I3 Extruder assembly
Revision as of 06:29, 11 August 2015 by Qing (talk | contribs)
Extruder assembly
Need Parts
  • 1. 1×MK8A Parts
  • 2. 1×40*40*11heat sink
  • 3. 1×12V Cooling fan
  • 4. 1×NEMA17 motor
  • 5. 1×Feed filament wheel
  • 6. 1×M6 nut
  • 7. 2×M3*4 screw
  • 8. 1×Bilateral groove bearing
  • 9. 1×M4 gasket
  • 10,11 2×7*10 plastic gasket
  • 12. 1×M4*8 screw
  • 13. 1×M5*8screw
  • 14. 1×M4*18 scew
  • 15. 1×M3*16 screw
  • 16. 1×stainless steel spring
  • 17,18 2×M3*40 scew
  • 19. 1×MK8B parts
  • 20. Nozzle(1 set)
Step 1 You need 1,7,4 accessories, Insert two M3 * 4 nuts in their positions .
M3*4 screw 2pcs,MK8A parts,NEMA17 motor 1pc
Step 2 You need 13, 16 parts, assembled according to pictures.
stainless steel spring 1pc,M5*8screw 1pc
Step 3 You need 14, 15,19 parts, assembled according to pictures.
MK8 parts,M3*16 screw 1pc,M4*18 scew 1pc
Step 4 You need 8, 9,12 parts,put the M4 flat pad placed below the bearing, then tighten M4 screws.
M4*8 screw 1pc,M4 gasket 1pc ,Bilateral groove bearing 1pc
Step 5 Please install both according to the picture.
Step 6 You need the 5 parts,Please install feed filament wheel.
Feed filament wheel 1pc
Step 7 Under pressure with your finger release bearing, insert feeding wheel, adjust the position and releaseyourfinger.
Step 8 Please tighten support screw.
