MDFstrap
Work in progress.
Release status: experimental
Description | Build log for 3D Printer made with MDF
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
MDFStrap Summary
Check out the blog for recent updates Hacktivate Blog
X Axis
Have used threaded rod for the X axis.
Parts
- Lots x MDF off cuts
- Lots x Self tapping screws
- 8mm threaded rod
- 5 x 8mm nuts
- 2 x 8mm washer
- 2 x LM8UU Linear bearing
- 1 x Server rack mount rail
First I cut the server rack rail down with a grinder to allow more horizontal movement, created countersink holes for the countersunk self tap screws, attached some MDF to the back of the rail and for mounting the filament extruder and hotend to.
For the threaded rod bearings I used the same method as the Z axis to create indents, for the drive nuts (Z axis ones too) I pressed them into pieces of MDF first drilling a 14mm indent then a 10mm hole, then notching the 14mm indent so the nuts would press in correctly.
Then I attached everything with the self tap screws (guide holes drilled first)
Z Axis
Similar to Mendel and Prusa builds this has dual direct drive steppers.
Parts
- MDF
- 2 x 8mm Stainless steel rod (From Mustek 600 flatbed scanner)
- 4 x 608 skate bearings
- 14 x 8mm nuts
- 8 x 8mm washers
- 3 x 8mm threaded rod (about 1.5 meters)
- Several self tapping screws (holes drilled for guide)
I used more MDF off cuts to create the Z Axis, 8mm holes were cut for the stainless steel rods, 22mm indents were cut with a wedge drill bit then 10mm holes in the centre for the threaded rod, 8mm holes were cut for the centre threaded rod which was then used to make the distance between the sides accurate from top to bottom.
Y Axis
This was built using a Agfa Flatbed scanner.
- Stepper Cog Teeth: 24
- Belt Pioneer 419MXL
- 65.6814 steps per\mm
Extruder
Greg's_Hinged_Extruder Greg's Hinged Extruder
Electronics
- Sainsmart Arduino Mega 2560
- Sainsmart Ramps 1.4
- Sainsmart Endstops
- Sainsmart Full LCD Controller
- Sainsmart Heat Bed
- Xbox 360 Power Supply (to be replaced)
- 5 x Nema 17 Steppers
