List of Firmware
Revision as of 15:00, 1 September 2024 by Ddrmax (talk | contribs) (Cleanning and moving firmwares no more updated to the abandonned and deprecated firmware page (cont))
This page is the authoritative list of active firmwares.
For a list of out-of-date firmwares, see List of Abandoned and Deprecated Firmware:
Klipper
FIRMWARE INFO
Details Description
Author(s) : KevinOConnor
Status : Active as of September 2024
Firmware that runs all calculations on a host and has the MCU execute steps at specified times
Features
  • High precision stepper movement.
  • High step rates even on 8bit.
  • Kinematics algorithms, the G-code parsing, and more are in Python.
  • Multiple microcontrollers supported on single printer.
  • Configuration via single file, no need to flash MCU.
  • Host software can run on Raspberry Pi.
  • Supports Cartesian, Delta, and CoreXY. Adding more only requires changes to Python code.
Compatible Electronics
How to download
Can download like this:
git clone https://github.com/KevinOConnor/klipper
Documentation & Misc. Notes
Documentation on GitHub: https://github.com/KevinOConnor/klipper/blob/master/docs/Overview.md
Prusa Firmware
FIRMWARE INFO
Details Description
Author(s) : Prusa Research
Prusa Firmware is provided by Prusa Research for Prusa printers. It is a fork of Marlin which has been highly tailored for Prusa FDM 3D printers.
Features
  • Planner lookahead to maintain fast motion.
  • High stepping rate, ideally 20KHz or higher
  • Interrupt-based movement with real linear acceleration
  • Interrupt-based temperature protection
  • Pressure Advance extrusion
  • Endstops support
  • SD Card support with sub-folders and long filenames
  • 20x4 Character LCD support
  • LCD Menu with Encoder Wheel
  • Persistent storage (EEPROM) for configurable settings
  • Temperature oversampling
  • Dynamic Temperature setpointing aka "AutoTemp"
  • Heater power reporting for PID monitors
How to download
Can download like this: ?
Marlin
FIRMWARE INFO
Details Description
Author(s) : Erik van der Zalm: Active as of February 2014; Bernhard Kubicek: Active as of November 2011
Development on this firmware appears to be very active. Forked from Sprinter and Grbl.
Features
  • Multi-platform (AVR, SAM, LPC, STM32, ESP32, Teensy, BCM283x, BCM2711B0, etc.)
  • Configurable for a wide variety of machines
  • Optimized S-curve acceleration
  • Junction Deviation for smooth direction changes
  • Linear Advance extrusion. (For more info see: this reprap-dev mailing list message.)
  • Endstops support, enhanced for interruptible pins
  • Endstop trigger reporting to the host software.
  • Host interaction
  • LCDs / Controllers: Character, Graphical, and Serial (Ideally 20x4, but 16x4 and 20x2 are supported.)
  • LCD Menu with Encoder Wheel or Keypad for standalone SD card printing.
  • Persistent storage (EEPROM, Flash, SD) for configurable settings
  • Arc and Bezier Curve support in 3 planes
  • CoreXY and Delta support.
How to download
The latest release of Marlin can always be found at marlinfw.org.
All Marlin release and development branches are hosted on Github.
Repetier-Firmware
FIRMWARE INFO
Details Description
Author(s) : Repetier
Status : v1.0.3 (Active as February 2019, with v 2.x in development)
forked from Sprinter.
Features
  • RAMP acceleration support.
  • Path planning (look ahead) for higher print speeds. (since version 0.32, 2011/9/24)
  • Fast ooze prevention system. (since version 0.35, 2011/10/8)
  • Trajectory smoothing for smoother lines. (since version 0.32, 2011/9/24)
  • Nozzle pressure control for improved print quality with RAMPS. (since version 0.32, 2011/9/24)
  • Fast - 16000 Hz and more stepper frequency is possible with a 16 MHz AVR. (since version 0.32, 2011/9/24)
  • Multiple extruder supported (experimental).
  • Standard ASCII and improved binary (Repetier protocol) communication.
  • Autodetect the command protocol, so it will work with any host software.
  • Continuous monitoring of one temperature.
  • Important parameters are stored in EEPROM and can easily modified without recompilation of the firmware.
  • Stepper control is handled in an interrupt routine, leaving time for filling caches for next move.
  • PID control for extruder temperature.
  • Interrupt based sending buffer (Arduino library normally waits for the recipient to receive written data)
  • Small RAM memory print, resulting in large caches.
  • Supports SD-cards.
  • mm and inches can be used for G0/G1
  • Works with Skeinforge 41, all unknown commands are ignored.
  • Dry run : Execute your GCode without using the extruder. This way you can test for non-extruder related failures without actually printing.
  • User defined and generic thermistor table( just set r0,t0,beta,r1,r2) in config (since version 0.31).
  • LCD support
How to download
github code
github wiki
RepRap Firmware
FIRMWARE INFO
Details Description
Author(s) : DC42 and Chrishamm(active) Adrian Bowyer (initial)
Status : DC42 and Chrishamm forks active as of September 2024
RepRapFirmware is intended to be a fully object-oriented highly modular control program for a wide variety of machine kinematics
Features
How to download
Smoothie
FIRMWARE INFO
Details Description
Author(s) : Jim Morris, Arthur Wolf, Mark Cooper, Triffid Hunter, and an army of others
Firmware for 32-bit ARM NXP LPC1768 Cortex-M3 boards (includes a port of Grbl)
Features
  • Ethernet
  • USB composite
  • Easy configuration without compilation
  • Digital current control
  • Fast an "near-perfect" step generation and acceleration
  • Support for laser and CNC milling also
  • Extremely complete documentation
  • Large and active community
  • Stepper extruder
  • Extruder speed control
  • Movement speed control
  • Heated build platforms
  • SD card support
How to download
git clone https://github.com/Smoothieware/Smoothieware.git
Further reading
