Lalita
Revision as of 04:36, 11 October 2015 by DiegoLale (talk | contribs)
Lalita
Release status: Working
a foldable RepRap 3D printer.
GPL
This is the first time this design is being published. PLEASE WAIT and give me time to publish all the information, please don't start to buy or build this design. I'm working on this page.
Introduction
Non printed parts
MAKERBEAM :
10mm x 10mm profile Quantity
300mm long 4 pcs
200mm long 6 pcs
150mm long 4 pcs
60mm long 6 pcs
Others from makerbeam Quantity
Square headed bolts 6mm 42 pcs
regular nuts m3 58 pcs
MECHANICS:
Description Quantity
stepper NEMA14 5 pcs
linear bearing lm6uu 10 pcs
bearing 623 4 pcs
Screw M5 x 40mm 4 pcs
Regular nuts M5 6 pcs
This is not a complete list of all the parts and materials yet... i'm sorry, working on it!!
Printed Parts
Piece Quantity Description link
12 pcs print this w/o support material File:Lalita corner.stl
4 pcs File:SoporteBarra.stl
1 pc Don't need support File:MotorY.stl
1 pc File:RodamientoY.stl
1 pcs Y belt holder for gt2 File:Correa.stl
3 pcs File:Linear bearing.stl
1 pcs + 1pcs mirroed Print one normal and one mirroed File:Basegiro.stl
1 pcs + 1pcs mirroed Print one normal and one mirroed File:Giro.stl
1 pcs + 1pcs mirroed Print one normal and one mirroed File:Barra sup.stl
1 pcs + 1pcs mirroed Print one normal and one mirroed File:Z motor.stl
1 pcs Remove the support material after print File:IddlerX motor.stl
1 pcs File:IddlerX i.stl
1 pcs File:CarroX v2.stl
1 pcs File:Alu hot end.stl
6 pcs File:Correa623.stl
2 pcs File:Y lock1.stl
Extruder
This extruder works with a mk8 1.75 drive gear and a 1/8" Male Thread Quick Connect
PRINTED PARTS
1 File:Bisagra.stl
1 File:Soporte.stl
1 You have to end drills with a 3mm drill File:Cuerpo.stl
1 You have to end drills with a 3mm drill File:Palanca.stl
This is not a complete list of all the printed parts... i'm sorry, working on it!!
External links
[1]link to spanish reprap comunity. Topic of lalita.
