MKS TB6600
Revision as of 10:58, 1 May 2024 by Simon.pilepich (talk | contribs)
Release status: Working
| Description | Stepper Driver
| License | |
| Author | |
| Contributors | |
| Based-on | |
| Categories | |
| CAD Models | |
| External Link |
Summary
High performance, cost-effective. Automatic idle-current reduction. Supply voltage up to 45V DC Output current up to 4.5A. Can be used on ramps(need mks cd),mks gen and so on
Features
- PWM chopper-type single-chip bipolar sinusoidal micro-step stepping motor driver.
- BiCD 0.13 (50 V) process, Lower Ron: 0.4 Ω(typ.).
- Output withstand voltage: VCC = 50 V.
- Output current: IOUT = 5.0 A (absolute maximum ratings, peak, within 100ms);IOUT = 4.5 A (operating range, maximal. value);More Stepper motors
- Thermal shut down (TSD) protection.
- Under voltage lock out (UVLO) protection.
- Over-current detection (ISD) protection.
- Double input port: Anti-reverse structure IDC haeder( 8pin symmetrical input) & HT-396-4pin input (suit for DIY).
- Stepless adjustable reference voltage.
- Compatible the CNC Stepper Motor.
- Offer an solution to change your CNC to 3D Printer.
- Board size: 50.5*50mm ; Carry 50*50*23mm aluminum Heat sink which build-in fix hole and connection hole.
- Auto half current, energy conservation.
- Photoelectric-isolation used in the input port,compatible more drive Level.
- Programmable micro step - 1/1, 1/2A, 1/2B, 1/4, 1/8, 1/16.
- Affordable price.
Settings of Driver
Connect direct
Connect with MKS CD
