Mendel/Files/edrawings
Release status: unknown
Description | documenting a generic tool/artpiece
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
E Drawing format for Mendel- development of cast components
Instructions. !
The drawings are provided on an as is where basis and if there is any changes or modifications the version change will be updated in respective folders. The drawings carry the same name as the original Mendel drawings naming nomenclature and strictly are derived from the original drawings. The format provided is a standard Edrawings format which allows the part to be viewed ,editied , dimensioned and printed. You will need a Edrawings viewer to see the files. The Edrawings viewer is available as a free download from here.
[1]-download link for-E-Drawings viewer.
All dimensions are mentioned in metric mm unless specified.
The components are also categorised as per the mechanical components, extruder parts, electronic components and universal standard fixtures.
Text
Share and Enjoy!
PayPal
KYAQTL95Y2FMS. Jags Paypal account.
Entrepreneurship (Kits)
Jags is working on the cast-molded mendel parts for easy -cheaper duplication. All parts are being tooled and from master we make the molds to cast epoxy filled parts. some parts are also glass fibre filled parts.. matching metal and plastics. This is to have uniformity and easy duplicability..
Files and Parts
Media:Belt-split-jig-universal_2off.EPRT
Media:Belt_width_adjuster_1off.EPRT
Media:Bed-spring_4offA.EPRT
Media:Bed-height-spacer-31mm_1offA.EPRT
Media:Circuit-board-bracket-m3_4offA.EPRT
Media:Drive-pulley_3offA.EPRT
Media:Frame-vertex_6offA.EPRT
Media:X-180-z-bearing-plate_2offA.EPRT
Media:X-360-z-bearing-plate-mirror_2offA.EPRT
Media:X-360-z-bearing-plate_2offA.EPRT
Media:X-axis-side-plate-nut-jig_2offA.EPRT
Media:X-bar-clamp-m3_6offA.EPRT
Media:X-bar-clamp-m4_4offA.EPRT
Media:X-carriage-belt-clamp_2offA.EPRT
Media:X-carriage-lower_1offA.EPRT
Media:X-carriage-upper_1offA.EPRT
Media:X-end-bracket_2offA.EPRT
Media:X-motor-bracket-spacer_2offA.EPRT
Media:Xlr-bracket_1offA.EPRT
Media:X-vert-drive-nut-trap_4offA.EPRT
Media:X-vert-drive-side-plate-180-end_2offA.EPRT
Media:X-vert-drive-side-plate-360-end_2offA.EPRT
Media:Y-bar-clamp_10offA.EPRT
Media:Y-bearing-180-inner_2offA.EPRT
Media:Y-bearing-180-outer-left_1offA.EPRT
Media:Y-bearing-180-outer-right_1offA.EPRT
Media:Y-bearing-180_0offA.EPRT
Media:Y-bearing-360_0offA.EPRT
Media:Y-bearing-360-inner_2offA.EPRT
Media:Y-bearing-360-outer-left_1offA.EPRT
Media:Y-bearing-360-outer-right_1offA.EPRT
Media:Y-belt-clamp_2offA.EPRT
Media:Y-idler-bracket_1offA.EPRT
Media:Y-motor-bracket_1offA.EPRT
Media:Z-bar-top-clamp_4offA.EPRT
Media:Z-drive-pulley-rim_4offA.EPRT
Media:Z-driven-pulley_2offA.EPRT
Media:Z-leadscrew-base-bar-clamp_2offA.EPRT
Media:Z-leadscrew-base_2offA.EPRT
Media:Z-motor-bracket_1offA.EPRT
Media:Z-opto-bracket_1offA.EPRT
Media:Z-tensioner_1offA.EPRT
END OF MAIN PARTS FILES !
EXTRUDER PARTS
Photos and Drawings
Flicker Example
<flickr>2967868906|right</flickr>
Working Notes
Project Lead(s): Mr. Jagannathan Wiki-maintainers and helpers:
Forum thread?
Files
There are no zip files loaded as of now.
Tooling
Description of tooling requirements.
Process
What is making the part like?
