LongboatPrusa
Revision as of 17:52, 29 October 2011 by JamesWalsh (talk | contribs) (Step 2 Cross Bars)
Longboat Prusa
Release status: Working
LM8UU Liner Bearing Based Prusa.
GPL
Mendel Variations
Coming soon.
The Longboat Prusa, is a Prusa Mendel variant which uses LM8UU liner bearings on all axis’s. It has a 4mm aluminium heated print bed, Y axis carriage and X axis carriage.
Bill of Materials
Printed Plastics
Quantity Description Type Comments Diagram
Smooth Rod
  • 2x 414mm 8mm stainless steel round bar
  • 2x 406mm 8mm stainless steel round bar
  • 2x 350mm 8mm stainless steel round bar
Threaded Rod
  • 6x 370mm M8 Threaded rod
  • 4X 294mm M8 Threaded rod
  • 3x 440mm M8 Threaded rod
  • 2x 210mm M8 Threaded rod
  • 1x 59mm M8 Threaded rod
Nuts, Bolts & Washers
  • 100x M8 Nut
  • 100x M8 Washer
  • 5x M8 Mudguard washer
  • 1x M8 Nyloc Nut
  • 15x M4 nut
  • 10x M4 Nyloc Nut
  • 10x M4 Washer
  • 4x M4 Wing Nut
  • 3x M4 Bolt16
  • 4x M4 Bolt50
  • 6x M4 CSK Machine Screw 40mm
  • 40x M3 Washer
  • 80x M3 Nut
  • 3x M3 Machine Screw 8mm
  • 20x M3 Machine Screw 10mm
  • 30x M3 Machine Screw 16mm
  • 20x M3 Machine Screw 20mm
  • 25x M3 CSK Machine Screw 12mm
  • 2x M3 CSK Machine Screw 16mm
  • 3x M3 Grub Screw 6mm
Belts
  • 840mm x 5x T5 pitch timing belt
  • 900mm x 5x T5 pitch timing belt
Bearings
  • 4x 608zz
  • 12 LM8UU Liner
Thick Sheet
  • 1x 4mm aluminium heated print bed
100px Media:Longboat-Prusa-heated-print-bed.dxf
  • 1x 4mm aluminium X-plate
200px Media:Longboat-Prusa-X-Plate.dxf
  • 1x 4mm aluminium Y-plate
200px Media:Longboat-Prusa-Y-Plate.dxf
Heated bed parts
Extruder parts
Hot End parts
Electronics
  • Longboat all in one electronics board coming soonor any other version.
Steppers
Assembly
Frame assembly
In this section we will be looking at the frame assembly.
NOTE: Even if you have assembled a RepRap Prusa before please read these instructions as our frame differers slightly from the standard Prusa.
Tools
30cm rule
M8 Spanner
Step 1 Frame triangles
Components
  • 28x M8 Nuts Bag 1
  • 28x M8 Washers Bag 2
Instructions
Divide the above components in to two even sets.
Take one of the lengths of threaded rod and slide a bar clamp to the middle. Place a washer and then a nut either side of the clamp.
Place a nut, washer and then a frame vertex with foot followed by a washer and the nut on to each end of the rod. Loosely tighten the nuts.
Attach two more lengths of threaded rod to each footed frame vertex, using a washer and nut either side as before.
Attach a non footed frame vertex to the connect up the triangle.
Repeat all the above instructions until you have two matching frame triangles.
Place each frame flat on you desk, using your ruler tighten the nuts until each side is 290mm (measure from plastic to plastic)
Step 2 Cross Bars
Components
  • 2x 608zz Bearings
  • 4x 294mm M8 Threaded rod
  • 14x M8 Nuts Bag1
  • 15x M8 Washers Bag2
  • 4x M8 Mudguard Washers Bag 3
Instructions
Take the Y motor mount and attach a 294mm length of rod through the bottom hole, approximately half way along the rod. Fix in place with a M8 washer and M8 nut either side.
Take a Bar clamp and attach in to a 294mm length of rod, approximately a quarter of the way in from one end. Fix in place with a M8 washer and M8 nut either side. Then attach a M8 nut and M8 washer half way down the rod. Attach this rod through the top hole of the Y motor mount.
Add the following components, a M8 Mudguard washer, M8 washer, 608zz bearing, M8 washer, M8 Mudguard washer and then a nut.
Add a bar clamp to the rod attaching with a M8 washer and M8 nut either side.
On a new 294mm length of rod attach a 608zz bearing, followed by a M8 washer, M8 Mudguard washer and M8 nut either side. Attach the remaining two bar claps either side of this, attaching with M8 washers and M8 nuts either side.
Y axis assembly
Coming soon.
X axis assembly
Coming soon.
Heated print bed
Coming soon.
Extruder and Hot End
Coming soon.
Wiring
Coming soon.
Commissioning
Coming soon.
Where To Purchase
http://www.thereprapkitstore.co.uk sell complete unassembled Longboat Prusa kits.
