Laser Cutter/ru
Revision as of 10:12, 28 February 2019 by Edlab (talk | contribs)
Существует серьезный риск ослепнуть при работе с лазерами. Всегда надевайте соответствующие лазерные очки!
Лазерный резак
Состояние выпуска: unknown
Описание turnkey or DIY laser-cutter toolheads
Лицензия GPL
Автор Sebastien Bailard, VDX
Соавторы
На основе [[]]
Категории Laser Cutter Toolheads
CAD модели нет
Ссылка на внешний ресурс нет
RepRap Research/Writeups
See the Laser Cutter Working Group@forum.reprap for discussion.
Фон
См. Laser_Cutter/Background
Cost Estimate
- comercial 'naked' diodelaser with [email protected] and 0.1mm atached glass fibre: ~230 Euros (in quantities above 5 pcs).
- turnkey-system with 10Watts @ 975nm, a visible red pilot-laser and jack for the glass fibre: ~1000 Euros (in quantities above 5 pcs).
Комплектующие
Источники лазерного света
- Различные лазерные диоды:
1 Watt pigtail diode laser with optical head, different diodes with up to 25 Watts, different diodes with up to 500 Watts:
1Watt Diode-laser with focussing head all laserdiodes High-Power-Laserdiodes
You can harvest RED LaserDiodes from old DVD burners. The quicker the burner the better. The types you can expect to find are more or less the following:
x12 speed recording – 200mW
x16 speed recording – 250mW
x16 Dual Layer speed recording – 300mW
x24 Dual Layer speed recording – 400mW
These are diven mostly around 300-400mA (to get around 200-250mW of power). With this little amount of power you can expect to engrave (in slow speeds) wood and paper, and cut colored paper. Помогает хорошая фокусировка.
In ebay there are Blue 2Watt lasers scavenged from DLP projectors. The so called M140 variety can go easily up to 2Watt when driven at 1.4Ampers. With this quite more hefty diode you can expect to cut any color of paper, light plywood, thin leather etc.
- IR-diodes internal assembly:
opened 5Watt-, 9Watt- + 25Watt-diodelasers, 20Watt808nm-diodelaser, [email protected]:
Internal Assembly 5Watt- and 9Watt-Diodelasers Internal Assembly 25Watt-Diodelaser
Internal Assembly 20Watt@808nm-Laserdiode Internal Assembly 200Watt@976nm-Laserdiode
- Complete modules:
5 Watt pigtail diode laser with 4xLM317-driver atached and lighting on a beam-indicator without optics:
5Watt-Diodelaser with 4xLM317-driver
complete 5 watt pigtail diode laser-module with 4x or 5x LM317-driver, MOSFET, microcontroller, armored tube and an optic head - prototype on the left, V2 on the right:
5Watt-Prototype1 5Watt-Prototype1
- Applications:
'real blue' 445nm-diode with 1Ampere current and roughly 1Watt output power. - left = focussed beam, middle = burning without filter, right = UV-filterplate:
445nm von Vorne kl.jpg 445nm - 1Watt ohne Filter.jpg 445nm - 1Watt mit Filter.jpg
1. Лазерный источник:
- CO2-lasertube ... sealed (RF) or 'naked' glass-tube
- diode-laser ... best with atached glass fibre (=pigtailed)
beam-feeding optics
2. beam-feeding optics:
- CO2: - зеркала
- диодные лазеры: - стекловолокно и/или линзы и зеркала
focussing optics
3. focussing optics:
- CO2: - Germanium- or ZnSe-lens for CO2-laser ... concave mirror is possible too
- диодные лазеры: - 'normal' optical lenses
3.1. Embedding a Pilotlaser as guide or beam-indicator:
Pilot-Laser
power source and output-power control
Main article: Bright Light Circuit
4. power-source:
- CO2: - mostly monolithic PS, good when below 40 Volts for RF-CO2-lasers, 'naked' and DIY-CO2-tubes need свыше 1000 Вольт
- диодные лазеры: - constant-current-driver (e.g. more LM317 in parallel)
LM317 parallel
- a 5xLM317-driver with switching MOSFET:
5xLM317
- modified driver with 2xLM317 with 1Ampere each and 3xLM338 with 2, 2, and 2.6 Ampere for free combinations from 1 to 8.6 Amps:
5xLM317
5. output-power controller:
- CO2: - embedded in RF-CO2-lasers - mostly TTL-input capable of switching the laser output with some ten kHz
- диодные лазеры: - current-modulation and/or PWM-switching for diode-lasers until some kHz.
A very cheap and stable solution is the AMC7135 chip that can be easily found as flashlight driver. Its a super simple constant current regulator that works up to 6V (so the 5V PC power supply is enough). Every AMC7135 provides 350mA of power and you can parallel them. So that means 2 AMC7135 provide 700mA , 3x 1050mA 4x 1400 etc. A small 47μF capacitor near the laser leads should protect the laser from spikes.
The PT4115 driver is more versatile and it can be set with a sense resistor. It also has a PWM pin. It can also be found as flashlight driver but it can need modding, ie change the sense resistor and/or attach a cable to the PWM pin.
- диодные лазеры: - AOM (AcoustoOpticalModulator) switching until some hundred kHz
6. controlling the output-power:
- generating geometrically defined pulses from the XY-clocks of the CNC-controller:
XY-pulsegenerator
- calculating the needed power relative to moving speed of the laser focus
Air Jet
While not strictly necessary, many laser cutters have a blow a jet of air at the point being cut. Is it better to use (a) relatively cool room-temperature air, or (b) hot air?
Применение
CO2-лазерная резка акрила:
CO2-cutting encoder-disc
Диодный лазер:
- резка:
- brazing / hard soldering:
hard soldered gold-paste
Multi-Diode-Laserhead:
- similar to an inkjet-printer, where many nozzles ar aligned in an array to print many dot-lines synchrone, you can align multiple diode-lasers in an array to process parallel lines simultaneous.
With falling prices of laserdiodes it should be possible to build a head with 8 hating/burning spots in a line with a distance of 5mm (diameter of typical small collimator-lenses) between them (or less, when arranging in a zigzag-array) in a DIY-range below 1000 Euros.
With a software separating the processing data for the single lasers you can speedup the time per sheet along with the count of lasers ...
Capacity/Specifications
Требования
Питание
Резервуар с азотом или чистый сухой сжатый воздух.
Скорость резки
The primary factors affecting cutting speed v are laser beam power P, the material being cut and its thickness h. The dependence of v on P and h is approximately proportional, i.e. severance energy P/hv is approximately constant for a fixed material and cutting process. Severance energy can be thought of as the laser beam energy needed to make a cut of 1 mm2 area (i.e. 1 mm cut length × 1 mm thickness). Note that 1 Watt power is 1 Joule of energy per second, so a 36 W laser should cut 3 mm acrylic sheet (P/hv=1.2 J/mm2) at the speed of about v = P/h / (P/hv) = (36 W) / (3 mm) / (1.2 J/mm2)=10 mm/sec.
Severance energies (10.6μm CO2 laser) from [1], p. 159
Материал Typical severance
energy (J/mm2)
Min-max severance
energies (J/mm2)
Cardboard 0.5 0.2–1.7
Acrylic sheet 1.2 1–3
Plyboard 31 20–65
Cutting Speed and other firmware considerations in RepRap firmwares
Using a laser on a reprap machine requires usually lower speeds. In order to achieve them, it maybe necessary to change the acceleration settings on your reprap firmware. With acceleration of 800mm/sec² the lowest achievable speed is F360 (6mm/sec). Changing the acceleration speed to 80mm/sec² will achieve a lowest speed of F120 (2mm/sec).
Instead of tweaking acceleration you can also use Teacup Firmware, which allows feedrates down to F1. That's a full minute for a single millimeter and should be fine for even the slowest cuts.
If you are using the M106/M107 (fan on/off) for laser on/off then a G4 P0 command is actually needed before and after every M106/M107 command. If the laser is not so powerful then the G4 P0 command after every M106 (laser on) should be set to something like G4 P250 (wait 250milliseconds) in order to give the laser point a head start. your mileage may vary, so testing is your best friend :)
Экспериментируя с красным лазером из DVD-писалок
While CO2 lasers are great and quite cheap to get, they are bulky and need to be mounted away from the head of your laser cutter. Thats the reason most people in the hobby category opt for a diode laser. While from 2014 and on, everybody's favorite diode seems to be the so called blue (445nm) M140 harvested from old projectors (1,4W and 2W variety), those diodes tend to be quite expensive for experimentation. The same (and more expensive) rule applies to even beefier lasers that make their rounds on ebay.
 Sourcing red lasers from old DVD recorders on the other hand is quite cheap and driving them with a LM317 or an AMC7135 even cheaper. But what a flimsy red diode running at around 350mA can really achieve as a laser cutter?
I dare say quite much if you handle with care. You have seen the videos on the internet, but I havent found yet a source of tips and tricks. Вот мое мнение по этому поводу.
a) While laser cutters dont need a Z axis, try to get one. Getting the right distance from the material you want to cut is essential and this is more true for weak lasers. While you can get the right distance by focusing your lenses, re-focusing is a tedious job and a pain in the ass. A z-axis permits you to focus once on Z=0 and then adjust the height of you axis to the height of the material you want to cut/engrave.
b) Did I mention how important is the right focus? The thinner your burning tip is the more concentrated power you get. Doubling the size of the tip spreads the power logarithmically, so adjusting the focus is paramount. The difference between focused and unfocused is sometimes quite miniscule in terms of turns of the screw-on lens. Sometimes a 5-10degree turn can make a huge difference. Thats why its important to have a Z-axis in order to offset for the height of your cutting material.
c) Go slow. I use RepRap firmware which is adjusted for 3d printing. Going slow even to 1mm/sec is going to give your laser time to cut/engrave easier. (in order to do that in reprap firmware you should decrease the acceleration. Test with a timer if the F Value (mm/min) reflects to actual time your carriage travels.
d) Go darker. The darker the color of the material you are trying to cut the easier it is for the laser to burn. For wood I use some stain, for paper colored paper
e) Используйте G4 PXXX . This is essential if you are using the M106/M107 commands to drive your laser (Fan on/off). G4 PXXX adds a pause in miliseconds. Обычный трюк состоит в следующем G4 P0 M106 ; лазер включен G3 P250 ; ждем 250 миллисекунд.
Эта пауза дает лазеру время начать прожигать. Once it has started burning its easier to continue. The G4 P0 command help synchronize movements. M106 is meant for fan on/off and sometimes without a G4 P(ause) command it doesnt play well
Здоровье и безопасность
Лазерные очки необходимы при работе с лазерами!
This laser goggles have blocking ranges of 700-1100nm (for diode-lasers and NdYAG) and 10600nm (for CO2-lasers)
Лазерные очки
Пары чрезвычайно токсичны и канцерогенны!
You can absorb the toxic vapours by exhausting the fuming area through a charcoalabsorber - e.g. the disc-shaped filters often used in deep fat fryers, or filtering units for soldering ...
Common laser-fume absorbers are really big parts but much more capable than absorbers for soldering vapours:
When using inert (and other) gases in an enclosed room you have to test for leakage or monitor the oxygen-concentration in the room.
Similar projects
There are some similar projects to create an Open Source laser cutter, some of them already shipping devices:
References
  1. Steen, Mazumder. Laser Material Processing, 4th ed, Springer-Verlag, 2010.
Внешние ссылки
