Mendel Z-axis
You may find the assembly data sheet useful during assembly.
Leadscrew base
Total # of assemblies 2
Name | Qty/assembly | Total Qty | Type |
z-leadscrew-base-bar-clamp_2off.par | 1 | 2 | RP |
z-leadscrew-base_2off.par | 1 | 2 | RP |
624-bearing.par | 2 | 4 | Bearing |
m4-nylock.par | 2 | 4 | Fastener |
m4-washer.par | 8 | 16 | Fastener |
m4x40-cap.par | 4 | 8 | Fastener |
m5-mudguard-washer.par | 2 | 4 | Fastener |
RP parts
Assembly
Leadscrew base with optoswitch
One of the leadscrew bases needs an optoswitch.
BOM
Total # of assemblies: 1
Optoswitch PCB | 1 | 1 | PCB |
z-opto-bracket_1off | 1 | 1 | RP |
Spring | 1 | 1 | Spring |
m4-nut.par | 1 | 1 | Fastener |
m4-washer.par | 1 | 1 | Fastener |
m4x40-cap.par | 1 | 1 | Fastener |
m3-capx20.par | 2 | 2 | Fastener |
m3-nylock.par | 2 | 2 | Fastener |
m3-washer.par | 4 | 4 | Fastener |
Printed parts
Assembly
Slot the nut into the hexagonal cavity between the two bearings (underside in view). Use a spring along the length of the M4x40 bolt to keep the opto-elevated from the top surface of the leadscrew bracket.
Motor bracket
BOM
Total # of assemblies:1
drive-pulley_3off.par | 1 | 1 | RP |
z-motor-bracket_1off.par | 1 | 1 | RP |
m3-capx20.par | 4 | 4 | Fastener |
stepper-motor-nema17-fl42sth47-1684A-01.par | 1 | 1 | Motor |
Printed parts
Assembly
Tensioner
BOM
Total # of assemblies 1
z-tensioner_1off.par | 1 | 1 | RP |
624-bearing.par | 1 | 1 | Bearing |
m4-nylock.par | 1 | 1 | Fastener |
m4-washer.par | 3 | 3 | Fastener |
m5-mudguard-washer.par | 1 | 1 | Fastener |
Printed parts
Assembly
Lead-screw
BOM
stud-z-leadscrew.par | 1 | 2 | Studding |
z-drive-pulley-rim_4off.par | 2 | 4 | RP |
z-driven-pulley_2off.par | 1 | 2 | RP |
608-bearing.par | 1 | 2 | Bearing |
m8-nut.par | 3 | 6 | Fastener |
m8-washer.par | 6 | 12 | Fastener |
Printed parts
Assembly
Loosely load the lead-screw (1) to ensure studding comes flush with lower nut. Tighten the two nuts which surround the bearing. Remove the lower parts (2) and store - these will be re-assembled later.
Back to Mendel mechanical construction root.
