Manual Support
Revision as of 19:46, 9 July 2011 by Madscifi (talk | contribs) (Created page with 'Various materials can be used as a manually placed support material when printing PLA (ABS has not been tested). While manually placing support material is only useful in a l…')
Various materials can be used as a manually placed support material when printing PLA (ABS has not been tested). While manually placing support material is only useful in a limited number of situations, it does allow for designs that cannot otherwise be printed.
The following materials are known to work as support material (that is, PLA will stick to the support):
  • Museum putty
  • Sculpey polymer clay
  • La Doll clay
Play-Doh does not work (PLA does not like to stick to it).
The first two materials work well as a support surface, but can be difficult to remove after printing. La Doll clay falls apart when soaked in water and consequently is works well as support in difficult to reach locations.
Manually placed support is most useful when the design includes a small number of flat (parallel to the print surface) overhangs that are ideally connected to the main body of the design.
This approach has not been tested with heated build platforms.
Skeinforge Settings
At present there is no support in Skeinforge for manually placed support so the a lot of manual work is required to prepare for printing.
When exporting from Skeinforge comments should be left in the exported file. This is done by setting:
  • Export -> Comment Choice -> Do Not Delete Comments
Also, if any of the support material extends ouside the body of the object it is often easier to place the material correctly if a tall skirt is used. This can be enabled by activing Skirt and setting:
  • Skirt -> Layers To (index) -> 100000
File Preparation
When Skeinforge has finished generating the GCODE you'll need to examine the layers in the Skeinlayer window in order to identify the z depth of the layers that need support. Examine the layers and record the z-depth of the layers that have areas that need to be printed directly on the support material.
It is useful to write down a description of the area that needs support along with the z depth as a reminder of where the support material needs be placed.
Next, the generated GCODE file should be split into n+1 pieces, where n is the number of layers that need support. This is needed in order to allow the manual support material to be placed. Each file should contain everything after the previous file and up to, but not including, the comment line that specifies the next layer that needs support.
It is useful to put a G1 Xa Yb GCODE command at the end of every file except the last one that moves the extuder off of the part being printed. A and B should be replaced with values that place the extuder outside of the bounds of the object being printed.
Printing
Print the first file.
When the file is done, reposition the print surface so you can easily get to the object to place the support material. Place the support material within the needed area on the part. The top of the support material should rise to the top of the last printed layer, or maybe very slighly lower, but it should not be higher than the last printed layer. Placing the material so that it stays in place and stays within the necessary bounds might take a little bit practice. In the case of La Doll clay, do be aware that the PLA will not stick if the clay is too wet.
Extrude a bit of plastic, clean the nozzle, and print the next file. Repeat the process of printing files and placing support until you have run every file.
Cleanup
Cleanup will depend largely on which support material you use. Museum putty and Sculpey will need to be machanically removed using a tweezers and or some other tool. La Doll clay can be significanly softened by soaking in water (remove any easy to remove external lumps first). Once softened, tweezers, a brush and bowl of water, or a source of pressurized water (outside, of course) will generally remove the remainder.
Example: Simple
The manual-support-1 test file defines a simple test object that needs easy to remove support in order to print. When completed, it consists of a captured ring that is contained by a rod and bound on each end by a disk.
Prepare the GCODE
This part needs support at two layers:
  • The bottom of the inner ring.
  • The bottom of the upper disk.
Assuming 0.2mm layers, z=5.2 and z=9.2 are the layers that need support.
The first file should contain the text from the start of the source file up to but not including the line:
(<layer> 5.2 )
The second file should contain the text starting with the "5.2" line up to, but not including, the line:
(<layer> 9.2 )
The last file should contain the text starting with the "9.2" line and include the remainder of the source file.
Printing
First file printed:
First support applied:
Second file printed:
Second support applied:
Third file printed:
Soaking
Cleaned up
