MKS 12864OLED
Revision as of 06:21, 25 July 2015 by Leiochen (talk | contribs)
Template:MKS 12864OLED
Release status: Working
3Dprinter Display
MKS-12864OLED
Overview
MKS-12864OLED adopts OLED display and created by Makebase.
It is suitable for the printer which carries with small display , installed size and good display effect .
Features
1. Default 1.3 inch OLED display; 2. If you have other sizes display, you can ask not to weld 1.3 inch OLED either , but the interface will be retained for users. 3. The interface of MKS-12864OLED is as the same as 2004/12864LCD.
Notice
1.The Marlin must be modified before use, the modification method refers to the below instructions. 2.Repetier may not work unless you self-develop one. 3.We will provide an example of firmware for testing, but does not provide technical support. 4.Each piece will be tested.
MKS 12864OLED Photo
Size
Connection
EXP1 connects to EXP1 of mainboard
EXP2 connects to EXP2 of mainboard
You must follow the connection sequence, especially 3v3 and GND, wrong connection will burn OLED. GND: connects to GND of OLED power ground 3V3: VCC of OLED power anode CLK: CLK of OLED clock MOSI: MOSI of OLED data RES: RES of OLED reset DC: DC of OLED data order option CS: CS of OLED chip selection
Instruction on Usage
1.If use Arduino IDE, We suggest updated version 1.5.4 . And unzip U8glib.rar into libraries directory. As follow:
2.Modify file Configuration.h, add the following sections, refers to the example firmware.
/*---------------MKS OLED patch_1-----------------------*/
// MKS  OLED 1.3''  128x64 FULL GRAPHICS CONTROLLER
// ==> REMEMBER TO INSTALL U8glib to your ARDUINO library folder
#define MKS_OLED13_128x64_FULL_GRAPHICS_CONTROLLER
#if defined (MKS_OLED13_128x64_FULL_GRAPHICS_CONTROLLER)
	#define DOGLCD
	#define U8GLIB_SH1106
	#define REPRAP_DISCOUNT_SMART_CONTROLLER
	#define NEWPANEL
#endif
3.Modify file dogm_lcd_implementation.h, add the following sections , refers to the example firmware.
/*---------------MKS OLED patch_2-----------------------*/
#elif defined(U8GLIB_SH1106)
U8GLIB_SH1106_128X64 u8g(23, 17, 16, 25);	// SW SPI Com: SCK = 23, MOSI = 17, CS = 16, A0 = 25
4.Modify file Marlin_main.cpp, add the following sections ,refers to the example firmware.
/*---------------MKS OLED patch_3-----------------------*/
  pinMode(LCD_PINS_DC, OUTPUT);
  pinMode(LCD_PINS_RST, OUTPUT);
  digitalWrite(LCD_PINS_RST  , LOW);
  delay(1000);
  digitalWrite(LCD_PINS_RST  , HIGH);
#endif
5.Modify file pins.h, add the following sections ,refers to the example firmware.
/*---------------MKS OLED patch_4-----------------------*/
#ifdef LCD_PINS_D5
#undef LCD_PINS_D5
#define LCD_PINS_D5 -1
#endif
#ifdef LCD_PINS_D6
#undef LCD_PINS_D6
#define LCD_PINS_D6 -1
#endif
#define LCD_PINS_RST  27
#define LCD_PINS_DC   25
#endif
Data Download
More data resource:
