Jello Solution
Revision as of 22:16, 16 April 2016 by Rtoselli (talk | contribs) (Created page with " == Jello as a bed adherence method == This solution consists of 10 parts water to 1 part unflavored cooking jello. == How to make == * Measure 1 part jello to 10 parts o...")
How to make
  • Measure 1 part jello to 10 parts of cold water ( purified water works best ) Eg: 10gr of jello to 100ml of water.
  • Mix both thoroughly until no floating particles are apparent.
  • You can store the solution on the fridge and use a few drops of propolis to stop growth of bacteria.
How to use it
Swab some of the solution on the heated bed surface and heat it at least until 60C, print the part and let it cool down, the part will pop itself up when the bed cools down.
