Joints for Delta Printer
Revision as of 03:03, 7 May 2014 by JKDesign (talk | contribs) (Created page with "DeltaCategory:Delta = Principle and Requirements = TBD The precision of nozzle positioning depends on rod length and a correct nodal point. = Varia...")
Delta
TBD
Variants
Cardan Joint
TBD
DIY Cardan Joint
TBD
PROs:
  • Very low cost
  • TBD
CONs:
  • Precision depends on manufacturing and assembling. Little manufacturing and assembling error results in a much bigger nozzle positioning error
  • Needs more space in construction
  • TBD
Industrial Cardan Joint
Industrial Cardan
TBD
Main Problem:
PROs:
  • Ready to use
  • M4 or M5 threads
CONs:
  • Cost per joint about 12 Euro
  • Have to be mounted in 45° angle to minimize limits
Rod End Bearing
Rod End Bearing
TBD
Main Problem:
PROs:
  • TBD
CONs:
  • Limited printing area
  • TBD
Magnetic Joint
TBD
PROs:
  • TBD
CONs:
  • TBD
Magnet in Tube Variant
TBD
PROs:
  • Low cost. About 1 Euro per joint
  • TBD
CONs:
  • Precision depends on tube cutting and deflashing
  • TBD
Moving Ring Magnet Variant
TBD
PROs:
  • Easy assembly
CONs:
  • TBD
Fixed Ring Magnet Variant
TBD
PROs:
  • Easy assembly
CONs:
  • TBD
