Laser Cutter Notes
Revision as of 08:31, 16 February 2010 by VDX (talk | contribs) (Components)
Laser Cutter
Release status: unknown
turnkey or DIY laser-cutter toolheads
[[Category:Laser Cutter][Category:Tools]]
RepRap Research/Writeups
Bright-VikBot or a good name.
Background
See Laser_Cutter/Background
Discussion: http://forums.reprap.org/read.php?70,13836,14061#msg-14061
Laser Light Sources
~45 sealed CO2 laser ...
1 watt pigtail diode laser with optical head (focus ~50 microns): File.php?0,file=1984,filename=Lasediode1-1Watt.jpg
Cost Estimate
- comercial 'naked' diodelaser with [email protected] and 0.1mm atached glass fibre: ~230 Euros (in quantities above 5 pcs).
- turnkey-system with [email protected], a visible red pilot-laser and jack for the glass fibre: ~1000 Euros (in quantities above 5 pcs).
Components
1. Laser-source: - CO2-lasertube ... sealed (RF) or 'naked' glass-tube - diode-laser ... best with atached glass fibre (=pigtailed) - ...
2. beam-feeding optics: - mirrors for CO2-laser - glass fibre (or lenses and mirrors) for diode-laser - ...
3. focussing optics: - Germanium- or ZnSe-lens for CO2-laser ... concave mirror is possible too - 'normal' optical lenses for diode-laser - ...
4. power-source: - mostly monolithic PS, good when below 40 Volts for RF-CO2-lasers, 'naked' and DIY-CO2-tubes need above 1000 Volts - constant-current-driver (e.g. more LM317 in parallel) - ...
5. output-power controller: - embedded in RF-CO2-lasers - mostly TTL-input capable of switching the laser output with some ten kHz - current-modulation and/or PWM-switching for diode-lasers until some kHz - AOM (AcoustoOpticalModulator) for diode-laser switchin until some hundred kHz - ...
Usage
Capacity/Specifications
Requirements
Power
Nitrogen tank or clean dry compressed air.
Health and Safety
