Knob
Revision as of 18:03, 29 January 2010 by TheOtherRob (talk | contribs)
Knob
Release status: Stable
A knob to make adjusting screws easier.
unknown
This knob, designed by nophead can be adapted for exporting to various sizes of nuts. See nophead's blog post for more information. In an e-mail sharing the aoi file he said the following:
"I assume you have AOI so can make the STL. I have been meaning to put it on the objects wiki but have not got round to it. If published it really needs a table of scaling factors for various nut sizes, or an array of STLs. Also BA nuts are thicker than metric so it may need a bit slicing off the end. You will have to play around with scaling it because it was for 2BA, but was a bit tight as internal holes come out a lot smaller than they should be. This seems to depend on the filament width and the type of plastic. I also think how much you stretch it will have an effect. Adrian published corrections for circles but I get an order of magnitude more error that that formula. It is something on my list of things to research and quantify."
Note: The current STL file (see right sidebar) is only for a 2BA nut. Please export other sizes and post them here if you get around to it.
