Marlin
Revision as of 06:11, 9 January 2015 by Traumflug (talk | contribs) (Moving away from the RepRap wiki isn't acceptable. Undo revision 140929 by Stv0g (talk))
Sprinter
a firmware for arduino compatible setups
GNU GPL v3
Firmware
The leading developers of Marlin are currently EvdZ and bkubicek, though many others contribute with their patches. This is a firmware for reprap single-processor electronics setups. It also works on the Ultimaker PCB. It supports printing from SD card+Folders, and look-ahead trajectory planning. This work is licensed under the GNU GPL v3 or (at the user's discretion) any later version. It is based on Sprinter firmware, which was licensed under GPL v2 or later.
Current Version: 1.0.0:
See Marlin on Github.
Works on RAMPS 1.4, Ultimaker and Sanguinololu, maybe? working on Generation_6_Electronics, and maybe other setups.
Quick Information
This RepRap firmware is a mashup between Sprinter, Grbl and many original parts.
Derived from Sprinter and Grbl by Erik van der Zalm. Sprinter's lead developers are Kliment and caru. Grbl's lead developer is Simen Svale Skogsrud. Sonney Jeon (Chamnit) improved some parts of Grbl. A fork by bkubicek for the Ultimaker was merged, and further development was aided by him. Some features have been added by: Lampmaker, Bradley Feldman, and others...
Features:
  • Interrupt based movement with real linear acceleration.
  • High steprate.
  • Look ahead (Keep the speed high when possible. High cornering speed).
  • Interrupt based temperature protection.
  • preliminary support for Matthew Roberts advance algorithm For more info see: http://reprap.org/pipermail/reprap-dev/2011-May/003323.html.
  • Full endstop support.
  • SD Card support.
  • SD Card folders (works in Pronterface).
  • LCD support (ideally 20x4 or 128x64).
  • LCD menu system for autonomous SD card printing, controlled by an click-encoder.
  • EEPROM storage of e.g. max-velocity, max-acceleration, and similar variables.
  • many small but handy things originating from bkubicek's fork.
  • Arc support.
  • Temperature oversampling.
  • Dynamic Temperature setpointing aka "AutoTemp".
  • Support for QTMarlin, a very beta GUI for PID-tuning and velocity-acceleration testing. https://github.com/bkubicek/QTMarlin
  • Endstop trigger reporting to the host software.
  • Updated sdcardlib.
  • Heater power reporting. Useful for PID monitoring.
  • CoreXY kinematics (http://www.corexy.com/theory.html).
  • Delta kinematics.
  • SCARA kinematics.
  • Auto bed leveling (actually auto bed compensation) support has been added.
  • Firmware binary size between around 50kB and 100kB, depending on options.
The default baudrate is 250000. Because this baudrate is directly derived from the usual 16MHz clock of the Arduino MCU, it has less jitter and hence errors than the usual 115200 baud, but 250000 baud is less supported by drivers and host-environments.
Differences from and additions to the already good Sprinter firmware
Look-ahead
Marlin has jerk-type look-ahead. Whithout it, it would brake to a stop and re-accelerate at each corner. Lookahead will only decelerate and accelerate to some non-zero velocity, so that the change in vectorial velocity magnitude is less than the xy_jerk_velocity. This is only possible, if some future moves are already processed, hence the name look-ahead. It leads to less over-deposition of material at corners, especially at flat angles.
Arc support
Slic3r can find curves that, although broken into segments, were meant to describe an arc. Marlin is able to print those arcs. The advantage is that the firmware can choose the resolution, and can perform the arc with nearly constant velocity, resulting in a nice finish. Also, less serial communication is needed.
Temperature Oversampling
To reduce noise and make the PID-differential term more useful, 16 ADC conversion results are averaged.
AutoTemp
If your gcode contains a wide spread of extruder velocities, or you realtime change the building speed, the temperature should be changed accordingly. Usually, higher speed requires higher temperature. This can now be performed by the AutoTemp function. You can enable AutoTemp mode by issuing M109 S T F and suable it by issuing M109 without any F value. When active, the maximal extruder stepper rate of all buffered moves will be calculated, and named "maxerate" [steps/sec]. The desired temperature then will be set to t=tempmin+factor*maxerate, constrained between tempmin and tempmax. If the target temperature is set manually or by gcode to a value less then tempmin, it will be kept without change. Ideally, your gcode can be completely free of temperature controls, apart from a M109 S T F in the start.gcode, and a M109 S0 in the end.gcode.
EEPROM
If you have established known working PID constants, acceleration, and max-velocity settings for your own machine, you can set them, then store them in the EEPROM. On each boot-up, Marlin will automatically load these values from EEPROM, independent of what your compiled Configuration.h says.
LCD Menu
If your hardware supports it, you can build a LCD-CardReader+Click+encoder combination. This will allow you to adjust temperatures, accelerations, velocities, and flow rates in realtime (while printing). It also provides the ability to select and print files directly from the SD card, preheat the extruder, disable the stepper motors, and do other interesting things. One working hardware configuration is documented here: http://www.thingiverse.com/thing:12663 . If you have at least a 20x4 or 16x2 display, useful data is shown.
SD card folders
If you have an SD card reader attached to your controller, folders now work. Listing the files in pronterface will show "/path/subpath/file.g". You can write to file in a subfolder by including the slash-separated path, using lowercase letters in the path. (Also, backup copies of various operating systems are hidden, as well as files not ending with ".g".)
If an endstop is hit while moving towards the endstop, the location at which the firmware thinks the endstop was triggered is output to the serial port. This is useful because the user gets a warning message. Tools like QTMarlin can use this to find acceptable combinations of velocity+acceleration.
Coding paradigm
Not relevant from a user side, but Marlin was split into thematic chunks, and has tried to partially enforce private variables. This is intended to make it clearer what interacts with what, and leads to a higher level of modularization. We think this is a useful preliminary step for porting this firmware to an ARM platform (for example) in the future. A lot of RAM (with enabled LCD ~2200 bytes) was saved by storing char []="some message" in Program memory. In the serial communication, a #define-based level of abstraction was enforced, so it's clear that some transfer of information (usually beginning with "echo:"), an error "error:", or just normal protocol, necessary for backwards compatibility.
Interrupt based temperature measurements
An interrupt is used to manage ADC conversions, and enforce checking for critical temperatures. This leads to less blocking in the heater management routine.
Delta compatible
TODO...
CoreXY compatible
Can use a CoreXY table.
Non-standard M-Codes, different to an old version of sprinter:
Movement:
  • G2 - CW ARC
  • G3 - CCW ARC
General:
  • M17 - Enable/Power all stepper motors. Compatibility to ReplicatorG.
  • M18 - Disable all stepper motors; same as M84.Compatibility to ReplicatorG.
  • M30 - Print time since last M109 or SD card start to serial
  • M42 - Change pin status via gcode
  • M80 - Turn on Power Supply
  • M81 - Turn off Power Supply
  • M114 - Output current position to serial port
  • M119 - Output Endstop status to serial port
Movement variables:
  • M202 - Set max acceleration in units/s^2 for travel moves (M202 X1000 Y1000) Unused in Marlin!!
  • M203 - Set maximum feedrate that your machine can sustain (M203 X200 Y200 Z300 E10000) in mm/sec
  • M204 - Set default acceleration: S normal moves T filament only moves (M204 S3000 T7000) im mm/sec^2 also sets minimum segment time in ms (B20000) to prevent buffer underruns and M20 minimum feedrate
  • M220 - set build speed mulitplying S:factor in percent ; aka "realtime tuneing in the gcode". So you can slow down if you have islands in one height-range, and speed up otherwise.
  • M301 - Set PID parameters P I and D
  • M303 - PID autotune, S = target temperature.
  • M400 - Finish all buffered moves.
Advance:
  • M200 - Set filament diameter for advance
  • M205 - advanced settings: minimum travel speed S=while printing T=travel only, B=minimum segment time X= maximum xy jerk, Z=maximum Z jerk
EEPROM:
  • M500 - stores paramters in EEPROM
  • M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily).
  • M502 - reverts to the default "factory settings". You still need to store them in EEPROM afterwards if you want to.
  • M503 - print the current settings (from memory not from eeprom)
Bug reports
For bug reporting please use the Issue tracker on github
