Idea lab one
Revision as of 13:14, 18 July 2013 by IdeaLab (talk | contribs) (Created page with 'Idea Lab one is printer that ws developed between July 2012 ap to July 2013. Specifications Working area 200mm x150mm x150mm WDH Print PLA and ABS (1.75mm) Heated table The head…')
Specifications Working area 200mm x150mm x150mm WDH Print PLA and ABS (1.75mm) Heated table The head assembly compatible with jhead Electronics hidden inside the printer. Direct Drive Extruder. External dimensions 410mm x 300m x 356mm
There was couple of prints made already with succes.
The printer was in the assumption that the elements must be able to be printed and the rest of you can get in a small town or on the internet.
Frame Printer is designed with 3mm Dibond material. It can be ordered in most of the companies that make advertising signs.
Printer table moves in the Z axis and is heated
The head is compatible with mounting jhead
Below are the links to the assembly instructions in PDF format, STL and DXF files from the boards to be cut on the CNC milling machine
