MDFstrap
Revision as of 15:44, 8 April 2014 by Terryb8s (talk | contribs) (Prints)
MDFStrap
Release status: Working
Build log for 3D Printer made with MDF
MDFStrap Summary
I created this printer just to see if I could in my garage, the chassis is made of MDF and some particle board, the point was to get a good build volume, acceptable quality, and average speed on a small budget, I have taken inspiration from various other RepRap and RepStrap printers, have made many mistakes along the way but intend to keep improving the printer over time, I have recently started using the printer to print parts to improve itself.
Made In NZ
Check out the blog for recent updates Hacktivate Blog
X Axis
Brief
Originally created the X axis using a threaded rod method but found this to be far to slow, so changed it up for a GT2 Belt.
Parts
  • Lots x MDF off cuts
  • Lots x Self tapping screws
  • 8mm threaded rod
  • 5 x 8mm nuts
  • 2 x 8mm washer
  • 2 x LM8UU Linear bearing
  • 1 x Server rack mount rail
First I cut the server rack rail down with a grinder to allow more horizontal movement, created countersink holes for the countersunk self tap screws, attached some MDF to the back of the rail and for mounting the filament extruder and hotend to.
For the threaded rod bearings I used the same method as the Z axis to create indents, for the drive nuts (Z axis ones too) I pressed them into pieces of MDF first drilling a 14mm indent then a 10mm hole, then notching the 14mm indent so the nuts would press in correctly.
Then I attached everything with the self tap screws (guide holes drilled first)
Z Axis
Similar to Mendel and Prusa builds this has dual direct drive steppers.
Parts
  • MDF
  • 2 x 8mm Stainless steel rod (From Mustek 600 flatbed scanner)
  • 4 x 608 skate bearings
  • 14 x 8mm nuts
  • 8 x 8mm washers
  • 3 x 8mm threaded rod (about 1.5 meters)
  • Several self tapping screws (holes drilled for guide)
I used more MDF off cuts to create the Z Axis, 8mm holes were cut for the stainless steel rods, 22mm indents were cut with a wedge drill bit then 10mm holes in the centre for the threaded rod, 8mm holes were cut for the centre threaded rod which was then used to make the distance between the sides accurate from top to bottom.
Y Axis
This was built using a Agfa Flatbed scanner.
  • Stepper Cog Teeth: 24
  • Belt Pioneer 419MXL
  • 65.6814 steps per\mm
Extruder
I ended up buying this as it seemed like something that would be hard for me to get right otherwise, the original one is made of ABS.
I didn't have any sheet metal so I cut a bit out of the power supply casing for the Agfa scanner I stripped for parts, this was then used for securing J-Head Hotend to the gregs extruder.
Greg's Hinged Extruder
Electronics
Components
  • Sainsmart Arduino Mega 2560
  • Sainsmart Ramps 1.4
  • Sainsmart Endstops
  • Sainsmart Full LCD Controller
  • Sainsmart Heat Bed
  • Xbox 360 Power Supply (to be replaced)
  • 5 x Nema 17 Steppers
Prints
Here are some things I have printed so far.
