Mendel90
Revision as of 05:28, 5 March 2012 by AdrianKelly (talk | contribs)
Mendel90
Release status: Experimental
A Mendel with flat sheets at 90 degree angles
Mendel90 is being designed by Nophead to replace many of the threaded rods and printed parts of the Prusa Mendel with flat sheets, either MDF or Acrylic.
Advantages
Compared to the Prusa Mendel, which it is based off of.
  • Fully parametric across build area, motor size, rod size, and sheet material
  • Stiffer, especially in the X Direction, so it can go much faster without vibration
  • Much less calibration and jigging required; if your holes are in the right places, your rods will be parallel. If the buttresses are square, your printer will be square.
  • Can be drilled with a paper template to make sure all holes are perfect
  • Sheets are usually straighter and flatter than rods, as they are thicker and much wider
  • All the OpenSCAD files are fully parametric; you can set all the parts to whatever sizes you want and easily increase the build area
  • Everything is mounted on one of two planes, so it's all flat
  • Frame is held together throughout the machine, instead of just at the corners, so much less warping
  • Less vitamins
  • Open design, allowing it to be worked on easier and mostly dissassembled without falling apart
  • Z axis motors are at the bottom, so that the couplings don't need to support the weight of the X axis
    • This means the Z couplings can be smaller, and therefore Z smooth rods closer to the threaded rods, increasing stiffness
    • The center of balance is also lower, making it more stable
  • Less printed parts, so it can be printed easier and faster
  • Parts are ribbed to maintain strength and decrease print time
  • Ribbon cables are used to prevent cable tangling and friction
  • Rectangular, so it can be shipped and put in Heated Build Chambers easier.
  • Uses LM8UU bearings
    • Uses 10 instead of 12, so only one package is needed
Disadvantages
  • If you drill a hole wrong, it is much harder to fix than to adjust a nut on the Prusa Mendel
  • Less room for adjustment-only a few mm
  • MDF expands with heat and moisture, and Acrylic cracks-MDF could be coated with Epoxy
  • OpenSCAD files have not been released as of March 4, 2012
  • More volume of vitamins-sheets are larger than rods
  • Probably heavier and harder to ship
  • More types of screws
  • Louder because sheets act as soundboards
  • Fewer bearings might make it less accurate
Development
Nophead says he will put his OpenSCAD files on Github, but they are not up yet.
The STLs linked below are for an 8mm rod version with NEMA17 motors, T5 belts and an acrylic frame. They are copied directly from Thingiverse.
Bill of Materials
Printed Parts
STLs are links to Thingiverse, how do I upload them?
Required
Quantity Description File Diagram
Modified Wade's Geared Extruder
1 Extruder Body stl pic
1 Extruder Idler stl pic
1 Small Gear stl pic
1 Large Gear stl pic
1 Gear Spacer stl pic
1 Cable Mount stl pic
Optional
Non-Printed Parts ("vitamins")
All measurements are in millimeters.
 1 Sheet 468 x 432 x 10
 2 Sheet 170 x 324 x 6
 1 Sheet 224 x 224 x 6
 1 Sheet 468 x 324 x 6
 4 19mm bulldog clip
 3 624 Ball bearing 4 x 13 x 5, 1 for X idler, 2 for Y idler
 3 608 Ball bearing 8 x 22 x 7, for extruder
22 M3 cap screw x 10
22 M3 cap screw x 16
17 M3 cap screw x 20
 4 M3 cap screw x 25
 2 M3 cap screw x 30
 2 M3 cap screw x 45
 4 M4 cap screw x 20
 2 M4 cap screw x 40
 1 9 way D plug
 1 9 way D socket
 3 M3 grub screw x 6
 1 borosilicate (Pyrex) glass sheet 214 x 202 x 2
 5 M3 hex screw x 16
 2 M4 hex screw x 20
 2 M4 hex screw x 50
 1 M8 hex screw x 60
10 LM8UU
 5 NEMA17x47.5
 1 PCB bed
 1 polypropylene strip 373mm x 17mm x 0.5mm
 1 polypropylene strip 320mm x 27mm x 0.5mm
 1 polypropylene strip 275mm x 29mm x 0.5mm
38 M4 pan screw x 12
24 M4 pan screw x 16
 1 Smooth Rod 8 x 22, for extruder idler
 3 Smooth Rod 8 x 275, 2 for Z axis, 1 for Y
 2 Smooth Rod 8 x 382, for X axis
 1 Rod 8 x 428, for Y axis
 2 Threaded Rod 8 x 211
 2 Tubing OD 7 ID 5 x 16
12 No2 pan wood screw x 13
 6 ziptie 87
 1 belt T5x6x674
 1 belt T5x6x861
 4 hex pillar M3x20
 3 microswitch
 6 nut M3
 2 nut M4
 3 nut M8
45 nyloc nut M3
 6 nyloc nut M4
 2 rubber washer M3 x 9.7 x 1.5
 1 spring 12 x 0.75 x 10
 2 spring 7 x 1 x 10
18 star washer M3 x 7 x 0.5
53 star washer M4 x 9 x 0.9
12 washer M2.5 x 5 x 0.5
79 washer M3 x 7 x 0.5
78 washer M4 x 9 x 0.9
 4 washer M5 x 20 x 1.4
 1 washer M8 x 16 x 1.5
 2 wingnut M4
See Also
Category:Development
