Laywoo-D3
Revision as of 04:41, 16 July 2013 by 3ddinge (talk | contribs) (Created page with '{{Languages}} File:File:Laywood_250.jpg Wood filament LAYWOO-D3 is a wood/polymer composite - the filament contains recycled wood and harmless binding polymers. The materi…')
File:File:Laywood 250.jpg
Wood filament LAYWOO-D3 is a wood/polymer composite - the filament contains recycled wood and harmless binding polymers. The material has similar thermal durability as PLA and can be printed between 175°C and 250°C. "After printing it looks like wood and smells like wood."
Depending on the temperature you can even print wooden-like objects with annual rings. At 180°C, the prints has a light color, at 245°C it becomes darker. Afterwards the printed objects can be cut, grinded or painted.
Features:
near zero warp rough or smooth surface possible during one print printable tree-rings stick well on print bed, no heated bed necessary recommended extruder temperature 185°C (bright) to 230°C (dark color appearance) the filament contains 40% recycled wood
Text from 3ders.org
