Joints for Delta Printer
Revision as of 09:39, 7 May 2014 by DavidCary (talk | contribs) (link to article that goes into more detail, etc.)
Delta
Principle and Requirements
TBD
The precision of nozzle positioning depends on rod length and a correct nodal point.
Variants
Cardan Joint
TBD
DIY Cardan Joint
TBD
PROs:
  • Very low cost
  • TBD
CONs:
  • Precision depends on manufacturing and assembling. Little manufacturing and assembling error results in a much bigger nozzle positioning error
  • Needs more space in construction
  • TBD
Industrial Cardan Joint
Industrial Cardan
TBD
Main Problem: In only 4 directions the joint can be tilt up to 90°. In directions between the usable angle is limited to about 30° (depends on design).
PROs:
  • Ready to use
  • M4 or M5 mounting threads
  • Less friction
  • Threaded rods can be used in between
CONs:
  • Cost per joint about 12 Euro
  • Have to be constructed in 45° angle to minimize limits
  • Have to be mounted in optimal working direction
Rod End Bearing
Rod End Bearing
TBD
Main Problem: At rotation axis the joint is designed for endless rotation. But at the tilt axis the joint is limited by construction. As manufacturer documentation tilt is limited to ±30° (Source: igus.de). To use the maximum reaching area as printing area a tilt angle of 35…40° is necessary. In result you can use only a limited printing area.
PROs:
  • Ready to use components
CONs:
  • Limited printing area
  • Conical spacer required
  • TBD
Magnetic Joint
Magnetic Joint Example 1
main article: magnet joint
TBD
Note: V2A balls are not magnetic and can not be used!
PROs:
  • Precision by design
  • No backlash
  • Implicit correct and well known nodal point
  • Low cost. About 1 Euro per joint
  • Simple construction
  • Easy assembly
  • Easy disconnecting for service and transport
CONs:
  • Limited holding force
  • Magnets are sensitive to shock and high temperatures
Magnet in Tube Variant
TBD
PROs (additional):
  • TBD
CONs (additional):
  • Precision depends on tube cutting and deflashing
  • TBD
Moving Ring Magnet Variant
The bearing balls are glued to the lift and carriage. The ring magnets are part of the rods.
TBD
PROs (additional):
  • TBD
CONs (additional):
  • TBD
Fixed Ring Magnet Variant
The ring magnets are pressed in and glued to the lift and carriage. The bearing balls are part of the rods.
TBD
PROs (additional):
  • Depending on design up to (and over) ±90° tilt angle
CONs (additional):
  • TBD
