Kettle Hat Hot End
Revision as of 15:23, 17 December 2011 by Theodleif (talk | contribs)
The kettle hat hot end is a diy hotend intended for those who don't have a lathe.
At first you need a M6 acorn nut made of brass with a 0.5mm hole at the top, a 40 mm long M6 rod with a drilled trough hole of 3,2 mm, a washer with 30 mm diameter, and an M6 nut.
There are 3 types of holes in the washer: 8 mm, 3 mm and 2mm.
Now assemble the parts:
Wind heating wire around the base of the acorn nut and fixate a termistor to the nut. Insulate the wire with silicone tube.
