J-Head Lite
Revision as of 18:24, 18 December 2013 by Ohioplastics (talk | contribs)
J-Head Lite
Release status: developement
J-Head Lite- A minimalistic spin On the J-Head nozzle
Creative Commons Share Alike
Introduction
No sugar added!
The main difference in this design is the use of off the shelf products and technology to build a more economical hot end. For example, the heat sink is actually just a simple plumbing cap with a hole through it and mounted with a brass nut. The holder uses 1/2" reprocessed PTFE instead of the 5/8" in regular j-heads. The difference in price between 1/2" and 5/8" is substantial.
Please note the .stl file is for reference only. Do not attempt to print your own j-head lite holder.
Made out of: 1/2" reprocessed PTFE (McMaster-Carr # 8803K14) Laser cut oak mounting plate (Lowes 1/4" Oak) M6x1 stainless steal barrel (McMaster-Carr # 90024A461) Aluminum heater block (Clinton Aluminum .3750X.5000 FLT 6061) Vishay 6.8ohm resistor (Digikey # RWMA-6.8CT-ND) Honeywell 100k thermistor (Digikey # 480-3135-ND) Brass nozzle (McMaster-Carr # 8952K33) Ceramic insulation (Mcmaster-Carr # 87575K85) Heat Resistant Wiring (skygeek.com # M22759/16-22-0) Copper Heat Sink (McMaster-Carr # 5520K44)
To ensure that the PTFE is seated properly, it's best to heat up your extruder and then screw on the holder. This will acount for thermal expansion. It's also a good idea to add PTFE tape to the barrel to lock it in place.
An assembly video is in progress. I'll post it up next month, hopefully.
Buy one for $24.99: http://www.ebay.com/itm/J-Head-Lite-V1-0-Reprap-3D-Printer-Extruder-Hot-End-Nozzle-for-1-75mm-Filament-/261355242110?pt=LH_DefaultDomain_0&var=&hash=item3cd9fc827e
