Mendel/Parts
Revision as of 00:06, 16 August 2010 by ClothBot (talk | contribs) (Page created for group-build preparation logistics. X-axis entries added.)
Mendel Parts
The following is a list of all parts used in Mendel construction with links to their individual datasheet pages.
Page Objectives
  • Web-browsable BOM summary.
  • Aid for optimized group-build of Mendel.
  • Links to Datasheets for each part containing detailed web-browsable drawings, sources and related notes.
    • Cross-referenced with build stages.
    • Cross-referenced with re-use in other Mendel design variations.
    • Cross-referenced with alternate part designs.
To Do
Bar
x-bar
Used In Qty/assembly
Mendel X-axis - Motor bracket 2
Total 2
Bearings
624-bearing
Mendel X-axis - Carriage 10
Mendel X-axis - Idler Bracket 6
Mendel X-axis - Vert bearing 360 6
Mendel X-axis - Motor bracket 4
Total 26
Fasteners
m3-nylock
Mendel X-axis - Idler Bracket 4
Mendel X-axis - Vert bearing 360 1
Total 9
m3-washer
Mendel X-axis - Idler Bracket 8
Mendel X-axis - Motor bracket 12
Total 21
m3x20-cap
  • Note: Standardizing name to match other parts of similar type. Files are currently named m3-capx20.
  • Datasheet: Mendel/Parts/m3x20-cap
Mendel X-axis - Motor bracket 8
Total 13
m4-nut
Mendel X-axis - Carriage 12
Mendel X-axis - Vert bearing 180 4
Mendel X-axis - Vert bearing 360 4
Total 20
m4-nylock
Mendel X-axis - Idler Bracket 11
Mendel X-axis - Vert bearing 360 14
Total 43
m4-washer
Mendel X-axis - Carriage 58
Mendel X-axis - Idler Bracket 36
Mendel X-axis - Vert bearing 180 16
Mendel X-axis - Vert bearing 360 44
Total 166
m4x16-cap
Mendel X-axis - Carriage 6
Mendel X-axis - Idler Bracket 2
Total 16
m4x40-cap
Mendel X-axis - Carriage 14
Mendel X-axis - Idler Bracket 9
Mendel X-axis - Vert bearing 180 8
Total 45
m5-mudguard-washer
Total 6
m8-nut
Total 2
Motors
stepper-motor-nema17-fl42sth47-1684A-01
Total 1
PCB
opto-endstop-v2-1-pcb
Total 1
RepRap Printed Parts
drive-pulley_3off
Total 1
x-180-z-bearing-plate_2off
Total 2
x-360-z-bearing-plate_2off
Mendel X-axis - Vert bearing 360 2
Total 2
x-360-z-bearing-plate-mirror_2off
Total 2
x-axis-side-plate-nut-jig_2off
Total 2
x-bar-clamp-m3_6off
Total 6
x-bar-clamp-m4_4off
Mendel X-axis - Vert bearing 180 2
Total 4
x-carriage-belt-clamp_2off
Mendel X-axis - Carriage 2
Total 2
x-carriage-lower_1off
Total 1
x-carriage-upper_1off
Total 1
x-end-bracket_2off
Total 2
x-vert-drive-nut-trap_4off
Total 4
x-vert-drive-side-plate-180-end_2off
Total 2
x-vert-drive-side-plate-360-end_2off
Total 2
Thin Sheets
x-flag
Total 1
z-flag
Total 1
