ICProgHints
IC-Prog Hints
What is IC-Prog
IC-Prog is a well known no-cost Windows program used to program serial-programmable ICs, including the PIC used in RepRap. See http://www.ic-prog.com
Obtaining IC-Prog
You can download the three necessary files from http://www.ic-prog.com as follows:
- http://www.ic-prog.com/icprog105E.zip (The main IC-Prog program)
- http://www.ic-prog.com/icprog_driver.zip (The driver file for it)
- http://www.ic-prog.com/icproghh_eng.zip (English language help for IC-Prog)
Installing IC-Prog
Unzip all three files in the same directory, such as C:\Program Files\IC-Prog\ .
Configuring IC-Prog for use with a JDM-style PIC Programmer
See http://www.ic-prog.com/jdmset.html for the settings for the JDM. Also (thanks to bartlee45 on the RepRap forums) you need to go to Settings->Options then select Misc tab and check the Checkbox Enable NT/2000/XP Driver . Like this: ---
If you have further information about using IC-Prog, please edit this page and include it! Thanks.
-- Main.JonathanMarsden - 24 May 2007
