KosselHybrid
Revision as of 19:32, 8 February 2015 by Lkcl (talk | contribs) (Links)
KosselHybrid
Release status: experimental
Delta robot 3D printer with extrusion frame.
Introduction
The KosselHybrid is a planned larger GPL-compliant variant of the Kossel that uses parts available for the Rostock MAX, Kossel Pro and other kits to give a much larger print base.
Design Goals
  • Zero backlash.
  • Magnetic connecting rods
  • Triple fans on the print head
  • Type: Delta printer
  • Speed: 320 mm/s in all 3 directions.
  • Resolution: 100 steps/mm in all 3 directions.
  • Repeatability: better than 0.03 mm (30 micron)
  • Build volume: cylindrical, 255mm diameter, 240mm height.
  • Footprint: triangle, 450 mm width (360mm OpenBeam + printed corners).
  • Frame height: 600 mm.
  • Print surface: heated round glass, doesn't move.
  • Mass of end effector with hotend: less than 50 grams.
  • Simplicity: fewer than 200 parts.
  • Hardware cost: less than $700 USD.
  • Fully automatic print surface level calibration (autoleveling).
Bill of Materials
Printed parts
Most parts identical to Kossel
Frame
TBD
Fasteners
TBD
Linear motion
Identical to Kossel
Diagonal push rods
TBD
Bowden
Identical to Kossel
Endstops
Identical to Kossel
Automatic bed leveling probe
Identical to Kossel
Electronics
Identical to Kossel
Tools
This is not a comprehensive list, but should give you an idea of what tools may be required. Review all build manuals/videos to ensure you have all necessary tools.
  • 1x metric caliper
  • 1x M4 Tap Drill bit
  • 1x M5 Tap Drill bit
  • 1x 1.5 mm allen wrench
  • 1x slow-set epoxy
Assembly instructions
TBD
Links
Reearch purposes:
