Laser Cutter/Background
Introduction
What are the Laser Cutter Master Works? I'm doing some legwork for a friend who is thinking of buying a laser cutter for art, craft, design, and architectural modeling, and I'm trying to figure out if I want to build my own for various geek reasons. What have people done with them?
More specifically, what are the most beautiful, or technically innovative, or coolest works? What works have really pushed the boundaries of the tool?
I have tacked up a couple notes on a wiki of pieces that have caught my eye, but I've been wondering what the best stuff is.
Just discovered
and http://ask.metafilter.com/142220/Activate-Laser
What can you cut?
With a < 100 Watt LC, you can cut pretty much anything but metal sheet, and you can mark many kinds of metal sheet, if you muck around with coatings and masks and etching agents.
Via lasercuttinginc.us:
  • Materials we Laser Cut:
  • Acrylic (Plexiglass, Lucite)
  • PETG
  • ABS
  • Nylon
  • Expanded PVC (Sintra, Celtec)
  • Polycarbonates (Lexan)
  • Polyester (mylar)
  • Wood (solid & plywood)
  • MDF Medium Density File Board
  • Laminates (Formica)
  • Cardboard
  • Paper
  • Textile Fabric (Cloth)
  • Rubber (neoprene & silicon)
  • Acmetal, (Delrin, Celcon etc.)
  • Depron
  • Fluoropolymers (thin gauges)
  • Fiberglass
  • Kapton
  • Linoleum
  • Silicone Bonded Mica
  • Polyethylene
  • Polypropylene
  • Polyurethane
http://www.lasercuttinginc.us/index.php/services/lasercut
What can't you cut?
Metal. Shops use a >400-600W laser to cut stainless steel and so on. Hypothetically, you might be able paint a metal sheet with a mask and burn of the mask where you want cut lines, and then electrochemically etch the metal, but it's tedious. Model railway folk do this all the time with conventional masks and photolithography.
Fab lab folk have cut through the thin copper layer on clad board by cutting through the backside; the laser heats up the board material which softens the metal and the air assist blows both materials away. In this case the laser needs enough power to "cut" the copper but would have had reflection issues. To make very small thin metal parts, a shim stock is bonded to a sacrificial material with cyanoacrylate then cut with the above process. The metal parts are released by soaking with a solvent such as acetone. There is significant slag in this process and it is pretty much only entertaining or artistic.
Who makes them?
Chinese White Box
Epilog
Kern
What Can You Make
Jewelry
n-e-r-v-o-u-s
Material industrial wool felt and silicone
These bracelets and necklaces would be tricky to fabricate in small quantities using another technology. Even a craft knife would probably give crappy toolmarks and finish. As such, I regard these works as some of the best motivation for purchasing these tools.
Design concept: generative art-yay! Aesthetics: ?
More Etsy stuff
Paper
Cupcake wrappers, etsy - beautiful
Resources
Boxes
Plywood boxes
I could stand to be better at making boxes.
Acrylic Boxes
RBS/Beam
RBS/Beam - should be easy, no-one's gotten around to it.
Lamps
Acrylic sheet
Polygon made from HDPE or Acetal (delrin) sheet
This is a direct (and acknowledged) copy of:
Body Modification
Human skin in vivo - LC (quasi?temporary Tattoo)
airbrush temporary tattoo with LC stencil
Stencils
Acrylic sheet (etched, although it could be LC cut as well)
(Note: Try using the 'autopager' extension for the instructables website.)
Sticker
On Laptop
Mechanisms
Fabricative
Locomotive (Strandbeast)
Timepieces
Gear Trains
Power Transmission
Robotics
Clothing
Wallpaper
Again, a triumph of concept over aesthetic.
Architectural models
Victorian Doll House Birch plywood Laser Cut Kit 2
20" high, cut from 1/8" baltic birch, selling on etsy for $88. This might be a little pedestrian, but a kid would love it, and I think it has charm. Aside from LC, it would have to be die cut or scroll saw cut. From a fabricator's perspective, after doing quite a bit of work on the design, it is now very easy to make multiples and changes.
Structures
Dome
Plywood dome, 6' tall, 6' wide, cut on 32" x 18" LC, designed in Grasshopper (Rhino)
