Jason Mendel
Release status: experimental
Description | The Jason Mendel was born out of a need for larger build space and better documentation of the Prusa i3.
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Introduction
The Jason Mendel is a fork of the Prusa i3. Initial variations are an attempt to increase the build area and provide better documentation on the actual build process. It also sets forth a more specific standard then the original i3.
Specifications
' | Mk1 |
Plastic Parts | 34 |
Non Printed Parts approx. | 293 |
Cost | $350-$450 |
Controller Electronics | Ramps v1.4 |
Printing Size | 305 x 305 x 270 |
Motors | 5 x NEMA 17 Stepper |
Extruder | Greg's Hinged Extruder |
Frame Material | 12mm Wood |
Frame Manufacture | Basic Woodwork Tools |
Main Improvements
- Increased Build Area
- Strict Specification
- Better Documentation
- Doesn't Require Expensive Machinery
Electronics
Stepper Motors
The Jason Mendel uses, including the extruder, 5 NEMA17 stepper motors. Two of these motors, the Z axis motors, are connected in series to the same stepper driver of the electronics. The extruder stepper motor needs a minimum holding torque of 40Ncm (0.4Nm). More information can be found on the Stepper Motor page.
Ramps v1.4 is recommended for the Jason Mendel. Required features: 4 stepper drivers, 2 thermistor input and 2 heater output for the extruder. For more information see Ramps
Extruder
The extruder used is a standard Greg's Geared Extruder with an E3D Direct Feed Hotend. The gears for the extruder should be made of nylon.
Heated Bed
The Jason Mendel includes a Heated Bed which allows for the use of materials such as ABS which can experience significant warping if printing on a cold platform.
Materials
The Jason Mendel is capable of printing ABS, PLA and Nylon. It is recommended to apply a layer of Blue M3 tape to the bed prior to printing.
