ITopie Build Manual
Revision as of 07:38, 20 August 2015 by Skarab (talk | contribs)
iTopie Documentation
Get the sources
The first thing you need is a local copy of the source files (OpenSCAD, DXF, STL, etc...).
The simple way to get it is to download/clone the git repository at https://github.com/lautr3k/RepRap-iTopie.
git clone https://github.com/lautr3k/RepRap-iTopie.git
or
wget https://github.com/lautr3k/RepRap-iTopie/archive/dev.zip
Make the default frame
If you do not want a customized version, you can simply use the generated DXF files in the ./build/output directory for milling/cutting your frame.
CNC milling version
./build/output/iTopie_plates-CNC-16mm_thickness.dxf
Laser cut version (experimental)
./build/output/iTopie_plates-LaserCut-16mm_thickness.dxf
Make an custom frame
If you want a custom frame, you need OpenSCAD to edit and parse/compile the scad source files. Once OpenSCAD is installed, you can open the ./scad/main.scad file for an live preview of all change made in the ./scad/config.scad, (make sure to enable "Design->Automatic Reload and Compile" in OpenSCAD).
Frame assembly
The frame assembly manual is available for download in ODT and PDF format or it can be read online.
Note: This manual is not complete and may change at any time, it's a work in progress... Do not hesitate to propose changes or a more complete version. Thank you.
