I3 LCD assembly
Revision as of 05:13, 13 August 2015 by Qing (talk | contribs)
Need parts:
  • 1×LCD
  • 4×M3*25 screw
  • 4×M3 nut
  • 4×M3 lock nut
  • 8×M3 flat gasket
  • 4×plastic gasket
Step 1
M3 * 25 screw and a M3 flat gasket insert acrylic sheet.
Step 2
Plus a flat gasket and use M3 lock nut tightening. then Coupled with a plastic pad.
Step 3
Inserted 4×M3*25 screw into four holes of LCD, and then tighten with M3 nuts.
