Mendel parts more info
Revision as of 03:45, 20 September 2011 by RhysJones (talk | contribs) (Undo revision 41972 by Wangmingjun123m (Talk))
Part Name Qty Needed Image Description
The text has 10433 lines and a size of 342.0 KB.
The total build time is 585 s =~ 9 min.
The total distance extruded is 8721.9 mm.
The total distance traveled is 9356.3 mm.
The version is 2009-10-14
The volume extruded is 1.71 cc.
The text has 17300 lines and a size of 569.0 KB.
The total build time is 668 s =~ 11 min.
The total distance extruded is 6211.4 mm.
The total distance traveled is 10658.3 mm.
The volume extruded is 1.22 cc.
The text has 22620 lines and a size of 698.0 KB.
The total build time is 2976 s =~ 50 min.
The total distance extruded is 37781.3 mm.
The total distance traveled is 47601.7 mm.
The volume extruded is 7.42 cc.
The text has 3538 lines and a size of 103.0 KB.
The total build time is 299 s =~ 5 min.
The total distance extruded is 4082.3 mm.
The total distance traveled is 4781.7 mm.
The volume extruded is 0.802 cc.
The text has 12258 lines and a size of 378.0 KB.
The total build time is 646 s =~ 11 min.
The total distance extruded is 7789.6 mm.
The total distance traveled is 10337.0 mm.
The volume extruded is 1.53 cc.
The text has 15921 lines and a size of 476.0 KB.
The total build time is 881 s =~ 15 min.
The total distance extruded is 11099.7 mm.
The total distance traveled is 14093.0 mm.
The volume extruded is 2.18 cc.
The text has 21041 lines and a size of 671.0 KB.
The total build time is 614 s =~ 10 min.
The total distance extruded is 7926.6 mm.
The total distance traveled is 9659.4 mm.
The volume extruded is 1.56 cc.
The text has 62975 lines and a size of 1932.0 KB.
The total build time is 7203 s =~ 2h.
The total distance extruded is 84878.7 mm.
The total distance traveled is 115149.4 mm.
The volume extruded is 16.7 cc.
The text has 44410 lines and a size of 1414.0 KB.
The total build time is 3233 s =~ 54min.
The total distance extruded is 37793.4 mm.
The total distance traveled is 51695.4 mm.
The text has 11871 lines and a size of 345.0 KB.
The total build time is 860 s =~ 15min.
The total distance extruded is 9918.2 mm.
The total distance traveled is 13720.7 mm.
The volume extruded is 1.95 cc.
The text has 11622 lines and a size of 339.0 KB.
The total build time is 823 s =~ 14min.
The total distance extruded is 9875.7 mm.
The total distance traveled is 13117.2 mm.
The volume extruded is 1.94 cc.
The text has 12015 lines and a size of 337.0 KB.
The total build time is 1130 s =~ 20min.
The total distance extruded is 13242.0 mm.
The total distance traveled is 18085.3 mm.
The volume extruded is 2.6 cc.
The text has 10400 lines and a size of 313.0 KB.
The total build time is 837 s =~ .
The total distance extruded is 10722.6 mm.
The total distance traveled is 13377.8 mm.
The volume extruded is 2.11 cc.
The text has 4080 lines and a size of 124.0 KB.
The total build time is 158 s =~ 3min.
The total distance extruded is 1739.5 mm.
The total distance traveled is 2514.5 mm.
The volume extruded is 0.342 cc.
The text has 9448 lines and a size of 279.0 KB.
The total build time is 9287 s =~ 2.5 hrs.
The volume extruded is 33 cc.
The text has 85189 lines and a size of 2681.0 KB.
The total build time is 7445 s =~ 2h.
The total distance extruded is 88393.9 mm.
The total distance traveled is 119035.3 mm.
The volume extruded is 17.4 cc.
The text has 50136 lines and a size of 1621.0 KB.
The total build time is 4578 s =~ 76min.
The total distance extruded is 61267.1 mm.
The total distance traveled is 73217.3 mm.
The volume extruded is 12.0 cc.
The text has 28534 lines and a size of 871.0 KB.
The total build time is 2482 s =~ 41min.
The total distance extruded is 30420.2 mm.
The total distance traveled is 39669.8 mm.
The volume extruded is 5.97 cc.
The text has 13941 lines and a size of 452.0 KB.
The total build time is 454 s =~ 8min.
The total distance extruded is 6462.0 mm.
The total distance traveled is 7245.7 mm.
The volume extruded is 1.27 cc.
The text has 13478 lines and a size of 412.0 KB.
The total build time is 878 s =~ 15.
The total distance extruded is 10189.6 mm.
The total distance traveled is 14035.9 mm.
The volume extruded is 2.0 cc.
The text has 40815 lines and a size of 1283.0 KB.
The total build time is 2911 s =~ 49min.
The total distance extruded is 37384.8 mm.
The total distance traveled is 46543.8 mm.
The volume extruded is 7.34 cc.
The text has 27306 lines and a size of 835.0 KB.
The total build time is 1855 s =~ 31min.
The total distance extruded is 23531.0 mm.
The total distance traveled is 29664.2 mm.
The volume extruded is 4.62 cc.
The text has 23864 lines and a size of 723.0 KB.
The total build time is 1321 s =~ 22min.
The total distance extruded is 15708.3 mm.
The total distance traveled is 21128.8 mm.
The volume extruded is 3.08 cc.
The text has 17425 lines and a size of 522.0 KB.
The total build time is 1770 s =~ 30min.
The total distance extruded is 22096.1 mm.
The total distance traveled is 28277.1 mm.
The volume extruded is 4.34 cc.
The text has 20333 lines and a size of 604.0 KB.
The total build time is 2240 s =~ 37min.
The total distance extruded is 27347.9 mm.
The total distance traveled is 35782.8 mm.
The volume extruded is 5.37 cc.
The text has 20452 lines and a size of 605.0 KB.
The total build time is 2170 s =~ 36min.
The total distance extruded is 27761.5 mm.
The total distance traveled is 34677.6 mm.
The volume extruded is 5.45 cc.
The text has 34932 lines and a size of 1076.0 KB.
The total build time is 3513 s =~ 1h.
The total distance extruded is 42829.7 mm.
The total distance traveled is 56159.9 mm.
The volume extruded is 8.41 cc.
The text has 38830 lines and a size of 1188.0 KB.
The total build time is 3954 s =~ 1h 6min.
The total distance extruded is 48122.1 mm.
The total distance traveled is 63204.2 mm.
The volume extruded is 9.45 cc.
The text has 39149 lines and a size of 1200.0 KB.
The total build time is 3917 s =~ 1h 5min.
The total distance extruded is 48122.9 mm.
The total distance traveled is 62637.3 mm.
The text has 7158 lines and a size of 212.0 KB.
The total build time is 480 s =~ 8min.
The total distance extruded is 6338.6 mm.
The total distance traveled is 7675.0 mm.
The volume extruded is 1.24 cc.
The text has 39228 lines and a size of 1221.0 KB.
The total build time is 4139 s =~ 1h 9min.
The total distance extruded is 52310.9 mm.
The total distance traveled is 66224.6 mm.
The volume extruded is 10.3 cc.
The text has 76041 lines and a size of 2341.0 KB.
The total build time is 8929 s =~ 2h 30min.
The total distance extruded is 114359.9 mm.
The total distance traveled is 142741.3 mm.
The volume extruded is 22.5 cc.
The text has 22671 lines and a size of 687.0 KB.
The total build time is 1938 s =~ 32min.
The total distance extruded is 24932.5 mm.
The total distance traveled is 30990.1 mm.
The volume extruded is 4.9 cc.
The text has 10497 lines and a size of 344.0 KB.
The total build time is 668 s =~ 12min.
The total distance extruded is 9695.6 mm.
The total distance traveled is 10669.6 mm.
The volume extruded is 1.9 cc.
The text has 1159 lines and a size of 36.0 KB.
The total build time is 187 s =~ 3min.
The total distance extruded is 2779.3 mm.
The total distance traveled is 2993.8 mm.
The volume extruded is 0.546 cc.
The text has 86163 lines and a size of 2679.0 KB.
The total build time is 12144 s =~ 3h 20min.
The total distance extruded is 154045.5 mm.
The total distance traveled is 194191.2 mm.
The volume extruded is 30.2 cc.
The text has 19900 lines and a size of 597.0 KB.
The total build time is 1532 s =~ 25min.
The total distance extruded is 19653.5 mm.
The total distance traveled is 24470.4 mm.
The volume extruded is 3.86 cc.
The text has 59060 lines and a size of 1817.0 KB.
The total build time is 8873 s =~ 2h 30min.
The total distance extruded is 111791.3 mm.
The total distance traveled is 141882.2 mm.
The volume extruded is 22.0 cc.
The text has 9249 lines and a size of 285.0 KB.
The total build time is 567 s =~ 10 min.
The total distance extruded is 7259.3 mm.
The total distance traveled is 9059.4 mm.
The volume extruded is 1.43 cc.
The text has 43638 lines and a size of 1311.0 KB.
The total build time is 7378 s =~ 2 h.
The total distance extruded is 95416.5 mm.
The total distance traveled is 117950.4 mm.
The volume extruded is 18.7 cc.
PLEASE NOTE: in an earlier version of the below photo, y-bearing-180_0off.par and y-bearing-360_0off.par are not needed and were shown by mistake.
