Mendel/Files/edrawings
Revision as of 13:48, 21 January 2010 by Jags (talk | contribs) (Files and Parts)
Example Development
Release status: unknown
documenting a generic tool/artpiece
E Drawing format for Mendel- development of cast components
Instructions. !
The drawings are provided on an as is where basis and if there is any changes or modifications the version change will be updated in respective folders. The drawings carry the same name as the original Mendel drawings naming nomenclature and strictly are derived from the original drawings. The format provided is a standard Edrawings format which allows the part to be viewed ,editied , dimensioned and printed. You will need a Edrawings viewer to see the files. The Edrawings viewer is available as a free download from here.
[1]-download link for-E-Drawings viewer.
All dimensions are mentioned in metric mm unless specified.
The components are also categorised as per the mechanical components, extruder parts, electronic components and universal standard fixtures.
Text
Share and Enjoy!
PayPal
KYAQTL95Y2FMS. Jags Paypal account.
Entrepreneurship (Kits)
Jags has a cottage industry making and selling kits. He's also the developer. If you want to buy a kit, he's the best person to buy one from.
Files and Parts
Media:Belt-split-jig-universal_2off.EPRT
Media:Belt_width_adjuster_1off.EPRT
Media:Bed-spring_4offA.EPRT
Media:Bed-height-spacer-31mm_1offA.EPRT
Media:Circuit-board-bracket-m3_4offA.EPRT
Media:Drive-pulley_3offA.EPRT
Media:Frame-vertex_6offA.EPRT
Media:X-180-z-bearing-plate_2offA.EPRT
Media:X-360-z-bearing-plate-mirror_2offA.EPRT
Media:X-360-z-bearing-plate_2offA.EPRT
Media:X-axis-side-plate-nut-jig_2offA.EPRT
Media:X-bar-clamp-m3_6offA.EPRT
Media:X-bar-clamp-m4_4offA.EPRT
Media:X-carriage-belt-clamp_2offA.EPRT
Media:X-carriage-lower_1offA.EPRT
Media:X-carriage-upper_1offA.EPRT
Media:X-end-bracket_2offA.EPRT
Media:X-motor-bracket-spacer_2offA.EPRT
Media:Xlr-bracket_1offA.EPRT
Media:X-vert-drive-nut-trap_4offA.EPRT
Media:X-vert-drive-side-plate-180-end_2offA.EPRT
Media:X-vert-drive-side-plate-360-end_2offA.EPRT
Media:Y-bar-clamp_10offA.EPRT
Media:Y-bearing-180-inner_2offA.EPRT
Media:Y-bearing-180-outer-left_1offA.EPRT
Media:Y-bearing-180-outer-right_1offA.EPRT
Media:Y-bearing-180_0offA.EPRT
Media:Y-bearing-360_0offA.EPRT
Media:Y-bearing-360-inner_2offA.EPRT
Media:Y-bearing-360-outer-left_1offA.EPRT
Media:Y-bearing-360-outer-right_1offA.EPRT
Media:Y-belt-clamp_2offA.EPRT
Media:Y-idler-bracket_1offA.EPRT
Media:Y-motor-bracket_1offA.EPRT
Media:Z-bar-top-clamp_4offA.EPRT
Media:Z-drive-pulley-rim_4offA.EPRT
Media:Z-driven-pulley_2offA.EPRT
Media:Z-leadscrew-base-bar-clamp_2offA.EPRT
Media:Z-leadscrew-base_2offA.EPRT
Media:Z-motor-bracket_1offA.EPRT
Media:Z-opto-bracket_1offA.EPRT
Media:Z-tensioner_1offA.EPRT
END OF MAIN PARTS FILES !
EXTRUDER PARTS
Photos and Drawings
Flicker Example
<flickr>2967868906|right</flickr>
Working Notes
Project Lead(s): Mr. Jagannathan Wiki-maintainers and helpers:
Forum thread?
http://dev.forums.reprap.org/
Files
There are no zip files loaded as of now.
Tooling
Description of tooling requirements.
Process
What is making the part like?
Notes
