** (4) 623zz bearings
Z180 Degree and X Axis Idler
Z360 Degree portion
X Axis Motor Mount
Put them together
