HuxleyXAxis
Revision as of 12:45, 20 February 2011 by AlexRa (talk | contribs) (X Carriage)
Image of a Huxley X Axis, assembled from a TechZoneCommunications Huxley Kit
General
This page and its peers should guide you through assembling a RepRap Huxley from the TechZone kit, or from parts you have printed which are the same as the TechZone parts. It is a work in progress, and needs some help, feel free to edit this document to add comments of you your own, or contact us [here] and send us messages asking us for better clarification or details.
I am starting by posting the pictures I have, and over the next few days, I will fill in the instructions and detials (24 Dec 2010)
Thanks,
Lambert (TechZone R&D/Support/Documenter)
You can access this page and it's peers (for the other parts of the Huxley assembly from the Main Huxley page or from the TechZone Huxley Page
Whene assembling the X Axis, assemble the parts just finger tight, and into aproximate areas. When it is all together, we will fix things by measurements, and tighten them up.
X Carriage
Photo of the parts used in X Carriage
Photo of an assembled X Carriage
On the left is a picture of the parts used to make the X axis carriage (some people call it a shuttle) It is shown assembled on the right:
    • (1) X Carriage - from the printed parts set
    • (1) 180 side of the X Carriage - from the printed parts set
    • (1) 360 side of the X Carriage/Bushing Clamp - from the printed parts set
    • (1) Graphite filled Bronze bushing
    • (6) 3mmX30mm bolts
    • (4) 3mmX20mm bolts
    • (16) 3mm washers
    • (10) 3mm nyloc nuts
    • (4) 623zz bearings
Here is how I stacked the bearings for the 180 degree side of the carriage.
We start this by installing the four bearings that hold the carriage onto the 180 degree restraint bar. The bolts go through the plastic part first (with a washer under the bolt head) then through another washer - or two - followed by a bearing and then the nyloc nut. you don't need another washer between the nut and the bearing. A close-up photo of the bearing stack can be seen on the right.
Photo of the 180 and 360 degree side of the X Carriage
Here you can see the bearings installed on the printed parts, and the bushing sitting in the groove where it will spend the rest of its existence. I simply place the bearing near the center, I don't get out a measuring device and make sure it is exactly in the middle, just eyeball it to close.
--AlexRa: The bronze bushing tends to lock the X axis, resulting in jerky movements and missing steps. I ended up cutting the bushing in two part and put them into the groove as far away from each other as possible, at the edges of the X-carriage. This gave much smoother movements and better yaw-axis stability of the X carriage (sorry, the image is Photoshopped, that was easier than to take apart the real thing (again)): HuxleyXCarriage180n360apart.jpg
Do Not over-tighten the clamp on the busing
With the bushing in place, I fasten the bushing clamp or X Carriage 360 side onto the carriage, I usually put a smooth bar through the bushing before I put ANY torque onto the bolts which hold it together. Be careful to NOT overtighten this, or it will deform the bushing and it will never slide well.
The Image here shows the 180 Degree bearing piece already installed to the Carriage, use (2) 30mm bolts with nuts and washer to do this, the head of the bolt goes to the bottom and the nut goes on top of the carriage (top of the carriage is the smooth side). These two bolts should allow you to adjust the tension with which the bearings ride on the smooth bar, but it is easiest to make this adjustment after the axis is all assembled, so leave them fairly loose for now.
Use a drill to spin the bar in the bushing to seat the bushing and allow it to move freely
While We are here, it is a convenient time to "Seat" the bushing. The bushing provided by TechZone in the kit is a graphite bronze bushing. Due to manufacturing imperfections and variations, you probably need to "Seat" the bushing. I do this by putting the smooth bar into a drill chuck and spinning it while moving the carriage up and down the bar, I do this until the carriage slides easily and freely.
There is an added bennefit of doing this in this way, as the bronze wears slightly, it lays graphite down on the stainless steel rod. You will want to make sure to use the same rod in your final assembly (I usually just set it aside the way it is and don't take the rod out of the bushing again.
I also recommend that you add a drop or two of your favorite machine oil, like sewing machine oil, or bicycle chain oil to the shaft, after you have seated the bushing.
Z180 Degree and X Axis Idler
Photo of the parts used in the Z 180 portion of the X Axis and the X Axis Idler
Photo of an assembled Z 180and X Axis Idler
We use the parts shown on the left to make the assembly shown on the right. The parts are:
    • (2) Z 180 - printed parts
    • (1) X Axis Bar Clamp, Idler end (does not have a recess for bolt head - the motor end has a recess for bolt head)
    • (1) X Axis Idler - Printed Part
    • (3) 3mm X 30mm bolts
    • (6) 3mm X 20mm bolts
    • (4) 3mm fender washers
    • (9) 3mm nyloc nuts
    • (29) 3mm washers (give or take a few)
Photo of the bearing stack for the belt idler bearings
I start by putting the idler bearings onto the printed Idler part, You adjust the width between the fender washers with 3mm washers, you want enough in there so that the belt fits with a small amount of extra room. For my assembly this was 2 washers on one side and 3 washers on the other side.
I then put the bearings onto the Z 180 printed parts, the parts are identical, but not symetrical, this is normal. I have two washers between the printed part and the bearing and no washer between the bearing and the nyloc nut.
To assemble them, place the X Axis smooth bar clamp onto the same side of the Idler as where the belt idler bearings are sitting. This clamp is not symetrical and will fit differently if turned aroud 180 degrees. I cannot tell that it makes any structural difference which way you put it, but in one directions it seems to fit in a more asthetic manner. Then place one of the Z 180 parts on each side and use the three 3mm X 30mm bolts to hold them together. Do not tighten them yet, you will need space to fit the smooth bars under the clamp.
Your assembly should now look like the photo at the top right of this section.
Z Nut Retainers
Z Nut Retainers and bolts
Photo of a prepared Z Nut Retainer
The following parts are used to assemble and prepare the Z Nut Retainers Assembled version is shown on the right.
    • (4) Z Nut Retainers
    • (8) 3mm X 20mm bolts
    • (16) 3mm washers
    • (8) 3mm nyloc nuts
    • (2) 6mm nuts
Heat a 6mm nut with a torch or something
The first thing we need to do is to make sure that the 6mm nut will fit into the space provided for it. It is usually tight and need to be carved out larger, you can do this with a knife, but I have found that it is easier to heat a nut up and then press it into the space as shown on the right. I use a standard plumbing torch to heat the nut on the end of a piece of the threaded Rod. Don't get the nut too hot, it only need to be about 130 degrees celcius to do this well.
You could also use a soldering iron, hot plate, or oven to heat the nut. Or, as stated earlier, you can use a knife to carve the space to fit.
Press the Hot Nut into the space on the Nut Retainer to make a better fit
I press the nut it while it is warm - as shown on the right, once it is in about half way (a little less really) I take it back out and perform the same operation on the other three Printed Nut Retainers.
Once they are all prepared you use the eight 20mm bolts and put two of them together with one of the nuts in between. Don't tighten it down yet, we want to be able to slip the smooth bar into the spaces there, without very much effort.
Note even when these are installed on the smooth bars and tightened down, there should be a small gap between the two halves.
Z360 Degree portion
Photo of the parts used in the Z 360 portion of the X Carriage
Photo of an assembled Z 360
On the left is a photo of the parts used to build the Z 360 portion of the X Carriage, an assembled shot is on the right. The parts used in this are:
    • (2) Z 360 - printed parts
    • (2) Z Nut Retainers - printed parts -Make sure you have prepared them for use with the steps above
    • (6) 623zz ball bearings
    • (8) 3mmX20mm bolts
    • (8) 3mmX30mm bolts
    • (16) 3mm Nyloc nuts
    • (30) 3mm washers
    • (1) 6mm nut
Photo of a Z 360 piece with the center bearing
Start by installing the center bearing. There is only one washer on each side of the bearing. The washers used here are from the smaller washers in your kit (you should have received two sizes of 3mm washers, a large number of normal washers and a smaller number of smaller washers; if you only recieved one size of washer, then they are all the smaller size).
Do this to both of the Z 360 printed parts.
Photo of a Z 360 piece with bearings
Next add the two angled bearings to each of the printed parts. Note how the bolt head is against the bearing and the nut is on the outside of the part, this is important, in order to fit the motor in place later on. There are two washers between the bearings and the plastic. No washers between the nut head and the washer.
Notice that the head of the bolt fits into a small recess when attaching the Z Nut Retainer to the 360 piece
Next, we add the Z Nut retainers to the Z 360 parts, the bolt head is on the Z Nut retainer side, and fits into the small recesses provided for this pupose. Use the 30mm long bolts, There is not much extra bolt here, so I usually forgo the washers on this part. Tighten these two bolts (in two places, making 4 total), since we won't be able to get to the bolt head in a moment.
Finally, bolt the two parts together, using two 30mm bolts, and 4 20mm bolts. The finished product should look like the unit in the photo above right. Don't tighten these bolts yet, we need to slide smooth bar into them in a few minutes. (leave them REALLY loose).
Below are a few extra photos I had, which may help make the assembly more clear - or not...
X Axis Motor Mount
Photo of the parts used for the X Axis Ideler
Photo of an assembled X Axis Motor Mount
The X Axis Motor Mount is assembled as shown on the right, from the parts shown on the left.
Parts used to assemble this are:
    • (1) X Axis Motor Mount - printed parts
    • (1) X Axis Bar Clamp, motor end - printed parts
    • (4) MudGuard/Fender washers
    • (2) 623zz bearings
    • (4) 3mm nyloc nuts
    • (18) 3mm washers
--NOTE-- the bar clamp looks very similar to the idler end bar clamp, but, the motor end has a recess in it for a bolt head, so that the bolt will reach far enough in to connect to the motor when we mount the motor.
Here is how I stacked the bearings and washers
Other than loosely attaching the bar clamp to the Motor Mount (with two of three possible bolts; the third is actually a motor bolt). We need to install the belt idler bearings. The stack is shown very nicely in the photo on the right.
I needed two washers on one side and three washers on the other side of the bearing, in order for the belt to fit correctly. You may need a different number of washers than I needed. The way to test it is to make your stack, and then see how your belt fits. The belt should fit, with just a little extra room.
Put them together
Photo of the parts used finish the Assembly of the X Axis
Photo of an assembled Frame
We use the parts we assembled above (shown on left) to complete the unit as shown on the right.
The list of parts used is:
    • (1) X Axis Motor Mount - assembled above
    • (1) X Axis Z 360 portion - assembled above
    • (1) X Carriage - assembled above
    • (1) Z Nut Retainer set - assembled above
    • (1) X Axis Idler assembly - assembled above
    • (2) X Bar Spacers - printed parts
    • (2) X Axis Belt Clamps - printed parts
    • (4) 3mmX30mm bolts
    • (4) 3mm washers
    • (2) X Axis Smooth bars - these are the longest smooth bars in the set, aprx 295mm (11-5/8") long
Squaring, and truing the size/shape
The squaring and truing of this axis is fairly simple. We want to make sure that the X Carriage 180 side has good contact between the bearings and the smooth bar. We want to make sure that the Z smooth bar will fit and ride in the 360 and the 180 sides without too much tension.
The X Carriage 180 is adjusted by means of the two bolts that hold the bottom bearing portion onto the main carriage. Simply loosen or tighten them as needed. There should be just enough tension for the bearings to make contact with the bar.
The Z 180 side is the easiest of the three, we don't check to make sure there is enough tension at this time, but we want to make sure ther is not TOO MUCH tension. The bar should fit between the bearings on the 180 end and should not rub on the plastic parts when it is "nearly" centered in the bearings.
The Z 360 side is the most temperamental. I often have to trim the shoulder between the straight bearing and the angled bearings. I trim it with a knife. The amount I have had to trim is very small when I have everything else adjusted well. The bar should go down through both sets of bearings and not rub on anything. If it is rubbing, I would first check to see that the parts are all fitting together as they should and the two 360 bearing clamps are parallel to each other. A common mistake here is to have the nut end of the bolts holding the 360 bearing and the Z nut retainer turned towards each other, rather than the heads of the bolts (take a close look at the pictures above, the nuts are on the outsides of the assembly, not the inside).
I have not posted pictures with this explainations, since I am not sure what to take pictures of to better describe the adjustments (other than the pictures in the steps above). If you have some please add them to this gallery... or send them to me and I will add them (see how to contact me above, I will send you my email address).
