Laser Cut Mendel Pulleys
Release status: Experimental
Description | |
License | unknown
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
This is a set of laser cut-able Mendel pulleys derived from a parametric OpenSCAD model I designed for this purpose. I plan to eventually make a complete set of configurations for the Mendel pulleys but in the mean time you can download the ready to cut drive pulley dxfs and it should not be to hard with the trusty OpenSCAD wikibook in hand to make the z driven pulleys (and then post them back here!).
Background
Mendel uses belt pulleys in driving it's x,y and z axis as well as in it's driven z axis threaded rods. The problem is that many cheap 3d printers such as the Makerbot, RepRap, etc. are still working on being able to print accurate parts. The lack of symmetry in these parts caused by printer inaccuracy can then cause further inaccuracy in the child printer. This is a version of each gear in Mendel that can be cut by a high precision laser cutter or CNC mill so as to increase the precision of Mendel.
Design/Usage
For each pulley a series of pulley parts (those marked with the pulley suffix) are laser cut and stacked until the gear is tall enough (the number of pulley parts you will need depends on the thickness of your material). Then a nut trap piece is laser cut from a peice of material no taller then Z_HEIGHT and a final pulley piece is placed on top and then tightened down onto an entrapped nut.
DXF Files
drive-pulley_3off
z-driven-pulley_2off.par
- not yet made. If you make these please add them!
