LaserCut Mendel Assembly
Revision as of 08:34, 15 June 2010 by GregFrost (talk | contribs)
These assembly instructions are incomplete and have been posted by a customer rather than anyone associated with the sale of LaserCut Mendels. You may also wish to refer to the LaserCut Mendel Assembly Blog which shows some assembly pictures from another customer (in that case, only the laser cut parts are from techzone).
Extruder
X Axis
X Carriage
LaserCutXAxisParts.jpg My supplied X belt was barely long enough. I installed the axis ends so that the smooth rods were almost touching the bearings. I still had to cut the belt and just clamp the ends on the x carriage to make it long enough to go round the x axis assembly. LaserCutXAxisBelt.jpg
Y Axis
Y Idler
Be warned that you probably need an additional washer against each bearing to allow the belt enough space for smooth running between the mudguard washers. LaserCutYIdlerExploded.jpg LaserCutYIdler.jpg
Y Motor
Be warned that you probably need an additional washer against each bearing to allow the belt enough space for smooth running between the mudguard washers. LaserCutYMotorExploded.jpg LaserCutYMotor.jpg
Z Axis
Z Leadscrew Base (one with opto)
You will need 2 of these assemblies, only one of them has the opto mount.
Name Qty /w opto Qty /wo opto Type
Z Leadscrew Base 1 1 Laser Cut Part
Opto Spring 1 0 Laser Cut Part
Opto Holder 1 0 Laser Cut Part
Bearing 2 2 Hardware
M4x40 3 2 Fastener
M4 Washer 9 8 Fastener
M4 Mudguard Washer 4 4 Fastener
M4 Nut 3 2 Fastener
LaserCutZLeadscrewOptoExploded.jpg Be warned that you probably need an additional washer against each bearing to allow the belt enough space for smooth running between the mudguard washers. LaserCutZLeadscrewBaseExploded.jpg
Z Motor
Z Tensioner
Be warned that you probably need an additional washer against each bearing to allow the belt enough space for smooth running between the mudguard washers. LaserTensionerExploded.jpg
Frame
Frame Sides
Left Side
BOM
Name Qty/assembly Type
M8 Nut 14 Fastener
M8 Washer 14 Fastener
370mm M8 Threaded Rod 3 Hardware
corner vertex 3 Laser Cut Part
Z Leadscrew base 1 Laser Cut Part
Z Motor Bracket 1 Laser Cut Part
You will also need a measurement jig to get the distance between the corner vertices the same. I created a jig using one of the other bits if M8 rod, 4 nuts and 2 washers. I assembled the jig so that the outside of the two washers was 290mm apart. Then used it when tightening the nuts on the vertex pieces to ensure the spacing was right. LaserCutFrameTriangleJig.jpg
Right Side
BOM
M8 Nut 14 Fastener
Z Tensioner Bracket 1 Laser Cut Part
Assembled Frame
