Lawson Buyers Guide
Lawson Documentation
Lawson
Release status: concept
Description | Lawson is a 3D printer with accurate linear motion and a mechanically stiff frame.
License | |
Author | |
Contributors | |
Based-on | [[]]
Categories | |
CAD Models | |
External Link |
Entries on this page are in no way an endorsement of quality of goods or service. Do your research by Googling <company_name RepRap forum> before you buy. This will usually find other Reprappers' experience with a given company on our forums.
Component Sourcing
Design Goals
- Simple part sourcing. The number of different suppliers needed to obtain all of the Lawson parts is minimized. Users can obtain 95% of the components from as few as two suppliers.
- Printable parts also have purchasable counterparts. The Lawson printer, unlike most printer designs, has no components which must be 3D printed, although many of the parts can be 3D printed. This design is accessible to users without access to 3D printers, or who prefer to use metal components instead of plastic ones.
Suppliers
To simply part sourcing, 95% of Lawson components can be obtained from two suppliers, Misumi and OpenBuilds Parts Store. A large number of alternative suppliers can be found in the RepRap Buyers' Guide.
Misumi
Description | Part Number | Quantity |
Black 2020 400mm | HFSB5-2020-400 | 2 |
Black 2020 380mm | HFSB5-2020-380 | 2 |
Black 2020 180mm | HFSB5-2020-180 | 1 |
Black 2020 60mm | HFSB5-2020-60 | 1 |
Black 2020 50mm | HFSB5-2020-50 | 1 |
Black 2040 380mm | HFSB5-2040-380 | 3 |
Heavy duty bracket | HBLTDW5 | 2 |
GT2 Pulley | GPA22GT2060-B-H4 | 1 |
Shaft collar | SDSJ16-8 | 1 |
2-hole Thin bracket | HBLSS5 | 4 |
4-hole bracket | HPTSSL5 | 2 |
8-hole L bracket | HPTLD5 | 2 |
4-hole L bracket | HPTLS5 | 4 |
4-hole T bracket | HPTTS5 | 2 |
Precision lead screw | MTSRA10-345-S12-Q6 | 2 |
Lead screw nut | MTSNR10 | 2 |
430mm steel slide | BJKSW20-430 | 1 |
OpenBuilds
RepRap Discount
Description | Quantity |
RUMBA electronics kit | 1 |
MK2A Aluminium heat bed | 1 |
E3D
E3D 1.75mm bowden | 1 |
