Metal deposition print head
This page is the nucleus on this wiki for development of a metal depositing print head to go along with an XYZ Cartesian robot or robot arm.
- 1 The big picture
- 2 Existing freeform fabrication processes
- 3 Proposed approaches
- 4 Summary of comparison between different approaches
- 5 Argon supply
- 6 Existing open freeform fabrication processes or metal deposition heads
- 7 Deposition speed
- 8 Fixturing
- 9 Support structures
- 10 General information on welding
- 11 feedback
- 12 stress and strain
- 13 more research starting august 22
- 14 Summary of current state of research
The big picture
Machines are the main physical tools that allow material wealth creation. Good machines require precisely shaped metal parts, made to dimensional tolerances in the 10-30 micron range (roughly).
The MetalicaRap is moving forwards but there are many roads to glory :). Another particularly interesting and promising method is to form the metal object roughly and slightly oversized (near net shape) using a solid freeform fabrication method, and then machine the surfaces of the part that must be precisely shaped using a traditional subtractive method like EDM or milling, either after or during freeform fabrication.
While there do not seem to be any open precision cnc milling or EDM machines, the know how to make them is widely available, so a serviceably precise Open EDM or milling machine can certainly be made. Development of a suitable open freeform fabrication method suitable will enable the aforementioned type of printer.
Such a machine would be relatively easy to have largely self replicating because it can print precision metal parts like a leadscrew, gears, linear journal bearings and fittings as well as snap together structural members, which is the bulk of the mechanical and structural components of such a machine. It could also print most of the parts for a Lister engine, hammer drill, a car (if the print volume was big enough), refrigerator etc.
Secondly, such a printer would probably have to already print in 2 different materials at least: a support material and a metal. Then, you could add an FDM head to the printer, allowing plastics to be printed onto the metal part as it is being made (within limits of not being exposed to excess heat). You would then have a multimaterial printer that could print the parts for even more of a car etc. Additional heads could be added like a head that deposited ceramic with the use of a diode laser, allowing you to produce parts mostly finished (including windings) for a stepper motor, most of an alternator, etc. Speed could be increased simply with multiple heads.
See Comprehensive_search_for_full_strength_material_printers#Additive_processes_that_might_be_adaptable_to_printing See also the existing printer sections in that document. Ultrasonic consolidation is another particularly interesting one.
Proposed approaches
See http://en.wikipedia.org/wiki/List_of_welding_processes . Essentially we are adding a small bit of metal to a much larger bit, ideally consolidating it into a perfectly contiguous mass, which is very similar to welding with filler, so that is what most processes will draw on.
There is so called "micro welding" which involves units that may be a suitable size. They might be adapted as a convenient starting point for the gun or power supply etc.
Methods of adding material indiscriminately like metal vapor deposition or Chemical Vapor Deposition or plasma sputtering could also be used and then followed by subtractive machining.
Wire and induction heating
Wire as a feedstock is a handy way to go, easy to transport and, for the prototyping process easier to buy and handle. Under atmospheric pressure argon.
Primer for uninitiated: Remember current is induced in such a way that it produces a field that counteracts the changes in the primary magnetic field. In the diagram of magnetic field lines, with the higher density of magnetic field lines indicates the areas that are heated more. The higher the frequency, the less the heating tends to penetrate the surface of the inductively heated metal.
Induction heating could either use a plain, rod shaped air core solenoid or non conductive ferrite core magnet, with one pole of the magnet close to the metal surface, and modulated at relatively high frequency (10s of khz) to achieve an annular shaped heating area on the surface of a metal object (the melt pool).
Another way which could give a more uniform, circular heated area could be to have the magnetic field enter the surface over a small area and exit over a large area. Heating occurs at a useful intensity at the small pole and the magnetic circuit is closed a bit better which helps increase coupling into the pool. The coil could be water cooled.
The surrounding area could also be pre-heated with radiant heating using a nichrome or, since it is argon atmosphere, tungsten element, or the melt pool could be assisted a bit (how much? What sort of energy flux do we need here for various sized melt pools?).
Resistive heating
Arc
Try to basically scale down and make open one of the freeform fabrication ones methods that use wire under argon, or another arc welding method. Remember precision is not critical since there will be a machining step later. There is a purely resistive, sans arc method listed lower down in a patent.
Electron beam
Electron beam welding, basically. See documents at the main page on existing processes; nasa simply adapted a purchased electron beam welding system to use as a freeform fabricator.
The main problem is that electron beam welding systems used a vacuum of 1x 10-4 torr. While making a chamber for that level is doable, everything inside has to be compatible with that vacuum level too. Sensors, electronics, motors, lubricants, all become harder to integrate with the system inside the chamber when desirable, as buying off the shelf units specially made for high vacuum is probably very expensive.
Luckily in practice new solutions have been found; over sized normal electric motors have been found to function for 6 months at a time until heat dissipation issues get them, out gassing happens to some extent but it has been overcome by pumping. The high voltage electrical feed through s have now effectively been replaced by cheap glass test tubes in compression vacuum fittings with viton O ring seals. The low voltage electrical feedthroughs have been replaced by spark-plugs welded on the chamber. As an unfocused beam is possible at 1x 10-3 torr which can be achieved by a two stage roughing pump, and that this beam can melt titanium so creating a electron beam titanium sublimation pump so avoiding the need for the expensive high vacuum turbo pump. The power supply use to have large expensive high voltage ladders full of high voltage specialist capacitors and diodes but now has been replaced by 200Khz switch mode power supplies driving a tower of 200 printed circuit board secondaries coils with standard/cheap 300V capacitors acting as voltage double's and fast but cheap 150V rectifying diodes rectifying the high frequency pulse width modulated supply. So the process of making our own versions has come some way but is still to be proven.
However strictly speaking only the electron gun itself needs to be under a high vacuum. There are many electron beam welding rigs that use low vacuum chambers and under normal atmospheric pressure (would still have to be argon though). Either a plasma window or even just a suitable arrangement of powerful pumps and narrow constrictions filled with gas is enough to keep the inside of the gun a vacuum while getting the electron beam out. A thin material though which the beam passes would not work in powerful 10's of KW commercial systems due to the inability to cool the window effectively, but luckily would work for home sub kW systems. Water cooled very narrow metal foil slot windows would work but demand the build table rotation(rotating windows with vacuum seals are practically very tricky), luckily stationary high tech blind hole perforated mica windows would work without the need to rotate the build platform , at a reasonably high cost.
NASA probably chose to use high vacuum in the entire chamber and avoid plasma windows as the windows would have; limited the power too much , or been too small 100µ across so demanding window movement that was too practically too difficult, also as they planned to also use the system in space, where their is no shortage of vacuum and so out gassing is no problem what so ever for them!
We could use the same gun as the MetalicaRap or a smaller one.[1]
Ultimately the main benefit of electron beam for our purposes is precision control of the energy into the melt pool and 7 times the efficiency of the energy entering the metal compared with the laser energy reflection, thus enabling fast enough printing on a single phase supply for the home setting for most common metals.
(Single phase home full strength metal part laser printing will be limited to part volumes of approx 9cm cubed, taking approx 2 days to print ( except in the case of steel which absorbs laser as effectively as electron beam).
The SMD and PTA FFF methods supposedly get full strength so it might not have much advantage but be more complex and expensive to prototype.
I think we should steer clear of the high vacuum approaches anyway for this particular project, because of the cost and difficulty of prototyping and working with high vacuum. I think further research on the support materials will tell which is the best, but I am leaning towards induction if enough power can be coupled to the melt pool that way. GreenAtol 00:00, 14 August 2011 (UTC)
Argon supply
As mentioned in the reprap forum, Argon can be extracted from the air at a small scale economically and with relatively non expensive or complex machinery. So the cost or difficulty of obtaining Argon as a consumable is probably not a major issue ultimately, just the electricity cost. The documentation on the commercial FFF processes indicates high purity argon is desirable, (99.99%) and that 10 volumes of gas exchange in the chamber is typically needed to achieve good metallurgy. But even high purity Argon does not look too hard to make at a small scale. Seems unlikely that even if they start with 99.99% argon that the purity actually in the chamber after 10 exchanges will be near that, maybe though. Successive division operations can add (multiply) up pretty fast. Laminar flow rather than dilution flow in the chamber must be employed most likely.
Approaches include, may need to be combined or repeated for high purity:
- Pressure swing adsorption.
- Membrane separation (maybe with reverse osmosis membranes?)
- Fractionation of air.
There are none known as far as I can tell right now.GreenAtol 00:11, 14 August 2011 (UTC)
Deposition speed
Obviously faster is better. However using thicker wire and more heat in the melt pool has limits and might have serious tradeoffs at some point. Using a row of identical deposition heads might be better. An array another step better still, as material could be deposited in a large number of places. An array of say 5 by 5 heads could be fixed relative to each other, and the motion required of the array to bring all the heads over the relevant points where material needs to be deposited could be either a scanning, raster approach, or there could be some performance enhancement possible using more complex motions that would be computed for each metal deposition layer. The melt pools could be sufficiently separated that they do not effect each other normally.
Fixturing
EDM is a nearly force free method. But milling entails significant force, though you can reduce the amount by moving the mill head more slowly.
So the object being fabricated needs to be firmly affixed to the rest of the printer somehow, the firmer the better. This is closely related to the support structure strategy. Options include, and these could be combined:
- Have the bottom of the first print layer of metal stick to a ceramic baseplate, but not so much that it is impractical to remove. Could be removed by breaking the bond by differential thermal expansion or maybe just a good stiff whack. Limitations:
- When the object first starts it's contact area with the base is small so it is poorly attached. Might have to be extra gentle with any milling, and/or maybe the process can be controlled to control the strength of the bond.
- If the first print layer only touches the bottom of the chamber at a point or line you are probably out of luck, would have to use the support material approach along with in situ casting (see support section.)
- The support material could be laid down in a single layer first as a sort of glue layer, if it had the right properties (has to stick to both metal and bottom of the print chamber of course and be adequately strong and temperature resistant WRT not burning and preferably not distorting (e.g. by melting) when the molten metal is deposited onto it). As the part is build up, the support material can be built up too, so it continues to provide a solid, rigid connection to the base. The corners of the build chamber could have vertical attachment points too, without interfering with the cartesian robot, which the support material can brace against. There may be a large amount of support material, if it can be reused in subsequent printings might as well go to town an fill any volume not filled with print metal with support material to provide quite solid support.
- See support structure section.
- There could be rods or pegs or wire sticking up from the base of the print chamber. Could be the same material as the print material. The metal could be deposited starting with welding it to the wire. Would provide grounding too for processes that require it.
- Could either be 3 in a triangle shape and hold the object down just by being support pillars and through their own rigidity.
- Could be only a single or 2 wires or pegs. The first bit of metal laid is welded to it/them, and then they are pulled downwards forcibly. This holds the object against the print chamber bottom and can continue to as the object grows if the support material surrounds it (or it supports it's self against the bottom of the chamber due to it's geometry of course). This could be combined well with the sticking to the bottom and corners of the chamber.
- removing the pegs could be done by machining, or if the dimensioning is not critical there could be just a small mechanism built in to the printer base that cuts through the rod or wire, releasing the part. More wire or rod could then be fed up, and the printer can start a new cycle without manual intervention.
Support structures
- main page: support structures for metal deposition
Support structures perform the following functions/should have the following properties for the printers we are talking about here:
- brace long thin vertical shafts and walls and parts that are not otherwise braced against the base of the print chamber (like the tip of the coat hanger hook before connected to the rest of the hanger, a leader) against the milling forces. This sort of entails being able to stick to the metal reasonably well and also be reasonably strong.
- damp vibrations from the mill in long thin shafts and walls and floating points, again needs strength and stick
- Act as a sort of in situ cast
- structures are easy to remove, preferably completely and not damage the surface.
- structures are manageable cost. Support Material may be recycled in many cases probably.
See support structures for metal deposition for more details.
There is available on the web free copies of the book "Principles of welding: processes, physics, chemistry and metallurgy" which is pretty good. There is also "materials science and engineering callister" available, which has more information on welding and the materials science involved.
Finite element analysis/simulation of the weld process we are thinking of would be a good idea to see what sort of residual stresses and distortion is involved if we can get access to the software tools for it, although the commercial processes like LENS do not seem to have a problem with it and use melt pools of what are probably comparable size compared with what we are likely to.
The main difference though is that if the machining is to be done at each step distortion from the welding process after machining might be a real problem. Smaller melt pools might help, as might keeping the z axis separation between the machining plane and the metal deposition plane high, and precomputed compensation for any distortion that is expected. Ultimately ultrasonic consolidation may end up being the way to go as it is essentially distortion free.
feedback
a camera like http://www.xiris.com/products/sub-arc-viewing-camera.htm but smaller might be useful for prototyping, maybe made with a low cost camera plus filters. Feedback about melt pool temperature is not as critical when melting is done under atmospheric pressure as when under vacuum because the metal is not as prone to evaporation/boiling. A lot of information can be obtained from sensing the arc current, or by "ringing" the induction coil, etc. too so sensors per se may not be needed.
stress and strain
For the uninitiated: stress implies compression or tension in a material. Strain indicates actual flexing/distortion. So stress will cause strain because any force on an object will cause some flexing since nothing is perfectly rigid, and if you flex (strain) a part on purpose by say bending it with your hands, the strain implies that stress will appear in the object. So they always occur together and are closely linked.
For melting processes, the books on welding say substantial stress/strain is always substantial and due to both thermal expansion and change of volume when metal freezes. Stress may be relieved by heat treatment. Ultimately probably not a problem if you only wanted near net shape parts, but in out case we want finished parts so the amount by which the object is distorted *after machining* matters a lot. ,
Things may be reduced in severity by using smaller melt pool, and also by increasing the distance between the material addition zone and the final machining zone, keeping the entire object very hot during printing (reduces relative amount of expansion but then shape changes occur during cooling after printing) and maybe other means (use cold gas to get the heat out of the ibject as soon as possible after it leaves the melt pool?).
Solid welding processes don't have the problem nearly as badly since no melting/freezing and usually lower temperatures (especially ultrasonic).
Plasma or vapor deposition may be another low distortion material addition method
Stresses produced during melt deposition
Melt deposition has many advantages in terms of speed and the ability to deposit any alloy with full strength and other good material properties, but the thermal distortion is one of the main problems involved with freeform fabrication with this method. There are other metal deposition methods that might turn out to be plenty good and workable like sintering followed by CVD PVD, plasma deposition or electrochemical deposition, and the 2 cold spraying methods EM gun and gas nozzle type. Those require more research too and might turn out to be promising.
- more on trying to get low or stress free parts (need info on degree of random changes that occur with thermal cycling or just heat/cool, and also the degree of predictability and randomness (or otherwise unpredictable changes) of changes in shape during the printing processes (the various processes) )
- On computational and other prediction of distortion and stresses, need to know more about dimensional changes that occur with repeated heating and cooling so can get decentaccuracy, in investment casting the accuracy they get may be some indication of what happens during a single cooling because they can compensate the molds, but what happens if it is reheated and cooled again and again as the layers are deposited:
- http://www.mendeley.com/research/3d-dynamic-numerical-approach-temperature-thermal-stress-distributions-multilayer-laser-solid-freeform-fabrication-process-1/ interesting, computational simulation of thermal distortion and stress during laser addition of metal and comparison to the
- http://www.freepatentsonline.com/5866058.html method that anneals part as it is being made, heat it to above the cprrep point but below melting temp basically but plastic apparently , some basic info o ndistortion but may bot be the whole story as it does not factor in scan pattern etc. which we know makes a big diff , secondly does not adress the compensatability of this type of distortion which is obviously very high " Since most deposition materials change density with temperature, especially as they transition from a fluid to a solid, thermally solidifiable material rapid prototyping systems share the challenge of minimizing geometric distortions of the product prototypes that are produced by these density changes. Thermally solidifiable systems are subject to both "curl" and "plastic deformation" distortion mechanisms. Curl is manifest by a curvilinear geometric distortion which is induced into a prototype during a cooling period. The single largest contributor to such a geometric distortion (with respect to prototypes made by the current generation of rapid prototyping systems which utilize a thermally solidifiable material) is a change in density of the material as it transitions from a relatively hot flowable state to a relatively cold solid state.
For the simple case where an expansion coefficient is independent of temperature, the nature and magnitude of geometric distortion of sequentially applied planar layers can be estimated. Assume a linear thermal gradient dT/dz is present in a material when it is formed into a plate of thickness h in the z direction, and that the material has a constant thermal expansion coefficient α. The z direction is generally orthogonal to a support surface on which the plate is constructed. If the plate is subsequently allowed to come to some uniform temperature, it will distort, without applied stress, to form a cylindrical shell of radius r where: r=(α*dT/dz) -1 ( 1)
Curl C is defined as the inverse of the radius of curvature: C=1/r. An example of positive curl is shown in FIG. 1. Sequential layers of a thermoplastic material 104 are deposited on a base 102, using a moving extruder 106. As is typical in thermally solidified rapid prototypes, a series of layers are deposited sequentially in the z direction (i.e., the direction orthogonal to base 102), with the last layer deposited always having the highest temperature. Such an additive process typically results in a geometrically accurate part which contains a thermal gradient. As the part subsequently cools and becomes isothermal, the part distorts as a result of a curling of the ends of long features. "
- search: no internal residual stress
- from the EOS (DMLS system)site for the cobalt chrome material they sell to go with the printer, Stress relieving procedure:-
Stress relieving is done in a stress relieving furnace under argon atmosphere or in a vacuum furnace. The stress relieving sequence is as follows:- 1. ramp up to 650 °C in 60 minutes 2. hold for 3h 3. furnace heating power off and open the furnace door when temperature dropped down to approx. 400°C Annealing:- Specific properties can be modified by annealing the parts at various temperatures ranging from 650 to 850°C and for dwell times between 1 and 4h http://www.3trpd.co.uk/content/pdfs/ti64-titanium-alloy-eos-ti64.pdf for DMLS printed parts, does not specify precision well DMLS so would be 50-25 micron according to prior research
- search for other methods to releive stress
- on EM peening http://en.cnki.com.cn/Article_en/CJFDTOTAL-HJXB200801004.htm
- http://en.cnki.com.cn/Article_en/CJFDTOTAL-CULT200906029.htm another one
- http://www.ingentaconnect.com/content/maney/stwj/2009/00000014/00000008/art00010 another one describing the method
- http://en.cnki.com.cn/Article_en/CJFDTOTAL-SJGY200801018.htm very interesting says it redu ced stres by 90%! maybe improveable?
- http://en.cnki.com.cn/Article_en/CJFDTOTAL-HJXB200801004.htm says controls craxcking
- "shotless peening"? one is cavitation peening, don't know how that goes
- http://www.cpmfastools.com/c/79/cryogenic-processing says that cryogenic processing of some sort can help releive stress in some parts but note that is pretty picky only works to some degree and sometimes also see http://www.eos.info/en/news-events/press-releases/pressdetails/select/pressemitteilungen/article/103/cpm-fasttool.html?tx_ttnews[year]=2006&tx_ttnews[month]=10&cHash=52a3bd345a not to be confused with traiilng edge cooling methods, which cause sompressive stress in the weld area which will then become canceled out by tensile as the weld bead shrinks thermally
- any method to reduce distortion in welding there must be large number of them search for the best
- salts of metals that boil off like in liquid chemical vapor deposition, but then the deposit of salt is reduced under an h2 atmosphere, some salts might reduce at low temps, the problem might be again stresses or voids etc.
- also other methods of transferring to the surface as salts, maybe some salts decompose tat hihg tmeps or with UV etc.
- http://iospress.metapress.com/index/PG067073484410V1.pdf general stuff on stres srelief
- vibration and ultrasonic for stress reduction
- http://md1.csa.com/partners/viewrecord.php?requester=gs&collection=TRD&recid=199806551647MD&q=eliminate+welding+stress&uid=790959344&setcookie=yes Vibratory stress relieving (VSR) of components, welded or otherwise, is frequently applied as a speedy and low cost alternative to thermal stress relieving (TSR). very interesting looking try to get copy Additionally VSR has a unique role where thermal processing is not possible. There are three distinct variatns of the VSR process although only one, resonant VSR (R-VSR), consistently works across the applicable component spectrum. Its use has evolved over a 40 year period due to a succession of empirical and research led refinements. Use of R-VSR on welded fabrications is commonplace but often misapplied. In well defined areas of applications, R-VSR is 100% successful in its main objective, dimension stabilisation. With its 100:1 time saving and > 1000:1 fuel saving as against thermal stress relieving, it has great appeal. However, overzealous sales claims, particularly by US equipment manufacturers, have led to mistrust when VSR processes fail to fulfill claims to completely remove stresses, substantially increase fatigue life and refine grain structure (in the case of vibrating during welding). Independent research has shown resonant VSR to be 100% reliable if applied as directed to produce dimensional stability. The treatment of components of up to 100 tonnes is now commonplace.
- http://en.cnki.com.cn/Article_en/CJFDTOTAL-MECH200901024.htm Mechanism of the residual stress reduction in aluminum alloy welding by ultrasonic wave "the elimination of the effect could reach 38.7 percent"
- http://www.iasmirt.org/SMiRT17/J07-6.pdf low frequency, 0 to 500 hz indicates more like 30 percent at the center of the bead less at the edges, still this ocudl be used in combination with the EM peening or maybe stronger vibes would improve things , they used pretty gently shaking
- 6223974 patent Trailing edge stress relief process (TESR) for welds
uses a shaker of sorts low freq but can be ultrasonic
- search "eleimination of welding residual stress" and residual stress etc
- trailing impact roller or trailing impactive rolling
- ultrasonic impact seems very interesting, although you'd think it only applies to the surface, it appartly is used on bridges and helps a lot so must go pretty deep
- http://www.scientific.net/AMR.189-193.3625
- http://en.cnki.com.cn/Article_en/CJFDTOTAL-HJXB200504012.htm
- http://www.scientific.net/AMR.255-260.324
- http://en.cnki.com.cn/Article_en/CJFDTOTAL-GJIG200803006.htm abstract is pretty unclear
- http://www.vsrtechnology.net/wp-content/uploads/dawson-moffat.pdf"The
Librar Vibratory Stress Relief y REPRINT: VIBRATORY STRESS RELIEF: A FUNDAMENTAL STUDY OF ITS EFFECTIVENESS" Says library so migh tbe more where that came from
- http://en.cnki.com.cn/Article_en/CJFDTOTAL-ZGTK200805010.htm gives percentages of relief, can be very high for some circumsstances , why thos ean dnot others? can we get that benefit?
- http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.140.7008&rep=rep1&type=pdf. general info, physics and mechanism of ultrasonic impact treatment
- http://www-it.jwes.or.jp/proceedings/en/3-12.pdf example of ultrasonic impact ebing used plus brief explanation can use magnetostrictive so maybe not LZT better for environment no lead
- http://www.scribd.com/doc/14428134/VSR-an-Alternative-to-Thermal-Treatment interesting says treatment time 40 minutes though
- http://www.mne.psu.edu/michaleris/pubs/wj97b.pdf more on thermal stress relief, looks good for the thing "The Chinese Patent No. 87100959 and International
Patent No. PCT/GB88/00136 describe in detail the relevant apparatus for using the thermal tensioning technique to eliminate buckling distortions for butt welding of thin plates. "
- http://en.cnki.com.cn/Article_en/CJFDTOTAL-HJXB401.001.htm a method using rapid cooling somehow to reduce welding stress thin on details "New technique for dynamically controlled low stress non-distortion welding"
- http://en.cnki.com.cn/Article_en/CJFDTOTAL-HAJA199809001.htm another one on similar method apparently s
- impact roller thing http://en.cnki.com.cn/Article_en/CJFDTOTAL-JXXB200408017.htm says it is highly effective, reducing stress
- http://cat.inist.fr/?aModele=afficheN&cpsidt=1987536 ther,mal tensioning to reduse stress? doesn't sound like it relieves that mucht though
- http://en.cnki.com.cn/Article_en/CJFDTOTAL-JCYY200707079.htm general info on vibratory stress relief
- http://www.cs.cmu.edu/~rapidproto/manufacturing/mfguniversity.html bunch of protptypical methods
- that ultrasound powder feeding thing could be used to gte the powder out of a hollow object after printing too
- remember posibility of controlling welding bead shape by electromagnetics while depositing, coudl really increase precision because one of the mail sources of imprecision is the weld bead is not predictably shaped
- relieving stress in metal and other material layers
- extremely powerful ultrasound to releive stress? other ways to rleive stress or produce compressive stress to coiunteract the tensile stresses in the deposited metal layer other
- other extreme shocks waves traveling through the devicee produced by exposives etc?
- powerful em pulses?
- deposite ions with an ion beam? almost any element can be used and so the alloy could remain good composition
Okay at this point the note files I have been using have gotten very mixed up because there are issues that are often interconnected so notes are on a range of subjects. However it takes time to organize them that would be better spent on research. Don't forget to check out the other pages in the related pages section of the comprehensive search for a full strength material printer page for other pages with similar notes.
- http://en.wikipedia.org/wiki/Electroforming
- what are the stresses involved?
- what sor to alloys? probably some pretty good alloys can be made
- this coudl be used with the array of electrodes thing with the crt that mentioned perhaps if it is possible to build large objects that are low stress
- ocudl use a strong electric feild vetically to encourage ions to go straight to the surface might help to allow increased standoff distances for a given precision
- use an LCD screen or similar as the electrodes?
- what are the electrodes made of ? We cant hav ethem dissolve whereas in normal process you prbably can, maybe we could make them from glassy carbon or something
- could use stress modification techniques if there is tensile stress build up em peening, vibrational stress releive ultrasonic cavitation etc.
- coudl print a shell of high melting point metal and then fill the shell with other material
- they must have some way that is similar for the stamping things for dies made with electroformding, to give strength to the relatively thin layer
- hav eto prevent the metal from contacting the other electrode obviously, could maybe use capacitance or other measures to see how close it is toa given electrode and compensate with reduced current
- coudl be a cold deposition method for on top of plastic as an insulating layer maybe, have to coat plastic with something conductive first though coudl use electroless plating maybe
- look more into electroless plating to build up a large object too
- as mentioned in the microsintering thing, can sinter an object then deposit material electrolytically in the pores might work even if the layer has some stress, one main problem is the pores blocking themselves off might lead to porosity but maybe coudl eb solvedwell enough through some means,
- also electroless, coudl have channels built into the sintered part much like capilliaries, with electroless fluid pumped through
- also if water was left behind and trapped inside it coudl boil destroying the part but maybe coudl be removed with heating if there is even the slightest hole allowing it to escape. If there is not that could be a problem btu there would very rarely be pockets of any significant size
- http://www.emeraldinsight.com/journals.htm?issn=1355-2546&volume=16&issue=3&articleid=1858292&show=pdf EFAB thing, saw it before, uses elecgtordeposition and says it can make stuff up to centimeters in size, true or not don't know, says good material properties, not clear how they do it thouth
"Layerize exports files in GDSII format; these are then used to drive an e-beam or laser-based pattern generator, yielding a set of photomask tools that define each cross section with sub-micron resolution. The photomasks are used in the EFAB process to define the locations of selective material deposition on each layer of the device. The EFAB manufacturing process begins with a blank substrate (typically alumina) and grows devices layer-by-layer by depositing and planarizing at least two metals. One metal is structural,formingthefeatures ofthefinisheddevice. Theother metal is sacrificial, providing support during the layering process and eventually removed. Figure 7 show the layering process, involving three key steps. In Step 1, a first metal (e.g. the sacrificial metal as shown) is selectively electrodeposited onto the substrate in areas defined by the photomask, in a pattern corresponding to the first cross-section of the device. In Step 2, a second metal (e.g. the structural metal) is blanket deposited (typically by electrodeposition). The second metal covers the first metal and fills in the region where the first metal was not deposited. InStep3,thetwometalsareplanarizedviaaproprietaryprocess to form a two-material layer of precisely controlled thickness, flatness, and surface finish. These three steps are then repeated again and again until all layers have been formedand the desired device has been fully generated. Finally, the sacrificial metal is completely removed by a selective etching process, freeing the device for use. If the first layer is entirely sacrificial metal, then devices will be completely released from the substrate; this method is typically used for medical devices. However, electrically interfaced devices such as those shown in Figure 5 can also be built directly on the substrate and remain attached to it; dicing the substrate then singulates the individual “chips” for use"\
What is "planarization"? presumably a method of levellin/flattenign the surface to a known plane, but how? prpbably just http://en.wikipedia.org/wiki/Chemical-mechanical_planarization or similar http://en.wikipedia.org/wiki/Microfabrication
- how to take advantage of stress rather than avoid?
- http://www.specialtytest.com/pdf/ControllingStess.pdf good doc on info about stress in electroforming doesn't say whether they are tensile or compressive
- coudl deposit material over the finished areas to prevent further deposition, or just use moving array of electrodes maybe of various sizes so can do small features too if want to maybe no point though
- http://www.google.ca/patents?lr&vid=USPAT4786376&dq=stress%20in%20electroforming&printsec=abstract&id=xokyAAAAEBAJ&output=text&pg=PA1 patent that uses a strain gauge sensor (flexing disc type) in real time to provide feedback and thereby adjust the current to reduce stres
- http://www.google.ca/patents?lr&vid=USPAT3374154&dq=stress%20in%20electroforming&printsec=abstract&id=wYxrAAAAEBAJ&output=text&pg=PA1 says can vary from tensile to compressive stress and the method allows control to within 1000 psi of 0 stress (15 psi ia 100 kpa or so so 6.6 mpa),
- http://www.nicoform.com/files/upload/upload/20/FastandAccurateTalk.pdf. Page 1
Fast and Accurate Deposit Internal Stress Determination on the double disc sensor thing, maybe 2 of them coudl be used together to provide real time montioring, also says some guidelines recomendations for the stress level in deposits that need high precision, optical is 5 mpa , so with methods like the ones in the patents above maybe could do more. Welding would have higher internal stresses than that probably, remember the thermal stress docs were saying hundred MPa range.
- so basically looks like just need some reasonably economical and tough metal alloys that can be deposited and a method to ensure the stress is tightly controlled in real time, an then the electrode array, maintain suitable spacing and that may wel lmake a good FFF method either to use with another method or to produce parts off the bat with all metal electrodeposited. Low temperature high strenght alloys like that zinc alloy stuff found in cars the multmachine people like coudl be used to do bulk filling, or even coudl be done just by printing a shell, heating everything up to a temp suitable for casting with low distortion(right below the melting point of the metal which is to be added) and putting the metal in the hollow shell.
- need to check speed at which low stress material can be deposited
- could use it as a bulk metal deposition method, simply mask off areas that you want to stop growing somehow, has to be done under water though. Can also print up a "cast" of sorts which will be filled with electodeposited metal
- important:method of low temperature low stressmetal deposition
- leaders would be a bit of a problem, maybe a conductive polymer coudl be used somehow, have it wired in so it can be swiched to ground or left floating, then ground it when you want deposition to start? Or just print a very thin shaft and surround it with the support/maskin/casting material for the very little bit of mechanical support it would need
- problem: looks like deposition rates are extremely slow in the microns per minute range http://www.finishing.com/286/95.shtml maybe could still be used with a printed mandrel though.
- coudl use inkjet with water soluble stuff and milling or really anything that makes a removeable mandres, electroless plate just a bit of stuff in a supe thin layer or evaporatively deposit (shoudl work on nearly any object or material surface) and then electrodeposit to a millimeter or two and then remove mandrel, clean, put in high temp chamber, heat , pour casting material in. Electrformed stuff has to be higher temp thatn the casting stuff and thermal expansion coeffs reasonably similar though.
- for very certain complex parts coudl have the thermal chamber a vacuum, then pour the metal in at he highest point until it is full, that way the metal can flow everywhere without gas gettin in the way
- http://utwired.utexas.edu/lff/symposium/proceedingsArchive/pubs/Manuscripts/1999/1999-093-Yang.pdf. uses the electroformed mandrel plus castin gapproach reports on accuracy no tclear from the no images version but looks like some issues with their particular method but has promise
- http://www.google.ca/patents?id=7Z8JAAAAEBAJ&printsec=description&zoom=4&output=text 6457629 a mehtod of multimaterial fabricaton using ultrasonic joinin of different materials "More recently, nickel vapor deposition has been employed as a means of producing nickel shells for net shape fabrication applications. Nickel vapor deposition (NVD) allows thicker shells to be produced as deposition rates are higher than electroforming (Milinkovic, 1995). However, NVD involves the use of highly toxic gases and a specialized reaction chamber. The cost and risk of this technology are both very high. " proabbly nickel carbonyl, laser heating maybe.
- interesting, describes putting a rod of material down to the surface and rotating it to add a layer of material, probably messes up the material properties thouh?important: low stress maybe low heat input method of deposition but looks like is not particularly low temperature as the temp gets to 0.7 to 0.9 of the melting point
- Maybe carbonyls coudl be used effectively as a bulk deposition method in combination with inkjet masking/partialsequential layer casting it coudl be used with masking, the heatin gmethod probably does not have to be that intense, maybe coudl be used with halogen lamp as super broght projector etc.?
- http://www.webermfg.ca/nvdadvantages.shtml important: says is virtually stress free!
- melting point of pure nickel is too close to that of steel though , maybe other materials that are depositable with carbonyl? Still coudl be used with lower temp alloys for bulk strength.
- maybe can use magnetostrictive actuator for ultrasonic consolidation more fabricatiable coudl get the actuator from an old ultasonic impact (peening) gun maybe , go back and have a look at those papers on the material properties of the stuff with ultrasonic consolidation
- http://utwired.engr.utexas.edu/lff/symposium/proceedingsArchive/pubs/Manuscripts/2004/2004-01-Rosen.pdf one of those general roundup papers but looks liek a fairly good one, regarding combos of additive/subrtactive (hybrid) apparently sort of contradicts itself on that and nto really clear
- more on thermal disortion and residual internally equilibriated stresses
- http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.11.7346&rep=rep1&type=pdf good one is a thesis long and detailed
- http://utwired.engr.utexas.edu/lff/symposium/proceedingsArchive/pubs/Manuscripts/1999/1999-084-Link.pdf. novel method to reduce stress and distortion in metals but may only work adequately with the material they are using which is tool steel, or require neew details for process parameteres for other materials sitll interesting reduced or -eliminated- stresses in a beam - needs a lot of process control, and the changes may be hard to keep as further layers are added
- obviously these types of changes in crystal structure have implications for low predicatbility dimensional changes in a hybdrid method as the volume of a layer that is melted and then cooled again may be signifcantly different each time depending on the cooling rates etc.
- Optimization of the thermal tensioning process for minimum residual stress and distortion http://md1.csa.com/partners/viewrecord.php?requester=gs&collection=TRD&recid=199912552499MD&q=residual+stress+%2Beliminate+welding&uid=790959344&setcookie=yes (1) thermal tensioning with localized heating produces welds with negligible residual stress at the critical locations. Such panels will have no buckling distortion important stress reduction method although mentioned elsewhere too this on esays they get to negligible residual stress and sounds like a good paper too
- Several techniques have been proposed in the literature to reduce or even eliminate buckling distortion. A number of these, referred to as Low Stress No Distortion (LSND) welding techniques, uses additional heating and/or cooling sources, which are applied during welding. http://www.narcis.nl/publication/RecordID/oai:tudelft.nl:uuid:65f45557-a4b6-430d-9774-14c9dbc17480/Language/en
One specific technique, referred to as Dynamically Controlled Low Stress No Distortion (DC-LSND) welding, was introduced by Guan et al. in 1993 and uses a localised cooling source, which trails the welding heat source at a short distance. Although the results produced are promising, the stress reduction mechanisms are still not fully understood. In this work, the three main fields of interest for the DC-LSND welding process, namely the thermal field, the residual stress field, and the buckling distortion, were investigated by means of conceptual, analytical and finite element models, and by experimental techniques, including thermocouple measurements, (synchrotron) X-ray residual stress measurements, residual deformation measurements, and microstructural evaluation. The combination of modelling and experimental work has provided valuable insight into the process of welding with a trailing heat sink. says it is open acess but don't seem to be able to download acopy
- http://www.mne.psu.edu/michaleris/pubs/wj97b.pdf FINITE ELEMENT ANALYSIS OF THERMAL TENSIONING TECHNIQUES
MITIGATING WELD BUCKLING DISTORTION very interesting
- http://utwired.utexas.edu/lff/symposium/proceedingsArchive/pubs/Manuscripts/1997/1997-14-Klingeil.pdf Measurement of Residual Stresses in Parts Created by
Shape Deposition Manufacturing probably already saw this and it is probably included above but searched and could not fidn it
- A process is described in which a weld is produced without residual stresses; or with residual stresses reduced to a low value. Stress cycles of low value at low frequency are applied in the longitudinal direction of the weld by means of an air operated vibrator during welding. http://www.google.ca/patents?lr&vid=USPAT4386727&dq=residual%20stress%20%2Beliminate%20welding&printsec=abstract&id=TCQ4AAAAEBAJ&output=text&pg=PA1 4386727
- http://www.industrial-lasers.com/articles/print/volume-17/issue-5/features/cryogenic-weld-cooling.html use of dry ice basically to cool the trailin gendge of hte weld apparently greatly reduces distortion, not clear exactly how though To assess the cooling impact some thermal field measurements were made using a thermal imaging camera. The thermal profile of a weld is typified by a long "comet" like heat trail, which reflects the relatively slow cooling rate achieved from self-quench conduction and ambient radiation. However, the results revealed the effectiveness of the CO2 as a cooling medium. The truncation of the heat trail of the weld by the CO2 can be seen to be complete and almost instantaneous. Temperatures of more than 700°C are reduced to <100°C over a distance of about 6 mm, which corresponds to the width of the cooling jet (see Figure 3). Interestingly, the thermal profile and the temperature gradient in the actual molten weld zone remain unaltered, implying that the forced cooling does not significantly affect the actual welding process in terms of the solidification of the weld pool.
- http://www.pulsepuddle.com/ claims 90% less cracking and distortion but compared to what not clear looks like cold dip welding sort of thing and a pretty shady company
- http://www.sciencedirect.com/science/article/pii/S0007850607622963 Benchmarking of Rapid Prototyping Techniques in Terms of Dimensional Accuracy and Surface Finish
- mats allow machining more easoily and solve grounding maybe?
- what about some sort of high precision investment casting thing? done under vacuum say? Have the casting material made from 2 different materials that can be mixed and matchded to match the coefficeint of thermal expansion to the part being made. Make the cast, heat it to the melting point under vacuum perhaps then add it. (High Temperature Metal Casting ?)
- had a look and coulnd't find anything on highly precise casting, 80 microns for premium investment casting that's it.
- ultimately the problem with the cast them machine approach is taht you can't always reach in tthere to do machining expecially with a mill, so you would need part specific tooling. Theoretically maybe a mill head tha was very small and very accurate on a robot arm maybe with a wide range of attachments and milling bits and maybe micro milling attachments or something could be the next best thing
- absolute positioning, xray or gamma (radioactive material but not scalable so no)
- brace against swrokpeice ot the base
- heavy on the comuputation extremely heavy even maybe. Mioght need extra computatioin hardware a GPU or even multiple, etc
.*****could be edm maybe or similar after investement casting, 80 microns is not much to remove and get good surface finish
- could havae a mini microrobot or maybe many of them that do the EDM work attached to workpeice by suction, just a thin cable leading to each of htem, positionin gis the main problem though maybe they coudl get enough info from the surrounding geometry? A probe that does the positioning from could work, as long as the bot can see the probe maybe, or maybe arm based encoders, would agian limit reach. Ultimately the most important parts to machine are bearing surfaces so probably reachable. Plus anything that is made with conventional methods is machineable relatively easily and that is the real goal anyway.
- the main thing is user intervention and knowledge needed, and speed, and indivisable cost
- machinists always seem to say otherwise bitut it seems clear that the first 2 should be soluble even for conventional machining as long as people share their experiences and results and dimensional feedback is possible there shoul dbe no problem.
- one problem with machining is the various bits etc that you need, also collissions, but collisions can be avoided almost absolutely by improved automation. You coudl make your own cobalt or hss bits and maybe with a grinding bit for the mill and some preceramic polymer or similar silicon carbide and other bits? but this is going down the conventional road again with a different way to do everything and a different tool for each job. Still if it worked it works. Need to focus on the end performance that is being obtained .
- with precomputation maybe it is possible to improve on the precision of investment casting, also with vacuum and special cast materials?
- Even if not, could deposit nickel on the inside of a cast by nvd or electro, then pour the metal in and even though the nickel shell would melt or not be strong enough that is manageable. Thermal distortions would probably still occur though, but unpredictably and to what degree is the question, als ohetting the nickel to physically stick to the cast might help hold it in place
- 0.02620741394208896607141661280442 http://www.crnano.org/Nanofactory.pdf interesting doc o n nanofactoories, size of water molecule 18 grams water so a cube 2.6 cm on a side 6.2 x 10^23 atoms so maybe 4.2 x 10^-11 meters wide or so 50 th on a nanometer
- maybe more research needed for precision ceramic forming and also coating and bonding to metal, plastics not really a problem probably.
- had a look at the doumanidis doc on strength of ultrasonic consolidation and apparently it is nearly perfect so that's good and so it might be hihgly useful, but the pressures it needs to exert agains the rest of the object is still a problem, maybe very small blocks or bonding areas can be used (large number at once though) or there are ways to reduce the amount of force (check how muchit was again , 400 newtons over 4 mm diameter spot I think)
- http://www.google.ca/patents?lr&vid=USPAT7378622&dq=electromagnetic%20peening&printsec=abstract&id=DlGsAAAAEBAJ&output=text&pg=PA1 elecctromagnetic peening 7378622
- http://gram.eng.uci.edu/~melissao/journal/alum_trans.pdf. Molten Aluminum Micro-Droplet Formation and Deposition for
Advanced Manufacturing Applications capillary stream of liquid metal dropped onto the object, does not seem to adress stress though
Control of residual stresses in shape deposition manufacturing find it maybve also Control of Residual Thermal Stresses in Shape Deposition Manufacturing
- http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.11.7346&rep=rep1&type=pdf ANALYSIS OF THERMAL STRESSES
IN SHAPE DEPOSITION MANUFACTURING OF METAL PARTS very interesting thesis on the stresses including prediction of it
- thermal deposition, internal
residual stresses build up as each new layer is deposit- ed due to differential contraction and thermal gra- dients between the freshly deposited molten materi- al and the previously solidified layer. Individual lay- ers can be shot-peened at a peening station to con- trol the build up of stress. http://www.ices.cmu.edu/thrusts/edrc/flyers/shape.pdf
- maybe ask the authors how long it too k them when have time to do the various FEM analysis esp te SDM thermal stresses thesis one and what hardware they used, just to see if practical to predict and compensate
- obtain ABACUS or similar FEM software and learn to use it
- http://www.sciencedirect.com/science/article/pii/S0257897203002500 says plasma spray with full density?? probably exaggeration
- http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.11.8064&rep=rep1&type=pdf. kind of interesting didn't really read, invar and TiC as low CTE material for laser deposition to overcome thermal stress
- lookup ballistic particle manufacturing again
- http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.12.1135&rep=rep1&type=pdf print the mold, them mold stuff, what precision do they get?
- http://www.sciencedirect.com/science/article/pii/S0924013607003974 interesting for machinign, machine, then measure the surface you got, then machine again allows much less precise machine tools plus you want to be able to measure the surface anyway, goes to show some of hte promise for more dependence on computation and measurement and less on rigidity etc. An alternate approach to free-form surface fabrication Surface milling and grinding are widely used for the fabrication of free-form surfaces for molds and dies. The continuous demand for better product quality has led to demand in higher surface accuracy. Limiting factors are the positioning accuracy of the tool and the accuracy of the manufacturing process. Computer controlled optical surfacing (CCOS) has been developed mainly for the fabrication of spherical and aspherical optics. The surface is repeatedly measured and corrected using abrasives until the target accuracy is attained. In principle, sub-micron accuracy is achievable. The accuracy is limited by surface measurement, and not by the processing equipment.
The current research investigates the adoption of CCOS for the fabrication of free-form steel surfaces. This paper reports on the development of a test bed and initial experiment results.
The test bed is based on a six-axis RX robot as the motion platform with a spindle attached to the wrist of the robot. Surface measurement is carried out using a Talysurf surface profiler. Surface error correction is performed by abrasion of material from the surface. The amount of material to be removed is based on the measured surface error. Following a predetermined tool path, the feed rate along the tool path for surface correction is to be varied according to the required among of material to be removed locally.
A free-form surface specimen of mold steel of about 40 mm × 40 mm across is used for the initial experiment. The surface is prepared by CNC surface machining with the initial maximum error over 50 μm. The positioning accuracy of the motion system is estimated to be no better than 0.1 mm. Through surface measurement and correction, the surface accuracy is significantly improved.
- how does a Talysurf work? says gets 12.5 nm resolution over 10 mm
- Design and analysis of digital materials for physical 3D voxel printing interesting deepdyvable, on block stacking apparently to do true voxel based printing. Actually such n approach could be done similar to that nanofactory but based on ultrasonic welding rather than connectors.
- consider the vacuum attached spider thing with a milling head coudl be made with efab like process problem is mostly localization, maybe coudl eb done with xrays , builder bots coudl have deposition heads too
- http://www.engr.uky.edu/~ymzhang/Papers/Mechatronics%20Paper.pdf another hybrid system, this time based on GMAW welding interesting
- http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.11.6376&rep=rep1&type=pdf process planning and automatino for hybrid system
- ANSYS substitute for abacus?
- http://en.cnki.com.cn/Article_en/CJFDTOTAL-ZGJX200221022.htm not that interesting, about using magnetic feilds to do something whiile welding
- http://www.vsrtechnology.net/wp-content/uploads/dawson-moffat.pdf vibrationals stress relief a study of effectivelness, give s frequencies etc
Copyright © 1993-2001, Hugh Jack Engineer On a Disk Overview: This note set is part of a larger collection of materials available at http://claymore.engi-neer.gvsu.edu. nothign to do with what was looking for but interesitn ginfo on manufacturing processes more here http://elib.tu-darmstadt.de/tocs/133140288.pdf
- http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.12.1042&rep=rep1&type=pdf. SDM for ceramic parts with the make a cast then inject the slurry method, supposedly dimensionally accurate in their view Fabrication of High Quality Ceramic Parts Using Mold SDM
- http://edge.rit.edu/content/P10551/public/SFF/SFF%202003%20Proceedings/2003%20SFF%20Papers/43-Klocke.pdf DIRECT LASER SINTERING OF CERAMICS
- patennt 5745834 says hot isostatic processing gets `1 to 55 micron accuracy?? it was mangled
- 6450393 patent that describes the putting a whole layer of foil down then welding in the right spots approach for UC, also the author had a paper describing that system too doumandinis
- precision investment casting 3204303 need to know how predictable it is also maybe do it under vacuum, have integral cooling channels in the mold etc. Lots of options to improve precision but there is ultimately a random or unpredictable component in the thermal shrinkage just depends on how big it is, still the normal premium investment casting got 80 microns over an inch. Maybe have to talk to someone who knows or find docs on compensating for shrinkage or otherwise attempting to produce accurate castings.
- Chapter 40. Design of a Laser CVD Rapid Prototyping System sounds iteresting but probably only very small scale due to low deposition rates
- what about putting metal powder ina mold and applying pressure but not isostatically and then ultrasounding? hot isostatic processing produces fuly dens parts. Als omaybe the dimensional changes in hot isostatic processing are more predictable in casting due to less crystallization changes happening and therefore high precision could be acheived
- http://www-rp.me.vt.edu/bohn/rp/SRock/SFF95-FPM.pdf. interesting new method, uses 2 diff powders deposited in 3d next to each other, then subject then both to conditions that only cause sintering or other joining in one of the powders, which becomes the part
- A comparative study of wire feeding and powder feeding in direct diode laser deposition for rapid prototyping http://www.sciencedirect.com/science/article/pii/S0169433205001777 Usig diode laser for full strength metal parts shows the brightnes is adequate don't need fiber or ndyag lasers
- RAPID PROTOTYPING OF FUNCTIONAL
METAL AND CERAMIC COMPONENTS BY THE MULTIPHASE JET SOLIDIFICATION (MJS) PROCESS okay http://utwired.utexas.edu/lff/symposium/proceedingsArchive/pubs/Manuscripts/1997/1997-23-Kupp.pdf. mildly interesting but uses binders, basically like fdm but mostly metal, then remove binders and sinter the object s
- see wikipedia article on casting, what if you melt it twice to get the gas bubble sout ? Maybe coudl get a bunch of suitable molds of hemispheres made or maybe use a ceramic ball bearing and a way to scan in the resulting cast surface, and do experiments to try to make highly accurate castings, no might have to make the cast yourself to match the CTE etc. so taht woudl increset he cost of experimetn
- Note that patternmaker's shrinkage does not take phase change transformations into account. For example, eutectic reactions, martensitic reactions, and graphitization can cause expansions or contractions.[19]
- maybe not possible to do casting in a way that eliminates the need for machining, surely someone would have at least tried it by now and can find no eveidence that anyone has
- add to the prototypical section http://www.aws.org/conferences/abstracts/2003/06b.pdf. welding based but the whole object rotates apparently
- http://www.mitcalc.com/doc/tolerances/help/en/tolerancestxt.htm interesting stuff on tolerances
- http://www.springerlink.com/content/42x71x7271620186/ MULTIPLE METALS moodlling for thermal issues and distortion
make a separate category for metal printers
- WATCHING SOME MIT MACHINING VIDS is clearly important to have the scanner to scan in oparts
- add to the comprehensive search page in the proposed open printers section a lin to the metal depositon head and to the ultrasonic consolidation hybrid pritner page, also make sure it and both of them are suitable categorized and accessible from the righ tplaces and also the multimaterial printer page
More general research in august 30--------------
- http://scitation.aip.org/getabs/servlet/GetabsServlet?prog=normal&id=JMDEDB000125000004000809000001&idtype=cvips&gifs=yes&ref=no in situ fabrication of mechanisms (fully assemebled) and sources of error for dimensionality etc.
- checked out the author Nickel, coudl not find any more stuff on thermal stress in SDM or anything else
- for the fused block one could assemble a whole plane or line of blocks and then position over the existing object and weld, might be easier to apply force needed for ultrasonic weldign since can apply it on all 4 sides of the plane and also press down., maybe even coudl be weldied explosively woudl sove thermaldistortion issue , maybe they coudl actually be joined mechanically and still get good strength with some joint mechanism like screws or cold fitting or something?
- http://www.freepatentsonline.com/y2008/0109103.html another on digtial materials basically blocks
- search "digital assembler" they say they made one that uses gik parts so see if it can be found that uses 20 micron gik blocks .
- coudl use error detection on the blocks, then on the line, before deposition, also might be able to connect with mechanical connectors and then press and weld as with isostatic ultrasonic processing to get good bonding
- also many ways to increase the speed, have an area instead of a line with multiple print heads working on the same object
- could maybe use frequencies that only bond some types of blocks when desired? probably not much point
- coudl do it assembly at low temps so grease and oil can be inserted as blocks maybe no need just leave channels
- for scanning laser microscope thing coudl have a low res image roduced by largish spot size, then take multiple images at a slight offset and correlate to give higher res images that maybe much smaller than the spot size of th laser beam
- also chekc how profilometers and other high res high precision reasonable speed , can reach into all visible places 3 d scannners work
- http://www.scientific.net/KEM.359-360.504 on useing a microscope and depth of focus with a camera to image grinding wheels sounds interesting , mentioneds SLM too
- Application of to Digital Scanning Laser Microscope to 3-D Analysis of Contact Surface Damages non english http://www.microsofttranslator.com/bv.aspx?ref=SERP&br=ro&mkt=en-CA&dl=en&lp=ES_EN&a=http%3a%2f%2fdialnet.unirioja.es%2fservlet%2farticulo%3fcodigo%3d3510418
- Photocurrent Imaging Using a Scanning Laser Microscope' PhD Thesis: University of London, 1999 says is a thesis so might be free, searched google scholar and didn;t din maybe here but not for 3d imageing http://www.tfmweb.com/scipro/my_work/PCimg.htm
- tons of hits on scholar for scanning laseer microscope
- also search Non-contact 3D measuring system, profilometer etc for other methods of high res scanning
- http://www.cybertechnologies.com/wp/products/sensors 4 different methods not including slm here, http://www.cybertechnologies.com/wp/products/sensors/laser-triangulation-sensor uses the laser line hing and camera and still gets good resolution
- ultimately probably requires light for good speed and non contact, so can assume that a high bandwidth optical sensor will be needed, either point or line or camera, array.
- http://www.caltexsci.com/measurement systems.htm not clear how this one works
- coudl also use the ultrasonic isostatic bonding with macroscale parts maybe since one of the problems is always bonding finished parts together after assembly, if can bond parts well enough the benefits of monolithic construction are relatvely less
- coudl also use with freeform for the final surface but blocks for bulk fillling eliminating the main thermal distortion problem, or coudl use machining for final surface
- maybe pseudo sintering, diffustion bonding, explosive wledinging etc coudl be used for block building too at least for some material combos , the differing elasticity and compressibility of soem material smight be a problem during isostatic pressing as it could preduce areas inside the part that are not he same pressure on all sidea and therefore distort, but solids are not usually very compressible so maybe not a major problem but there would always be some voids so gas or vacuum cant be filled with liquid because need to bond stuff
- http://www.springerlink.com/content/42x71x7271620186/ might have it elesewher e already Thermal Modeling of Direct Digital Melt-Deposition Processes
K. P. Cooper and S. G. Lambrakos
- http://utwired.engr.utexas.edu/lff/symposium/proceedingsArchive/pubs/Manuscripts/2009/2009-10-Hiller.pdf. ULLY RECYCLABLE MULTI-MATERIAL PRINTING more on digital materials
- http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?arnumber=1554263 small manipulator peizo custom actuator not that interesting off topic
**http://npl-web.stanford.edu/user/files/papers/thesis_agcooper.pdf FABRICATION OF CERAMIC COMPONENTS USING
MOLD SHAPE DEPOSITION MANUFACTURING thesis free and interesting and good mostly on material search and selection woul have thought that was the easy part maybe can do better by being more comprehensive and taking a higher level view, building a library of materials and their properties to choose from including many materials they did not consider and also compormising on e.g. the like of cutting heads is not such a big deal
- http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.11.8267&rep=rep1&type=pdf. Performance of a Shape Deposition Manufacturing Cell not that interesting
- Quality of Parts Processed by Fused Deposition (FDM) http://utwired.utexas.edu/lff/symposium/proceedingsArchive/pubs/Manuscripts/1995/1995-37-Weeren.pdf. ,entiones making ceramic parts with fdm (called FDC) but not clear probably just the green parts
- http://www.sciencedirect.com/science/article/pii/S0890695505001471 Development of a low-cost micro-CMM for 3D micro/nano measurements 1 nm resolution? interometric method
- http://www.technisoft.ch/html/nc-simu1.html machining simulation and compensation software compensate for deflection tool wear etc. with sensors or withouth, implications for automation of machiing too
- more on stress/distortion
- http://utwired.engr.utexas.edu/lff/symposium/proceedingsArchive/pubs/Manuscripts/1993/1993-01-Amon.pdf. might already hav eseen this "material issues in layered forming"
- substitute for casting maybe http://www.springerlink.com/content/v534x1753813t567/ basically sintering though probably has to have sintering or pressing etc as a final step
- http://utwired.utexas.edu/lff/symposium/proceedingsArchive/pubs/Manuscripts/2005/2005-31-Zekovic.pdf Thermo-structural Finite Element Analysis of Direct Laser Metal Deposited
Thin-Walled Structures
- http://www.springerlink.com/content/1175116311718125/ in the google hit thing it says Vacuum
plasma-sprayed deposits undergo self-anneal- ing, which leads to stress-relief and recrystallization, causing fine, stress-free, and equiaxed microstructures" very interesting need to get the doc though
- http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.12.573&rep=rep1&type=pdf has a section on counteracting stresses with shot peening and by surrounding the part in ceramic to prevent distortion and then annealing
- http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.91.4986&rep=rep1&type=pdf example of using shot peenign with sdm
- http://www.springerlink.com/content/3450025137g4w852/ prediction of deformations in parts due to thermal stresses Finite element prediction of thermal stresses and deformations in layered manufacturing of metallic parts
- if the part was rotated around it's center of gravity that migth htelp a bit to reduce thermal distortion because the stress would be circular in some places cancelling itself out, i.e. for a cylindrical region of the part, also maybe if a support material that bonded extremely well were used it could pull on and stretch the part material due to it's own thermal shrinkage but probably no such material since has to be easy to remove too. Still for lathe or other concentric circle parts this could be a way to reduce distortion a lot, coudl then be embedded in ceramic and annealed or just left as is maybe if peening was used during deposition or residual stress is otherwise manageable
- http://www.freepatentsonline.com/y2007/0205184.html ultraprecision additive material 'manufacturing station with EDM sort of interesting' in that it is acheiving high precision though , looks like is only for repair of existing components, interesting that they developed a special diode laser of high brightness apparently also uses various methoids to reduce thermal sresses http://www.google.ca/patents?lr&vid=USPATAPP11668752&dq=freeform%20fabrication%20%20%22manufacturing%20station%22%20precision&printsec=abstract&id=HJCiAAAAEBAJ&output=text&pg=PA1 similar
- http://www.sciencedirect.com/science/article/pii/S0736584510000189 probabl yalready added but good enoguh to be sure
- what precision is acheived with gelcasting ?
- http://www.sciencedirect.com/science/article/pii/S0736584509000982 Hybrid plasma deposition and milling for an aeroengine double helix integral impeller made of superalloy apparently got enough precision
- also maybe coudl build up thin walls or pillars or similar and then join them together to reduce residual stress, much line printing separate lines then joioning but higer z component , and still all those other ways of changing the scan pattern, preheat, thermal pinch, peen, cryogenic treatment, both types of vibratory relief etc. too bad they don't quantify their attempts t reduce stress
- vibratory releif thing said that did not change shape of part but must a little bit maybe check again, also how does it work again? maybe it coudl be done with the object embedded in water or other solvent soluble ceramic ot other extemely rigid material, or frozen material since vibration takes no heat coudl be ice even at very low temps
- coudl be quite a large block of ceramic if it is reusable. Would take some time to deposit, but could spray it on and allow evaporation of solvent. Also if ice coudl be used then a very large block could be used though getting the vibes in there migh tbe an issue.
- what about going to extremes - nanoparticles, extremely low temperatures or high temperatures, a salready said powerful vibrations or shock waves, what else?
- maybe put the questio to enineering forum on how to reliev or reduce stress or a way to deposit metal without stress
- http://www.devileye.net/catalog/pancreatin_preparations/metal_forming_process.html very interesting: STRESS FREE DEposition of steel though has to be relatively high martensitic fraction probably manageable , plasma spray such that stress is controlled partly due to supercooling the metal, wonder how much it coudl eb supercooled? , what about if the layers peen each other low stress method of metal deposition maybe cermaics too? also saw a method advertizing stress free silicon carbide coating
- ss of stress control can also be fine-tuned by the additional application of simultaneous spray peening (for example, as described in GB patent 1605035 ALSO CHECK
- search stress control rather then remove/reduce
- http://nparc.cisti-icist.nrc-cnrc.gc.ca/npsi/ctrl?action=rtdoc&an=14679034 on laser consolidation comments on precision, was to within 25 microns for wall thickness and 50 micron for the diameter of a hollow cylinder
- WO-A-96/09421 discloses a technique of producing
metallic articles by sprayforming wherein the conditions are tailored to ensure stress control http://www.freepatentsonline.com/EP0967295.html
- http://www-cgi.cs.cmu.edu/afs/cs.cmu.edu/Web/People/lew/PUBLICATION%20PDFs/RP/ASMJTST%201992.pdf is already above somwhere but copying again hee because it says soemthing about peening with spraying for stress control
- http://edge.rit.edu/content/P10551/public/SFF/SFF%202006%20Proceedings/Manuscripts/61-Aggarangsi.pdf Localized Preheating Approaches for Reducing
Residual Stress in Additive Manufacturing
- http://www.sciencedirect.com/science/article/pii/S0924013601006525 looked a bit interesting from the google search quote apparently
- 5746844 http://www.google.ca/patents?id=_-AbAAAAEBAJ&printsec=description&zoom=4&output=text apparently uses on the fly annealing didn't read yet though, also uses charged droplets and electrostatic focussing the stream
- 6923241 interesting way to control stress supposedly, image thermal of the deposited layer and use it to determine the distortions apparently not clea rhow it fhanges stress levels though
- http://www.faqs.org/patents/app/20100003158 ultrasonic isostatic powder consolidation to full density could be used with the blocks appraoch might be better to do it under vacuum as they mention gas being squeezed out issues
- also chekc out cold dynamic compaction
- similarly isostatic processing coudl be used with poorly bonded ultrasonic consolidation stuff etc. maybe to improve bonding
- maybe with enough computational power woudl be easier or cheaper to experiment digitally still inits
- http://www.google.ca/patents?lr&vid=USPAT6443352&dq=remove%20residual%20stress%20freeform%20fabrication%20&printsec=abstract&id=NRgKAAAAEBAJ&output=text&pg=PA1 interesting this one uses a method to releive stress after each deposition layer is melted on and uses resistance for heating directly no arc wait does not say how the compressive stress layer is induced, maybe by peening
- mayeb possible to produce blocks that woudl fall into place when vibrated or self assemble or something, if so then coudl use a mold, put the blocks in, then isostatic press and ultrasound with very little unpredictable distortion so make a net shape part high precision
- http://www.emeraldinsight.com/journals.htm?articleid=877433&show=abstract another on ceramics with RP methods
- http://www.sciencedirect.com/science/article/pii/S0957415800000647 htough already added this one but apparently not by searching, Automated system for welding-based rapid prototyping GMAW form fit function one
- Rapid prototyping and manufacturing by gelcasting of metallic and ceramic slurries http://www.sciencedirect.com/science/article/pii/S0921509301018007 more with SDM and gelcasting, there is a big free thesis one on gelcasting with sdm made molds probably above somewhere
- http://utwired.utexas.edu/lff/symposium/proceedingsArchive/pubs/Manuscripts/2003/2003-42-Harrysson.pdf on EBM, says the reason to use ebm instead of investment casting is the cost is lower (??) DIRECT FABRICATION OF METAL ORTHOPEDIC IMPLANTS USING ELECTRON
BEAM MELTING TECHNOLOGY
- CONSIDERATIONS REGARDING THE METHODS USED FOR THE
ASSESSMENT OF CASTABILITY OF DENTAL CASTING ALLOYS http://www.nanocon.cz/data/metal2004/sbornik/papers/106.pdf. some stuff on precision quality dental castings
Summary of current state of research
September 1: Okay so right now for a metal only printer it looks like the best way is to use a droplet on demand printer with molten metal. I think this could be done with induction heating and induction magnetic valves of a sort. The valves can be coils around the relatively narrow (like 0.5 mm) bore of the deposition nozzle section. AC current through them can be used to repel the metal inductively, and 2 of them can be used together to peristaltically pump small quantities of metal, which become the droplets.
This can give good metal deposition in terms of bonding/consolidation, material properties, strength, and variety of alloy that can be used. However the next main issue is residual stress reduction and releif.
For this the approaches, in terms of what should be implemented, in order, are preheating the substrate (build plate)(the dimensional changes that may occur with cooling need to be kept in mind though since the ultimate goal here is to make precision parts, more research is needed on how predictable such changes are), adjusting the deposition pattern and method (pillars or walls which the voids between are then filled in especially look interesting), other process parameters of all sorts, and then stress relief methods mentioned above and on the multimaterial page can hopefully be applied to remove or reduce production of most of the rest of the remaining stress.
EM peening, motorized peening hammer, ultrasonic vibrations either from the substrate or through ultrasonic peening, and low frequency vibrations, shot peening, thermal pinch, and quickly extracting excess heat from the welded area and more are all options. Then annealing or vibrational stress relief or other post production stress relief methods could be applied if needed after the build, one example is annealing while the object is embedded with ceramics (e.g. water soluble) to prevent dimensional changes similar perhaps, but ideally the stress really should be relieved and reduced during the build process because that makes it easier to get better precision for various reasons.
The ideal is a method to deposit stress free void free metal with good material properties at a reasonable rate. The precision does not have to be very good because it will most likely be combined with subtractive removal anyway.
A relatively large amount of support material is likely to be used so it would be nice if it were recyclable or low cost. The search for suitable materials is not trivial but there is such variety to choose from there is inevitably something that will do.
Essentially this deposition method could be either scaled down greatly to the extent where it can deposit with high precision on the order of 10 microns and get good surface finish, probably hard to do but possible with (high temperature for the metal) inkjet type technology, or it can be followed by machining for each layer or set of layers. There are many examples of such hybrid processes in the literature, see the multimaterial page for some more info on them. The most extensively developed and interesting is the Shape Deposition Manufacturing one from carnegie melon. They use it as a generalized term for hybrid FFF/printing and though a metal printing version is developed to a limited degree it is not done yet.
Supporting the leaders and other small parts against machining forces with the hybrid approach, as well as precisely forming bottom facing surfaces and the bottom of leaders is another, due to machine tool reach limitations and the difficulty of fixturing. One way to fixture is to surround the object with rigid support material. Another is to have the machine tool actually brace against the object being machined with a suction cup or similar possibly with a magnetorehological fluid that can be solidifed at will with a magnetic field to interface to the object instead of a rubber seal, thus it is conformable but also can be made rigid when desired. A scanner for dimensional feedback could help too, as can precomputation to simulate the process and compensate for the elasticity of the fixturing. 5 Axis machine tool can help with the reach problem. Machining leaders separately and then lowering them into place and epoxying them down could work too, possibly with alignment pegs machined into the leader that are subsequently removed by machining. There are other possibilities mentioned on the multimaterial page and elsewhere on this page.
Precisely forming the bottom of surfaces can be helped by depositing the metal onto a shaped area of support material so it takes the negative shape but this has accuracy limitations due to metal shrinkage etc. In some cases it may be possible to machine the part separately upside down in another area of the printer and then essentially weld it to the rest of the object with metal deposition though thermal distortion may again be a problem there perhaps no more so that in any other situation.
Again, the main hurdle here is thermally induced stress and distortion. If we can solve this to an adequate degree we will be on cloud nine.
Further reading
- Metal Delta RepRap v1 - uses a MIG welder to print steel
- cast then machine printer system concept
- The Vader ([2])
- Ann R. Thryft. "Video: Biggest 3D Manufacturing Machine Builds Jet Fighter Wing Boxes". Design News magazine. The comments mention that this is not a prototype, it's making actual parts that will fly in the F-35.
