Mendel X-axis
Revision as of 18:47, 11 October 2009 by Skinnyed (talk | contribs) (New page: Image:x-axis-assembly.PNG == Carriage == === Overview === [Image:carriage-ga.PNG]] === BOM === Total # of assemblies: 1 {| {{table}} | align="center" style="background:#f0f0f...)
Carriage
Overview
BOM
Name | Qty/assembly | Total Qty | Type |
x-carriage-belt-clamp_2off | 2 | 2 | RP |
x-carriage-lower_1off | 1 | 1 | RP |
x-carriage-upper_1off | 1 | 1 | RP |
m4-nut | 12 | 12 | Fastener |
m4-nylock | 10 | 10 | Fastener |
m4-washer | 58 | 58 | Fastener |
m4x16-cap | 6 | 6 | Fastener |
m4x40-cap | 14 | 14 | Fastener |
x-flag | 1 | 1 | Thin sheet |
RP parts
Assembly
- Assemble upper carriage first
- Then lower carriage. Note loaded trapped nuts.
- Assemble the two halves together using 6 M4x40 caps (don't forget the optoflag!). Tighten the middle two caps, keep the outer two pairs loose. When fully assembled use a piece of ø8 mm bar to set the distances between the bearings. Slide the bar between the bearings and tighten/slacken the outer two pairs of M4x40 caps to achieve a smooth, low resistance, running fit.
- Finally assemble the extruder.
