MetalicaRap
Revision as of 01:24, 12 February 2012 by Julialongtin (talk | contribs) (more english.)
MetalicaRap
Release status: Experimental
An Electron Beam 3D Metal and Home Solar cell Printer, including microscope vision system (SEM) & Z axis metal correction in a vacuum.(Design stage).
EBM,categories =Powder
please contact us via mail forum below
MetalicaRap, An Open 3D Metal & Home Solar Cell Printer
Design criteria
The printer should have the following characteristics:
  • A build volume of about 30cm x 30cm x30cm
  • Produces finished parts +/- 20 µm over 20mm
  • Finished parts should be the metallurgical equivalent to wrought iron milled metal parts (full strength, >98% density)
  • The printer is largely self reproducing (i.e. it can print many of its own parts)
  • Single Phase electrical supply (initally 3 phase)
  • Minimum consumables beyond metal powder (avoiding need for e.g. argon gas would be an advantage for later designs)
  • Cost for parts which it cannot itself print plus the raw material for printable parts is less than the cost of a used car (self replication plus self build kit may reduce the price by approximately 100 times i.e. from the existing price of a metal 3D printer or solar cell plant; 1,000,000 euro price tag, to 10,000 euro self print/kit price. historicallythe plastic printer went from 30,000 euro commercial price to 500 euro in 2009 via this approach)
  • The build-rate can be slow i.e. 0.2 kg per hour.
  • Max height should be 2.4m so it can fit in a home. ( first / simpler to construct prototype will be taller than this until we know how much we can bend beam while maintaining spot size, the bigger the bend the shorter it will become)
  • Shape and size of vacuum chamber and electron gun power rating should be suitable for Solar Cell Printing.
Initial decision making
An electron beam based printer was chosen due to the ability to print itsself, the power efficiency of an electron gun vs. a powerful laser at fusing metal, and the fact that an electron gun and vacuum chamber are the primary requirements for thin film solar cell printers. It was recognized that the printer did not require a new technological invention, but does require the existing solutions to become publicly accessable through grassroots research and re-engineering, freeing them from current industrial secrecy practices.
Solar Cell production
A solar cell production plant design that MetalicaRap will be able to print, that will then utilize MetalicaRap's vacuum chamber and beam for solar cell manufacturing processes. For a typical family home electrical system we may bring the solar cell cost down from 10,000 euro to 400 euro by self printing. ( extras; solar cell installation and electrical inverter purchase costs would obviously be on top of this price).
A process that creates thin film solar cells at a vacuum of 10-4 Torr with directly co-evaporate copper, gallium, indium and selenium onto a heated substrate, [3], other precurser choices would also be possible[4]. These CIGS manufacturing process will consist of electron beam physical vapor deposition [5] (EBPVD summary by material [6] ) and DC sputtering in the vacuum chamber (DC sputter animation [7]).
Essential Reading
Existing Commercial Electron Beam 3D printer 2min video introduction click link in square brackets here [8], Factory at home, See [9], 3d Printed Rocket Engine Takes Flight ! See here at 2:40[10] (a stainless steel 3d Print)
Newsletter
We are now 11 months into the development of a printer capable of printing in all common metals, which can largely print itself.
Why charitable?
Currently no commercial companies give away the ability to manufacture their own product to the customer (googles "free search" business model comes closest and also Mendel see below), MetalicaRap does through self printing, this is why this project demands volunteers initially giving their time, effort and charitable contributions via crowd funding. This price reduction method and empowerment model has been shown to work with a plastic printer in 2009 bringing the price down by a factor of 60 (30,000 euro to 500 euro kit price Mendel http://reprap.org/ http://en.wikipedia.org/wiki/Adrian_Bowyer award wining inventor).
What benefits?
A home solar cell printer will enable a whole set of new possibilities including; water supply from air condensing, home tropical greenhouse etc along with the well known environmental benefits of solar power.
Why help?
There is no technological block to the success of this project, but it requires the engineering solutions to happen within an open hardware cultural context to succeed, a group of technical specialists volunteering there time and effort, along with crowd funding. Currently we have 6 specialists based in Copenhagen, Geneva (x-Cern), California (x-stanford), and Toronto volunteering part time in areas including electron gun design software etc....
Critically MetalicaRap may offer the ability to largely print the most expensive parts so may enable the price of the solar cell printer to fall by a factor of 100, so to be within the home budgets grasp. (printing the electron gun is equivalent to printing a 600W fiber laser in a Selective Laser Sintering machine, this guns function is to melt metal on a build platform so producing metal thin film solar cells and metal parts)
For now the self replication will not include the vacuum chamber as it will be largely welded and glued from stainless steel 304 14inch pipe. The power supply is under construction from bought in parts, one pump will initially be purchased, and as the design progresses further parts will be self printed.
If you would like to help and knowing that MetalicaRap's design development details do not fit in one persons head, please specialize and take ownership of a specific task from below or contact us via the mail forum.
Towards this aim of reaching further volunteers we would really appreciate the inclusion of the below within your member contact newsletter in a form that suits your organization.
Kind Regards MetalicaRap team
Request for specialists
We are looking for technical people who are committed to empowering themselves and their environment through self motivated practical tasks in the following areas: Stainless steel metal prototype machining, High voltage power supply prototyping (100kV 1KW) with vacuum tank insulated C.W.Ladder,   Vacuum instrumentation, mechanical drafting / design, and back end software (specifically in unified accelerator library; a gcode to electron beam deflection coil data application).
Crowd Funding Support of MetalicaRap
We are currently raising money to make a RepStrap version of MetalicaRap.
We need an estimated 50K euro, and have so far raised over 5000 euro. Donations over 100 euro recieve a MetalicaRap Printing Certificate.
You can donate money:
There are many other ways you can help further the development of MetalicaRap. Please read this page to get an idea of current development status. We can be contacted on the RepRap IRC channel, [email protected], or best at RepRap MetalicaRap forum.
Practical Tasks
Specific's
  • Put this type of vacuum flange [11]in to Openscad[12] and upload the 3D result .oscd to the files and parts section on the site, owned by username ;...........likely finish date :.........emotional status..........
  • What motor power for build platform verticle motion see scale diagram below ? owned by username ;...........likely finish date :.........emotional status..........
  • Which diameter for extension rod inside moterdriven sleeve. I.D. & O.D. sleeve diameteres, I.D. & O.D for extention shaft? owned by username ;...........likely finish date :.........emotional status..........
  • What motor size & minimum shaft O.D. for hopper X movement/powder deposition ? owned by username ;...........likely finish date :.........emotional status..........
Broader research (this is the difficult stuff) you need plenty of free time to do these
  • We need more hours of CAD input, we could do it much quicker with VacuCAD as all the standard parts are already defined owned by username ;...........likely finish date :.........emotional status..........
Your suggested task here (especially pleased if you are going to do it)
  • ....................................................................................................................................................................................owned by username ;...........likely finish date :.........emotional status..........
None of the processes in themselves are new, they have all been done in other contexts. What is new is that it may offer finished parts requiring no further machining, verification of parts tolerance and bring error correction to metal powder 3D printing for the first time, thus enabling full-strength finished dimensional parts production.
(add your username, your likely Task completion date , and emotional status comment ;(possibles include " its fun" " its challenging" "wow" "----" "I feel like Robinson Crusoe" " I am so alve" "I am going to be wealthy" .... )
Current taken Jobs
  • The filament would have a longer life if we could achieve an electron beam window between gun and taget metal powder [13] ( window probably situated less than 9mm above powder), AL or Ti metal foil used on cross linking machines is unlikely to stand the heat, 400µ micron silicon sheet with 50µ micro dead end holes creating windows looks good? Now gun is sealed in its own chamber looks excellent. owned by username ;.rapatan..........likely finish date :...30 01 2012......emotional status.....cool.....
  • Calculate the required thickness of the vacuum chamber , in stainless 304 and Aluminum , Further material savings ? File:Assembly1 MetalicaRap V2.04.stl Pre detailing chamber to scale ( upload a file with your calcultions with this file name "MetalicaRap contributor additions to calculator spread sheet Rapatan checks adds002.ods" .owned by username: egoZentric likely finish date : 18/10-2011 emotional status: zenfin-ish.
    • File:Cylindrical_Vacuum_Chamber_deflection.ods [14] Results are unverified as of 20:20, 26 October 2011 (UTC) - 2nd opinion required !
    • /eZ
  • Recalculate powersupply for fullwave cockcroft walton ladder and find suitable isolating transformers 3V 50-60 Hz 10 A 100 Kv insolation, suitable to work with a 100 Kv feedthrough see here [15]owned by username: cclor likely finish date : 28/09-11 emotional status: quick-ish.
Contact: click here [16] Rapatan
File:Gun Coil Pump Cost calculator MetalicaRapReadOnly.ods This is MetalicaRap's master spreadsheet click on to download.
Please add your additional calculations for the above spread sheet by uploading either of the following two files with your fresh calculations in, we will then check and make the addition to the master spreadsheet. (please add to them when they are in the red font state only, to upload select upload from left hand menu, you know you have succeeded when one of the below goes blue)
File:MetalicaRap contributor additions to calculator spread sheet Rapatan checks adds002.ods
File:MetalicaRap contributor additions to calculator spread sheet Rapatan checks adds003.ods
General Design
Philosophy
"Since Jones and Swainson many other techniques for rapid prototyping have been developed. Three of the most significant are selective laser sintering (SLS), filament deposition modeling (FDM), and the MIT powder/ink-jet-glue process.A rapid prototyping machine that can make most of its own component parts will clearly be easier to design if one avoids things like high-powered lasers; having the machine make a laser from scratch would be difficult. More subtly, ink-jet print heads (though cheap) are intrinsically hard to make as they involve micro-fabrication, and so a machine based on them would be unlikely (in the medium term) to be able to liberate itself from that one bought-in part. " [17] Adrian Bowyer
Even though SLS was one of the 3 major contenders for the reprap machine, it was rejected due to the difficulty of self manufacturing the laser. Yet using an electron beam may offer easier self manufacture, due to it largely consisting of 3 simple elements; a cathode metal ring, an anode metal tube and a hot wire.
Another key issue is producing verified, dimensionally finished parts. Commercial metal powder printers, both laser and electron based, can not measure the individual parts they produce during production, unlike conventional machining methods. MetalicaRap could due to the inclusion of a layer by layer measuring system (stereo, 3d scanning electron microscope).
The challenges of Z axis control is expected to be greatly helped by the vision system and z axis correction method EBM/vaporization (Vision systems are currently in development stage on state of the art commercial machines.)
Its important to point out that this is a complex and in the 1000's of euro price range project Your largely self producing printer is possible in the commercial setting with either laser or electron beam printing parts as the commercial machines indicate, but due to the power transfer inefficiency from wall socket to most common metals in lasers being 50 times worse than in electron beams, available home lasers would print too slowly (an exception to this is laser to steel 80%)( typically a CO2 laser in copper 1.6% energy transfer efficiency, So a 400W energy to metal therefore requires a 25000 W laser, current home build lasers are considered large at 30W), therefore lasers would limit achievable part size to 10's of cm3( e.g. 3cm x3cmx3cm) with a 2 day print duration, which makes it impracticably slow for self replicating printers. (For further proof try our Laser 808 Build Speed Calculator get from bottom of this page link here[18] )
So the electron gun is still likely to be quite a bit easier for the same power level, especially as long as complications due to magnetic forces, grounding, X-ray radiation, and calibration do not turn out to be too bad a problem, and I wouldn't expect them to. Also, its likely that subtractive machining is needed. Commercial printers report being able to produce finished parts for jet engines and medical implants etc. without it, but granted maybe there are details the manufacturers don't put on their web sites. ( thanks toGreenAtol for his overview assistance Rapatan.)
Initial technical decisions
Due to lack of control in metal powder deposition & molten metal forming droplet/distortions in conventional ebeam 3D printing (e.g Arcam 3d) a tolerance of 300µ in the Z axis is a typical with 10µ powder, (Finer powders are prone to magnetic forces and typically unwieldy, though powder demagnetization and non ferrous construction is a possibility) this demands an error correction which is based round a Vision system using 4-sector, independent channel axial Back Scatter electron detector (BSE) Scanning Electron Microscope (SEM) combined with image processing. The pseudo stereo SEM picture data can be converted to true 3D dimensional data (asymmetrical 4-source BSE photometric stereo 3D-imaging), Enabling sub µ metal height measurement. Z axis dimensional mistakes in any particular layer can be found and corrected by removal of high points through Electron beam machining of the metal. From discussions with industry experts we may bring the XYZ axis to 20µ error over 20mm (IT grade 7 See IT grade table here [19].
Advantages of current chosen design approach
  • Fully functional parts directly from standard metals
  • For most parts it may offer dimensionally finished metal parts IT grade 7
  • Good metallurgy on all common metals (Melting process rather than sintering process ensures near 100% of solid material)
  • Closed loop system
    • Self measurement of finished part tolerances.
    • May offer automatic self correction (subtractive machining steps during build process and feedback with compensation used in the additive process).
Additional Benefits; Can print thin film CIGS Solar cells in existing 10<math>^-</math><math>^4</math>vacuum chamber with existing electron gun, will be able to self print additional required parts for solar cell printer.Example process[20].
Disadvantages of current chosen design approach
  • Vacuum chamber needs on going maintenance.
  • Given the quantity and quality of metal/materials used in 10-4 torr vacuum chamber construction they may have high cost or be hard to obtain. (Limited outgasing required, more info: [21][22])
  • Difficultly in managing metal powders, indicated by the need to have layer error correction, Problem area's including; powder layer flatness, metal meniscus blob formation, metal powder trapped in work piece (i.e. designed internal closed cavities, designed internal porous or honeycomb structures most likely impossible without additional processing or work on the part after printing).
  • Quality Control may be a hurdle to overcome - on the fly heat treatment process development (to overcome residual stress present in the first few layers) may be desirable but optional. This is a problem in general for additive manufacturing of all sorts at present.
  • Adequate surface finish may require post processing, depending on the purpose of the part (what do commercial EBM machines get?).
  • Non-desktop size wardrobe size, chamber volume approx 1m cubed.
Main elements
MetalicaRap in it's current form has 7 main elements which form the printer hardware proper:
  • electron gun including deflection assemblies in a 14 inch dia. gun tube 1.6 m long
  • and metal powder dispenser trough hopper, with a cartesian 8cm diameter topological pick up ring. ( in a box created from a single 8 cm thick sheet of aluminum self shaped to box by MetalicaRap subtractive Electron beam cutting)
  • build platform in a 14 inch dia. build platform tube 1.20 m? long (this first version will be taller)
  • SEM for vision system/feedback regarding the shape of the part and what's going on in the chamber, using the 12kg trough hopper pick up ring.
  • 2 vacuum pump: one roughing pump and one Self printed distributed Ion pump with some tantalum, slotted cathode cells for argon gas collection [23] or oil diffusion pump or turbo pump. ( prototype uses turbo pump)
  • Power supply with high volage elements vacuum encased - known to be doable, knowledge of how to do it widespread.
A low power gun build example
Low power gun in operation.. See [1]
Electron Gun Elements
Coil wiring diagram
Electron Gun
Static Electron Gun B 5KW max (80KV to 150KV 33mA) 1 m above build platform. Providing additive printing through melting at high beam deflection speeds, enabling high build rates, prototype will be approx 1KW 100kv 10mA beam current
For the prototype we suggest one gun in a chamber that can bu used to test either guns design( Melting gun and vision gun), Once we see the outcome of the test we can decide to try two separate guns again if necessary. The one gun will be stationary situated 1m above build platform, a sensor pick up ring will be attached to a 12Kg gravity fed powder hopper just above the build surface with 2 powder wiper blades attached, using sliding slotted plates to release the powder, ( design similar to household air vents but ours will have sharpened vent edges). A second powder hopper will gravity feed the 12 kg hopper, it will be situated up in the side of the 14 inch OD diameter gun tube and will obscure a little part of the build chamber from the beam( a necessary compromise).So using this one gun for both melting and vision systems and a back-scatter detector ring attached tp the powder hopper, close to the workpiece mounted on the Cartesian XY system (the hoppers motion itself provided by the X motion of the hopper, Y motion by means of further 2 linear bearings on front of hopper and drive shaft (No automated Z movement of the ring is included in the design ), (Technical background: See 5.2 [24]see lecture 4.02/11/04[25],[26]
Providing build platform metal powder heating and melting, spot size 100µ (may be inaccurate) pointing accuracy 10µ (may be inaccurate). The gun probably will require the inclusion of a liquid cooling anode system via its support You take heat out of assemblies like this by incorporating water cooling. If you use high purity water (80 meg-ohm) it is reasonably non-conducting electrically, though initially tests will be air cooled vanes on high voltage feed through copper bar.
Vision gun method of providing Sub µm Topological mode SEM vision system (See [27])
Additionally providing Micro vaporization (See gun layout Page 3 [28] down to 10µ to 40µ spot size), Initially this would be used to flatten every tenth layer of the build through high points / blobs removal. Future software development could provide live modeling of build, so through the adjustment of beam melting path in following layers errors/ blobs could be taken account of as they arise, thereby limiting the need for blob removal to critical surfaces.
Vacuum Chamber
Link to details of High vacuum chamber (initially welded then glued)
  • Roughing pump (initially purchased Vane pump e.g. Varian DS102 1.5x10<math>10^-</math><math>^3</math>Torr ) or better an oil free diaphragm pump.
  • Self printed High vacuum Titanium sputter-Ion pump (with some tantalum, slotted cathode cells for argon gas collection [29]) or bought in turbo drag pump or self printed oil diffusion pump (messy) (Use electron guns coils to provide magnetic field to splutter ion pump which pumps down chamber down [30] 50L/s max 1.5x10<math>10^-</math><math>^1</math><math>^1</math>Torr) Prior to self print bought in cost can be saved via diffusion pump route as they are by far the lowest cost to get to the vacuum levels needed compared to a turbo pump doubles the costs (4K euro extra) e.g. pfieffer or Turbovac 50L/s 1.5x10<math>10^-</math><math>^9</math>Torr).
  • Constructed from Stainless steel 304 14 inch pipe (NPS 14 min. SCH 10 ) with one 100mm thick Aluminum plate with interior "carved out" for hopper box sides and top, a further 304 plate for bottom of hopper box with o-ring seal, 304L Top and bottom pipe end caps if not domed min. 18mm thickness typical 25mm thick with copper CF flange and hinged window access.
  • High vacuum <math>10^-</math><math>^4</math> Torr to <math>10^-</math><math>^5</math>
  • Electrical feed-troughs ; For tungsten filament AC 10A 3V 50/60Hz heater power supply electrical feed-through includes a oil immersed 100KV isolating transformer using a Pyrex and quartz tubing within CF pipe coupler with orings with oil imersion on outside [31] .By placing last stage of main 100KV power supply the cockcroftwalton ladder in its own vacuum chamber keeps all high voltage ( 100KV) within vacuum(except filament isolating transformer) which allows 15 KV sparkplug type electrical feedthroughs to be used [32] these are welded sparkplugs on CF flanges with out radio noise suppression carbon resistor . A further welded sparkplug type electrical feedthrough will be used for interconnection of 100KV from power supply sub vacuum chamber to main gun chamber.
  • Mechanical feed-troughs ; 45Nm torque oring or more leak resistant magnetic feed-throughs
  • Viewing window/ Door 8inch borrsilicate glass, 3/8 thick, standard 10 inch CF plate and Oring.
The sputter ion pump has a cost reduction and ease of use advantage for us. As the turbo pump cost has been a block to costs coming down, but after redesign an Ion pump seems a good solution, approximately 300 tubes (anodes at 8KV) 15mm diameter 26mm long made of stainless, with 8mm diameter titanium plates ( cathodes at 0V) fitting in either end of anode tubes , leaving a 3.5mm gap for the gas to enter, these are situated around the outside of the lens coils providing magnetic fields and a 8KV supply hooked up, we have create a electron gun and ion pump combination pump. The number of tubes control the pumping rate it lasts 400 hrs at 10-4 torr but 40000 hrs at 10-6 torr . slotted cathode cells for argon gas collection [33] Nitrogen getting on repeated door opening will be overcome through 400µ micron silicon sheet with 50µ micro dead end holes creating ebeam window.
Another alternative is use an oil diffusion pump but this may be of limited use as it puts some silicon oil vapor in to the chamber which will be cracked if in contact with tungsten filament (at 2600 C) producing oil by products that reduce the vacuum and affect the quality of final produced metal parts, there is an existing home build design, see here: [34],[35] (use google translate) though some people have had success with using the chilling unit from an air conditioner in-between pump and chamber [36]. Other electrical feedthrough options includes 100KV sparkplugs with out radio noise suppression carbon resistor [37] with oil immersion on outside.
But many commercial machines use the diffusion pumps and cope with the oil issues;The cooled condensation baffles in between the pump and the chamber is adequate to prevent any significant amount of oil getting in the chamber at these pressures.
The best way to do wire coils is to seal them into a stainless steel can, and allow a cooling medium like air to ventilate the can. You cannot hope to dissipate much heat from a coil in vacuum, and you don't want the coil to outgas into your vacuum anyway
Metal powder dispenser
This will be a gravity fed split powder hopper.A small hopper will move in the x direction, intermittently refilled by main hopper situated in side of electron gun tube.The small hopper will have a 12Kg powder capacity, this gravity fed powder hopper just above the build surface has two 1cm square section powder wiper blades attached wither side, leveling the roughly dispensed powder. The powder is released using two sliding slotted plates, ( design similar to household air vents but ours will have sharpened vent edges). At the end of the hopper travel a small waste powder slot will remove old dispensed powder before the next dispensing sweep takes place. A second main powder hopper will gravity feed the 12 kg hopper, it will be situated up in the side of the 14 inch OD diameter gun tube and will obscure a little part of the build chamber from the beam (a necessary compromise). The vision system feedback can accommodate some roughness in the powder deposition during beam melting phase and subtractive removal phase.
Other dispensing/ considerations include:
  • Metal Vapor will be released in to the chamber during the melting of the the powder, a later consideration is protection of the gun, initially the guns distance from the build platform should be adequate, but the possible inclusion of a spinning slotted disc in front of the gun as further protection may need to be considered,
  • SEM pickup PIN diodes protection cover will be used when printing,
  • Variable layer thickness might (?) be desirable to provide fine control of the vertical resolution using thin layers where desired, while still allowing relatively high build speeds that come with thick layers for other areas.
    • The Arcam EMB uses a "textured roller". Presumably a roller is textured with a pattern of holes which is loaded with powder, then the powder falls out of the holes, and a little random redistribution occurs on the way down to the workpiece surface for a reasonably uniform powder layer of repeatable thickness.
    • Leveling the surface of the powder bed may be possible using ultrasonic lubrication to briefly fluidize the powder bed. It might cause unacceptable settling though.
    • The density of the powder is lower than the density of the solid metal. So if the powder is only deposited using say the textured roller the upper level of the powder bed will get higher than the surface of the part being printed. How is this dealt with in the Arcam printers? More research needed
Build platform
A 30cm vertical travel stepper motor driven circular platform within a 14 inch 304 tube. Within the build platform is a built in ceramic insulation layer. To keep the metal powder from falling off the platform two felt o- rings make a seal between the moving platform and the stationary tube.
Transformers and ladder 3 phases
Power supply
Power supply with Arc sense, arc quench and arc count.
Cartesian 1kW gun power supply circuit construction will be based around 2 MOT serialized 100KV(1Kw) that gets feeded from a freqency controlled 3 phase switchmode powersupply range 100 Hz to 1 KHz and 8 stage Cockcroft walton ladder for the positive 15 Kv x8= 120KV un regulated, To avoid the need for both; expensive air tight 100KV connecters, and power supply oil immersion , the Cockcroft walton ladder will be situated within the vacuum tank (dead tank with the enclosure at earth potential) in a sub chamber sealed from the main chamber having its own small 8KV ion pump with some tantalum, slotted cathode cells for argon gas collection [38]. The intermediate wall between vacuum tank containing Cockroft walton ladder and main chamber containing gun will be constructed from copper with internal water cooling channels connected to exterior water supply to avoid Diode and resistor overheating problems. With the use of a one way valve between chambers the circuitry remains well insulated unaffected by vacuum loss in the main chamber. .( Cross linking machines already use this vacuum encased powersupply approach).
Cockcroft Walton ladder Calculator Help & Tool for any one who want's a fast overview [39]
Power supply functional diagram now full wave Cockcroft- Walton ladder
Costs and technical calculations spreadsheet
Gun Calculator, download MetalicaRapReadOnly.ods left side
Lens Coil Calculator , download MetalicaRapReadOnly.ods above left side
Large part costs, download MetalicaRapReadOnly.ods above left side
File:Gun Coil Pump Cost calculator MetalicaRapReadOnly.ods this is metalicarap's master spread sheet click on to download.
please add your additional calculations for the above spread sheet by uploading either of the following two files with your fresh calculations in, we will then check and make the addition to the master spreadsheet. (please add to them when they are in the red font state only, to upload select upload from left hand menu, you know you have succeeded when one of the below goes blue)
Remember: What is contributed is more important than the expertise or qualifications of the contributor.
Software
Include the following models for tracking the process;
  • Electron gun beam focus model:To highlight resolution operational compromises between; the higher the gun cathode voltage the tighter gun focus, so the smaller the beam spot size on the metal powder giving rise to a higher XY minimum feature size (lens adjustment can alleviate. See lens simulation [40]), yet also the higher cathode voltage the faster the electrons go, so the deeper the electron energy deposition/giving rise to deeper vaporization holes, giving less vertical Z resolution, (used during Z axis error correction mode). Also surface tension is correlated with temperature, and works in opposition to wetting effect flattening the surface of the melt pool (if the melt pool diameter is small compared to the thickness of the metal layer it may appear as a molten blob of metal). This model will receive an energy profile of the beam by pulling two wire prongs through the beam in the X and Y direction, The wire prongs attached to the end of the sensor ring will be pulled through the beam by the XY motor drives, thereby sensing the energy cross section through the electron beam, which will be radioed back to Unified accelerator Library control system, enabling automatic adjustment of beam focus, beam strength and beam spot size. This will also be used to compensate for ripple in the power supply and operational loss of beam alignment from for example filament variation and magnetic interference. All except the last of these effects should be predictable so most calculations for build can be done by the model prior to build in offline mode.
  • Thermal Real Time Model; this allows us to keep track of the thermal changes across the build chamber or cooling path as the electron gun pulses strike the build volume powder. Considering the following 4 situations conduction rates:1. Metal powder & solid metal volumes experiencing direct electron energy deposition (i.e. heat around electron penetrated regions, the depth of these volumes increases with Cathode Gun Voltage KV & vary with metal type) see electron penetration model [41], 2. solid metal thermal conduction volumes (the completed elements of final metal part under construction), 3. metal powder conduction volumes (the surrounding powder), 4. chamber/boundary thermal conditions (vacuum region, build box). See electron strike model for different metals and different cathode Voltages.In general for any unit volume receiving an amount of energy per second to be raised by 1 degree K (the metals specific heat capacity) from a distant energy source, the amount of energy (W or J/s) arriving from that energy source(the electron beam) via a path; The paths energy transit rate (the conduction rate) is dependent on the cross sectional area of path, the length of path and the temperature difference between the ends of the path, ( "thermal conductivity, units in W/deg.K). The volume changes size by the surrounding pressure (atmospheric pressure, indicating the density of the material).So from known initial temperature conditions combining the specific heat capacity, thermal conductivity and density to calculate paths, then summing these paths leads to knowing the temperature of a specific unit piece of metal and its physical state, solid or liquid or vaporized (temperature above or below its melting point or vaporization point at any particular time). The following should be considered; variation of mass with scan speed, bed preheating scans. See for more background technical information. [42] [43].
  • We may need a network structure to combine the different hardware elements.
"Unified accelerator library" our electron beam focus model and control software choice
Those looking for entertainment might look at the open source Unified Accelerator Library (UAL) that has a 30yr track record of simulation and control of electron beam movement , a Electron beam focus model and a Control/Simulation approach. But UAL lacks thermal models and metal powder melting modeling so it's main use may be to get the beam spot landing on the powder at the correct position and with the desired diameter defined in the G code from skeinforge. (You can down load UAL here [44], [45] Introduction here, [46]
Manuel for UAL's Design Toolkit called MADX where you can enter a hardware definition i.e. collection of coils along a beam start with two solenoids at 0.1m and -6 m, beam at 0m along latticeset, at 3KW 100 micron diameter (MetalicaRap will likely have 3 XY deflector coils for beam deflection, 2 "Solenoid" for beam lenses) then run simulation of beam with OFFLINE MODEL UAL 1.9 here [47].
The hardware definition of coil positions is called the "lattice". The control ONLINE UAL 1.11 will them apply this simulation to the control of the electron guns in real time. Ignore the following elements we don't have them in MetalicaRap: BeamBean, electric kicker,Kicker, RF cavity, taylor map, wake, wriggler .
This has the advantage of being a closed loop system, which while simulating the beam movement simultaneously records models coils, guns, motors inputs; voltage values, current values etc. Then when you run the real world machine these form the drive instructions to the machine, any sensors picking up deviations are resolved through alarms or the software "reality checking" and thus improving the model. It also is designed as a multi user, multi platform software environment. Some draw backs may be over complexity of the system.
  • An open source network software Fast Network "EPICS" for running UAL on, See here [48] [49] More Info here[50]
"Code Aster" our thermal modeling software choice
Quick start instructions on thermal modeling software:
  • Open Source thermal real time model software Code_aster Introduction here[51],
    • Download code-aster software (Windows) here [52],
    • Download extra element GetDP.exe here[53] (put GetDP.exe in c:\ASTER\OUTILS\gmsh\)[54],
    • Download code-aster software (Linux to compile) here[55],
    • Download extra element GetDP.exe here[56] (put GetDP.exe in c:\ASTER\OUTILS\gmsh\) once it is installed and extra element has been copied then as it finishs select option to run code aster.
First select your problem type definition files from the wiki i.e.Thermal program example See here (Use login user: getdp password: getdp) [57]
Second build your mesh of shape you require to be tested, with code_aster sub module Gmsh: you can find it In ASTK prg window under menu item Tools Gmsh \\\ then in Gmsh window select GEO in drop down sub menu //// or import shape via .stl file In ASTK prg window, menu item Tools, Gmsh , then in Gmsh window select; MESH submenu
Third run solver to solve the problem you have defined above by selecting the SOLVER submenu in the GetDP window and hit GetDP button. In GetDP window choose source files for problem; name.PRO file(the problem defined in an example text file from GetDP wiki ) Choose name.MSH ( mesh file defining geometry) Then in GetDP window select options and tick "display client messages" option, then hit Pre then Cal then Pos buttons and then see window called message console window and it will tell you what happened, the output results files name.PRE name.RES name.POS will be in the same directory as the name.PRO file you selected for input.
General info;(Gmsh is a three-dimensional finite element grid generator with a build-in CAD engine and post-processor) See here [58] Can access Gmsh through Graphic user interface or directly through unix or TCPIP socket via code_aster sub module getDP Download GetDP.exe here[59] (put GetDP.exe in c:\ASTER\OUTILS\gmsh\ or specify path to existing location) Overview here [60]See here [61]GetDP documentation here [62], Thermal program example See here (Use login user: getdp password: getdp) [63] Documentation for relevant thermal model calculations See Thermics module R5.02 booklet: / General Architecture D00301a.pdf In DDocsHTML (Down load following two links, unzip to same folder) [64] [65], Complete Guide to code_aster documentation here [66], Software Principles explained here[67] ,Aster documentation source here [68] , home page here [69] wiki[70],
Research Corner Welcomes Your Contribution
If these knowledge areas are new to you, remember to use your networking skills to talk to others, that friend or uncle may be just that expert!
Design/research questions:
  • A. Find magnetic optics simulation packages and run simulations for a Pierce Electron gun running between 50W to 1KW 100KV  ? ( given cathode is 1.6m from target max deflection 8 degrees ) ( spot size vs Cathode voltage, ideal guns , for max 60 KV and max 100 KV guns) ( N.B. All lens are magnetic not electrostatic because to achieve high enough resolution implies guns at 60KV + , to deflect the beam Electrostatic lens must be similar leading to insulation problems and high distortions.)
  • B. Possible pit falls of running an SEM at 100W in four-source photometric stereo Ruderford back scatter mode ?
  • (Depth of field of measurements layer errors over 200µ height, typical SEM power is 0.1W. )
  • C. Target metal surface temperature measurement would be a big advantage, Do you know of a electron bombardment based remote temperature measurement approach?.
  • D. Quantify relationship between cathode surface tolerances and electron gun performance, (spot size variation , 2nd order effects etc ) Quantify range of gun performance at cathode tolerances of IT 7.
  • E. Which pattern of beam movement a "fixed raster pattern (like a TV scan)" or "point and fire where needed" in a) preheat stage? ( taking temp up to 20 C below melting point) b)melting/sintering part shape? (scanning coil eddy curents overcome with delays?,scanning blanked out areas leads to time wasting?, variable shaped beam more efficient?, Interference from other signals- X ray , secondary electrons , luminescence , beam induced currents?, Clear path for beam? )
Design question feed back / discussion. Add your ideas here!
MetalicaRap Construction; Physics Principles/Disscussion
Background Technical design considerations
Construction Materials
Materials:
  • Vacuum chamber wall stainless 304
  • Nickel for some fittings
  • metals for cathode/1stanode-wehnelt/ anode electrodes? '(tungsten /molybdenum/ tungsten,)
  • metal for "soft iron core" surrounding coil windings, unalloyed soft iron for yoke use a soft iron, like AISI 1006; as low carbon as possible. or possible. "Hyperm O", (Cobalt iron alloys for pole pieces if needed e.g. Vanadium Permendur is a superior soft magnet material, but it is VERY difficult to work with and very expensive , and requires fair expertise in heat treating after machining. You should only use it if you need to)
  • thermal conducting material for anode support structure that extends through high voltage feed through? copper
  • Thermionic emission regime hot filament design; Tungsten Ribbon 2mm wide 0.254mm thick ( copper infused tungsten has also been mentioned as more stable physically
  • ceramic insulators, you can use either mullite or alumina. Do not use stuff like teflon (is a sponge for water, and outgasses too much) or macor (machinable glass - too delicate). Your shoulder washers in electron gun support are standard commercial items.
Avoided materials:
  • brass contain zinc which out-gasses intensely when it gets hot, which can lead to ionization and flash overs.
Powder and metalurgy issues
NASA is also making their own machine but with wire not powder, t the 1 hour lecture is a good introduction to the metallurgy involved in EBM see here [71] (if not work then go to http://www.aeronautics.nasa.gov/electron_beam.htm# Select windows streaming in main page, then Windows Streaming Video then +window streaming in pop up window, some other selection options come up with the wrong video).
The initial test run prints will be made in stainless steel 30µ (Pre cool final printed parts from this powder is therefore likely to achieve a tolerance of 250µ) and chromium cobalt under 50µ 30µ?( Pre cool final printed parts from this powder is therefore likely to achieve tolerance of 250µ)metal powder [72]supplier[73], and then later the challenges of Titanium 4µ powder will be considered (Pre cool final printed parts from this powder is therefore likely to achieve tolerance of 20µ). See article on micro sls [74]. See example machine [75],See example of twin chamber 3D printer[76]. Though through subtractive machining we may be able to bring critical surfaces of most of parts down to 20µ. stainless is 316L grain size -45µ+10µ product purpose 3D printing good fluibility, 60gbp a kilo best price 80 kg per buy delivery 3 month. Powder is manufactured from cold rolled metal (e.g. 304 approx 1.8 Euro a KG 07/20111) by Electron Beam Melting of a rod of feed material which then is momentarily caught on spinning plate and flung thereafter, thereby solidify by cooling. See [77]
The magnetic metals lead to magnetizing of Iron based metal powders so should be avoided where possible, (the main magnetic metals are Iron, Nickel, Cobalt Iron)
The metal powders are not good to ingest or breath in so mask should be worn. The metal powders may get caught in the fine folds of your skin so gloves should be worn.
All metal powders can burn easier than solid blocks, the active metals are most flammable and difficult to handle; Titanium 4µ (other active metals include Aluminum, , zirconium ), then the moderate range metals e.g. Cobalt Chromium 50µ and finally low range Stainless steel 30µ . General fire avoidance should be followed, Avoid sparks and open flames, Avoid dust clouds( through dumping action of powders), and use appropriate tools. Design principles of fire avoidance should include; appropriate grounding of equipment, avoid excess mechanical friction in design. For active metals consider glove box contained nitrogen clean up environment or just a liquid based vacuum cleaner.
First layers are tricky to print  ; first layer must weld well to metal to stop part warping , because cold platform contact hot metal residual stress tries to snap build platform so build platform needs to be thick to resist this force, must also need to be reusable after each print must be milled.
Safety issues
The penetrating ability of Xray produced is proportional to the voltage applied to the apparatus, So for your your old TV it was at 30KV but as long as you keep the electrons in a box that was no problem. But If you do like those crazy people in hospitals fire them all round the place precautions need to be taken, MetalicaRap keeps the electrons and the target in a metal box 7.925mm thick.
We can use this formula to calculate the dose rate,
R (rad/sec) = 50 x V (kV) x I (mA) x Ztarget / [r (cm)]2 x 74 where V is acceleration voltage, I beam current, Z constant for target metal type, r distance from target. Formula from Radiation safety manuel page 11 [78]
Lets calculate the dose inside the box we find;
The dose rate inside the chamber at 14 cm from a copper target operated like metalicrap at 100kV and 14 mA is: 50 x 100 x 14 x 29/ (7cm)2 x 74 = 560 rad/sec.
The recommended shielding from this level of radiation for working hours use is 1.2mm of lead. Our chamber is made out of stainless steel 304 each 3mm thickness is equivalent to 1mm thickness of lead shielding, our chamber is 7.925mm thick, So over twice the required shielding is provided by the chamber. So no further shielding materials are required.
Current status
We are based in Copenhagen Denmark at Labitat.dk our main engineers are also in Lancashire UK and Stanford California.
Tuesday night is open night where you can come to Labitat in Frederiksberg, Denmark and meet the team. Currently electron gun test rig and repstrap vacuum chamber, including pumps and gauges under electrical maintenance.
Get involved! The current team donates their free time, Current tech team; 1 Administrator, 1 software developer UAL, 1 electrical engineer, 1 Metal prototyper and 1 accelerator/ electron gun designer all part time
(Very occasional advice from; 1 Ultra-high vacuum metal deposition specialist, 2 physicist, 1 High-voltage system designer, 1 mechanical Design Engineer).
Do get in touch. See talk page and forum for more discussion.
Specialist Parts Chamber
CF flange Electrical connectors, Other (1x 140KV 2KW , , 6x SEM PIN diode pickups low current low voltage,
Main Deflector Coil driver solutions; a) Raster 30cmx30cm b) point and shoot Driver circuit choice Coil position options 1)7 degrees at bottom of gun 2)nearer build table.
3x 12mm Motor shaft Vacuum chamber motion feed through. 10-5 Torr Low torque version and high torque for 700W build platform motor.
Files and Parts
File:Assembly1 MetalicaRap V2.04.stl Pre detailing chamber to scale ( work in progress)
Click on file names to download file
Sub Assemblies and Related
EBS=Electron beam sinterer/melting.
sequence - electron gun parts repstrapped EBS. Assembled tested in repstrap vacuum chamber. Metal powder deposition mechanism parts repstraped EBS . Gun deposition assembled tested. MetalicarapVacuumChamber parts Electron beam sintered by our system. MetalicarapVacuumchamber assembled tested. 5 Elements assembled and tested.
Downloads
Photos and Drawings
Version 2.0
File:MetalicaRap vers. 2.04.dwg
MetalicaRap V. 2
File:Gun coil section side view MetalicaRap vers. 2.0.pdf
Gun & coil section side view 1:2
File:Hopper sense ring MetalicaRap v2.pdf
The 12Kg hopper is supported by a 2 linear bearings at opposite ends. In the Y sense ring motion direction the ring is supported by two linear bearing one above each other next to the red sense ring.The hopper (x axis) and ring (Y axis) are moved by a threaded axels, the drive force is only applied to one axel at a time and is switched by a splined axel. The splined axel is situated on one side of the 12Kg hopper above the other drive axel and linear bearing bar in the x direction. In the y direction their is no spline, just two linear bearings and a drive axel. This drive switching via the splined control rod switchs the motion /drive power between hopper deposition direction x and sensor ring drive direction y, by a further twist on the control spline in one of two directions releases powder deposition from one of 2 hoppers. In the x hopper deposition direction the spline will push a bi laminar slide shutter with 45 degree knifed edge vents open, releasing powder from 12 Kg hopper on to the build platform, by an opposite further twist on control spline in the sensor ring drive direction (y axis control), the spline will push the second bi laminar slide shutter with 45 degree knifed edge vents open releasing powder from the reservoir hopper down to the 12Kg hopper situated below, refilling the 12Kg hopper................................................................................................................................... For high vacuum context this designs requires the further addition of a textured cylinder below bi laminar slide shutter and hopper side mechanical conveyor to overcome powder cloughing in higher vacuum enviroment. .................................................................................................................................... The wire prongs attached to the end of the sensor ring will be pulled through the beam by the XY drives , thereby sensing the beams energy cross section, which will be radioed back to Unified accelerator Library control system, enabling automatic adjustment of beam focus, beam strength, beam spot size, position adjustment. Hopper sense ring (in red) containing 6 PIN diode pickups for SEM in TOPO mode [2]. section side & plan view 1:2
File:Build platform MetalicaRap v2.pdf
Build platform piston section side view 1:5
Version 1.0
alt text
File:MetalicaRap vers. 1.0.pdf
Plan view
Cartesian Gun A
Side View build table
Plan view build table
Side Section of Build table actuator
Build table drum
Build table guide bearings
Metal powder over spill tray , XY lead screw
. . . . . . Change of design priorities behind V2 MetalicaRap's redesign included; Single combined gun through finding existing examples of sub 10µ spot sizes from powerful guns, Cost of large box V.1 chamber, cost of high vacuum motors-exclusion of motors from inside chamber and introduction of motion feed throughs , rejection of UHV due to motion feedthroughs needing to be magnetic, use of ion pump, weight of single hopper, functionality of gravity hopper with correct powder fluidity and preparation, necessity for automated beam energy cross section diagnostics feedback to control system(UAL).
Self replication
Self-replication of a vacuum chamber runs into the "how to make a match box inside a match box problem".
MetalicaRap V2's solution:Buy your 2 sizes of tube cut to length, the larger for gun chamber and build platform chamber the smaller for the spacing rings, glue or weld the smaller pipe rings in the larger pipe, weld in your self printed parts which are now large enough to fit
The chamber surrounding the 12Kg hopper / sensor is too large to print in the build chamber, and you don't want the challenge of welding boxs that are air tight, so you buy a plate as thick as the whole box in Aluminum (cost excludes 304) and slightly over size, remove the build chamber from the bottom of your working printer, clamp the over size plate under it and use your printer in subtractive electron beam machining mode, with the beam striking at an angle by the use of an extra deflection coil, thereby cutting up the material you want to remove and manually breaking the cut bits of with normal hand tools ( other parts are bigger than the build platform like the hopper itself but can be printed in parts and assembled as does not need to be airtight).
Design review
Green Tech./Solar Cell production cost calculation
To produce thin film CIGS solar cells at under 11 cents per Watt peak. So Solar cells cost for a family 3 Bed house; Average Electricity usage 4200KW per year, 4200KW/365days*4.93 Equivalent Hrs peak sunshine= 4200KW/1800Hrs=2.3KW peak of solar cell panels required, at 11 cents per Watt peak the solar cell's would cost 253 dollars from MetalicaRaps plant plus cost of backing material, cost of inverter plus extras 1300 dollar, so it may offer an uninstalled system at under 1,900 dollars,( current price for uninstalled system is around 14,000 dollars (jan 2011)). (Calculation based on cloudy areas of world, 1KWatt peak solar panel system under 4.9 hours peak sunshine per day gives approx 1800KWh per year, A desert area at low latitude would be up to twice as good as this.)( For reference in a hot climate a 1.25 dollar/W installed financed system gives ;0.07 dollar/KWh over 20yrs, 0.03dollar/kWh over 60 yrs [79])
AMQ- A Million Questions section, no need to ask just add your thoughts
Note difference between minimum feature size tolerance, part final tolerance, printer machining tolerance, printer repeatability, post cool down tolerance. So should we design mechanics around 400µ Tolerance so it will still work if we don't get to 20µ/50µ. many commercial powder printers end up printing at 250 µ pre cool tolerance spec. But 400 µ may be more realistic since after printing,part cools down Kinks, coils & warps even if many printer can achieve feature size of 50µ. Though with post print subtractive ebeam machining flatten blobs through repeated surface spot melting, we could bring it back to 50µ? Depends on parts shape, use ..etc
How will the 10µ metal powder effect the mechanics?
Self reproducing tolerance critical parts design around? / buyin ?
CF flange 300µ CHECK WITH VACUUM DESIGNER,
Cathode surface 10µ CHECK WITH EGN 2 gun cross point spec.
Threads ETC 10µ check Mechanical eng.
How do we avoid materials that out gass in high vacuum and so stop vacuum forming.? ..... Two suggestions from an Open source day Copenhagen, Use electric field to pull waste metal away switch on in between beam vaporizing pulses so avoid bending beam.-ve may magnetize powder switching on and off , To protect guns have 2 motorized slotted sheets just above the powder, the hole where the slots cross is where beam enters -ve will slow beam down too much So N.G. as beam may reach 8000m/sn mechanical movement approx 1m/ S
Cathode tungsten pin is heated to 2500o C electron source overheating surrounding mechanical construction once been at 2500o C for 2 days. Ideas to reduce heating of surroundings 1. Not wire connection but use RF aerial to Aeriel connection, insulator which? Principles behind problem Types of energy exchange EM radiation , no convection (vacuum) , Conduction through supports.?
First layers are tricky to print WHY residual tension left in metal. powder thermal pre-treatment to degass and avoid powder balls and good flow.
  • seach in google scholar for METAL POWDER BEAM any thing about why the first layers are so tricky to print and result in most residual stress. [80], [81]
More Examples
Practical manufacturing walk through
Manufacturing walk through Time/Cost
Given Electricity is 2kwh per hour .5Euro/hr Part A Material; Stainless steal, Size; 300x300x200mm Weight; 15Kg 10µ Stainless powder (40 to 100Euro/kg) melt print 100µ Z layer thickness
1 minute per 100µ each layer See below; 1 minute per Z 100µ layer, each layer preheated 20 degrees Centigrade under melting-point followed by printed by beam5.33 minute per Every 10th layer Z axis correction see below ;
SEM ( part assumed to occupy 1/9 of whole print area; 1/9* 300*300=10 000<math>mm^2</math> measurement at every 10µ, SEM picture 500x500 pixel so 5mmx5mm, So for 10,000<math>mm^2</math> need 400 SEM pictures 10,000/25= 400 4x pictures from 4 picups gives effect of different angles? for 3D picture reconstruction so real distances, 400 5mmx5mm pictures, 250ms a picture = 100sec. plus time of mechanical movement of electron gun between .024m square patches at .03m per second is 12y strips each 0.3m strip takes 10 seconds to travel, so in all takes 120 seconds to cover build area( Risk of underestimate factor x100 ) 100+120=220 or 3.66 min flatten blobs through repeated surface spot melting 1ms per 70µ diameter spot area 4000x10-6<math>mm^2</math> ( 850µs duration & 150µs beam movement) 1/10 of part high(Risk of underestimate factor x2) ( 1/10*10 000mm2/ 4000x10-6 <math>mm^2</math>= 1x105 spots 1x105 spots*1ms= 100Sec 1.66min
Time so far 200* Z correction layers 5.33 Min each 1066 + 1800 printed layer 1min each = 2866 min ( 2.0 days) Cost 690 Euro materials 600Euro Electricity 90
Further future developments
Critical Design Review, Review of decisions made so far
In chronological order
1.metal.......................... Vs ..composite. ........... .........Why .Metals needed for high stress high temp contexts , engines, solar plants.. -ve ........................ +ve metals 100 % recyclable fits Cradle to Cradle Design See [82]
2.additive.Sintering........ Vs Subtractive EDM?.................Why Tool path manual intervention required.Consumables......... -ve ..Powder management ............ +ve
3.ebeam..Vs laser .....Why A)laser below 50W,small size part 5x5x5cm,slow B) Laser above 150W cost, permit , Wall plug efficiency , optics .-ve .not so cool , difficulty diagnostics...+ve solar cell printer possible
4.powder...........................Vs foil..........................................Why foil waste removal.................................-ve .Harder solid parts.& powder management...... +ve
5.vision & correction sub. Vs one pass blind process ... ....Why .reliability Verifiable tolerance............................................. -ve ...Complexity..................... ................ +ve
6.gravity hopper................ Vs twin chamber........................ Why avoid old powder reuse fresh every time easier prep ............ -ve their must be a good reason to use 2 build chamber? e.g. EOS is. +ve
7.one static top of chamber gun with just sensor ring on cartesian axis Top gun shoots through sensor ring from top........... Vs two gun would ensure spot size on vaporisation but could add in again if existing does not work. Why So SEM near table Sensors PIN Diodes 164$ each not 64x PINdiodes . Pros & Cons of two guns design
8. Passive cooling Vs Water cooling for 5KW gun .............Why .Air cooling fins on cathode head block and on high voltage copper enclosed connector plus ducted fan & fins -ve need to be FEL modeled to check conductance. +ve Simplicity no water ( though could add later ).
9 Tungsten thermionic cathode filament.2600C. Vs .hot Field emission cathode ..Why Cost of IrCe, field emission required UHV, .Thermionic is OK in high vacuum... -ve hot spots poor beam focus reduced filament lifetime, gas load in metal powder more critical due to filament sharing same space.... +ve cheap no need for window to separate gun chamber from powder chamber
10. .Internal coils in a 304 can. Vs .External coils .... ....Why .to achieve small enough spot size as spherical aborations are zero on axis of lens and increase as you move out, ... -ve need for barrier between coil pole pieces and beam for vacuum, construction of can for air cooling +ve no contact between coils and vacuum
11. Split hopper ..... Vs ..One large dispenser hopper.....Why ..cost chamber size less force required on motion feed through............... -ve ..complexity of refill mechanism ( shutter with knife edges ) ............... +ve. initial lower cost
...................................... Vs ...............................................Why ...................................................... -ve ..................................................... +ve.......................................
list in importance order, bold text indicates more thought required
General Information
Solar cell thin film deposition
Thin film deposition summary by material [83] RF sputter is another option for increased solar cell production rate [84] uses the electron beam to resonate a cavity to produce an RF magnetron) .
Useful links
EBM introduction [85]
Images EBM / EBW [86]
General background Videos EBW see here [87]
Back ground Information on Electron beam processes; electron beam welding / vaporization , EBM 3D printing(2),
Scanning electron microscope SEM background(3)(4).
2. http://www.arcam.com/technology/ebm-process.aspx
More technical sites
3. http://www.matter.org.uk/tem/sitemap.htm ,
4. http://www.uga.edu/caur/semindex.htm
Self Replication Engineering Options See section 2. [88].
EBM technical background lecture See here [89]
General background Videos EBW see here [90]
Discussion of Advantages and Disadvantages of different Tool head processes.
Futher Reading
Vacuum chamber principles; Essential reading before you weld/construct your vacuum chamber, Basic Vacuum technology by Varian
Maths behind vacuum processes ( Not for the faint hearted )[91]
Online Design Tool: Build Speed Calculator for metals including Aluminum,Stainless,Tungsten,
Build speed Calculator Program shows you approximately how long it will take to build a part, based mainly on its external dimensions, metal type, metal fill percentage and power of the electron beam. You can enter these parameters and it will give you the build time.
To run this program you can copy the following code in the grey box below in to an text editor and then save as a name.html file, then open name.html in a browser and enter your values and press calculate build time button. ( for more detailed instructions see the bottom of this section)
<html>
<head>
<title>Build Speed Calculator </title>
<script>
//      N:B: This program takes Latent heat in to account only in build times, not in Frequency caculations!
//            This program's results are only rough guide as it simplifies the problem or does not consider the following options;
//            It considers the melt area under the beam as a cube with equal sided lenghts, the option to make the  X and Y directions longer will probably be implimented becasue;a) though the z layer thickness needs to be at final resolution specification as it can not possible to be varied across the build area, this is not true for the X & Y directions a variable spot size based approach would be advantagous b) the minimum feature size can be bigger than the print resolution.
//            It Caculates diffusivity limit using Fourer's 2nd Law,
//            Its durations do not include time for imaging or corection through vaporisation.
//           Mini research job for someone out their Some metal types diffusivity values have not been found, anyone can add them and remove commented out lines.
//   Program by Rapatan Tansen 5/2011   it will  be added to GIT once we sort it out so your versions can be added.
var stage;
var vaporized = 999999999;
var color = 'ffffff';
var ratio_required_for_cube_power_input_to_drop_below_vaporisation=0;
var ratio_power_input_drop_achievable_by_beam_scan_rate_doubling=0;
var multipass_build_slow_down_power_down_factor=0;
var ratio_needed_to_increase_maximum_hardware_scan_by_to_avoid_vaporisation=0;
var practicle_build_duration_message1='';
var practicle_build_duration_message2='';
var practicle_build_duration_message3='';
var scenario='';
function getValue(t) {  // function to go and fetch entry data variables by name from 'form' called 'calcform' ( see calcform at bottom of program)
   var i = document.getElementById('calcForm');
   var val = '0';
   for ( var j = 0; j < i.elements.length; j++ ) {
     if (i.elements[j].name == t) { // Finds name of variable in table of input variables
	val = i.elements[j].value;
   return( Number(val) );
function setValue(t, v) {  // function to go and put entry data variables by name from 'form' called 'calcform'
		i.elements[j].value = v;
function makeOutput() {
    var depth = (getValue('depth')); // in metres
    var out = '<table border="1"><tr><th>Results</th></tr>';
    var beamspeed = depth / (meltTime(depth) + meltingTime(depth));
    var cubes = ( getValue('object_side_length_x')/100 * getValue('object_side_length_y')/100 * getValue('object_side_length_z')/100 ) / (depth*depth*depth); // x y z in cm convert to m , cubes in whole area fill not taken in to account here as preheat applied to whole area
    var fillfactor = getValue('fill') / 100;
    var passtime = cubes * ( 1 - fillfactor ) * depth / getValue('max_beam_speed');  // Time to pass cubes not melted
    var totalmelttime = cubes * ( meltTime(depth) + meltingTime(depth) ) * fillfactor;
	var finaltime = (totalmelttime + cubes*preheatTime(depth) + passtime) /60/60; // totalmelttime is taking in to accountthe fill factor, but preheat time is all build area (via cubes), passtime is kipped area
	var totalvaptime = .001*cubes * ( meltTime(depth) + meltingTime(depth) + boilTime(depth) + boilingTime(depth) );
	out += '<span style="color:grey;font-size:50%">build slow down factor;</span>'	+ (diffusionDeflectionHardwareLimitsOnBuildTime(depth)).toPrecision(3) + '  <span style="color:grey;font-size:50%">   Number of beam passes ; </span>' + (achievableCubePowerDropToAvoidVaporisationThroughBeamScanSpeedIncrease(depth) ).toPrecision(3) + '  <br/> '+'<br/>' ;
	out += 'Beam power leaving gun: ' + BeamPowerLeavingGun() + ' W <br/> ';
	out += 'Build duration with metal diffusivity & deflection coil speed limit No defocus : melting time  ' + (((totalmelttime/60)/60)*diffusionDeflectionHardwareLimitsOnBuildTime(depth)).toPrecision(3) + ' hours  + preheating time  ' + ((cubes * preheatTime(depth)/60/60)*diffusionDeflectionHardwareLimitsOnBuildTime(depth)).toPrecision(3) + ' hours  + skipping time  ' + (passtime/60/60).toPrecision(2) + ' hours  =    ' + ((finaltime)*(diffusionDeflectionHardwareLimitsOnBuildTime(depth))).toPrecision(3) + ' hours to <span style="color:black;font-size:100%">build</span>        <br><br>';
	out += '             ' + practicle_build_duration_message1 + '   <br/>' + practicle_build_duration_message2 + '   '+ practicle_build_duration_message3 + '<br/>' ;
	var SpecialCasefinaltimeNodiffusionLimitOnPreheatAsDefocusBeam = (totalmelttime *(diffusionDeflectionHardwareLimitsOnBuildTime(depth))+ cubes*preheatTime(depth) + passtime) /60/60; //
	out += 'Build time with preheat defocused : melting time    ' + (((totalmelttime/60)/60)*diffusionDeflectionHardwareLimitsOnBuildTime(depth)).toPrecision(3) + ' hours  +  Defocused beam preheating time  ' + ((cubes * preheatTime(depth)/60/60)).toPrecision(3) + ' hours  + skip  ' + (passtime/60/60).toPrecision(2) + ' hours  = <u> <span style="color:black;font-size:160%"> ' + ((SpecialCasefinaltimeNodiffusionLimitOnPreheatAsDefocusBeam)).toPrecision(3) + ' hours to  build     </u> <br><br>';
	out += ' Build time ignoring metal diffusivity limit: melting time   ' + ((totalmelttime/60)/60).toPrecision(3) + ' hours  + preheating time  ' + (cubes * preheatTime(depth)/60/60).toPrecision(3) + ' hours  + skipping time  ' + (passtime/60/60).toPrecision(3) + ' hours  =  ' + (finaltime).toPrecision(3) + ' hours to build    <br>';
	out += 'Desired speed for <span style="color:black;font-size:140%">Digital to Analogue converter</span> controling beam power switching Off and On to achieve required melting : <u>'  + ((((1/( (meltTime(depth)) + (meltingTime(depth)) ))*(diffusionDeflectionHardwareLimitsOnBuildTime(depth))).toPrecision(8))/1000000) + ' MHz </u><br/><br/> ';
	out += 'Other info;<br/> ' ;
	out += ' Scenario : ' + scenario + '        .....    <br/>   ';
	out += ' Total vaporisation time of 1000th of volume of part: ' + (totalvaptime/60/60).toPrecision(2) + ' hours <br/> ';
	out += ' <span style="color:grey;font-size:50%">  Number of cubes within part: </span>' + (cubes).toPrecision(5) + '<br/> ';
	out += ' <span style="color:grey;font-size:50%">  Melt time 1 cube ( depth^3) </span> ' +  (meltTime(depth)).toPrecision(3) + ' <span style="color:grey;font-size:50%"> S   max thread exposure duration is  </span>' + (maxExposureDuration(depth)).toPrecision(2) + ' <span style="color:grey;font-size:50%">  S </span><br/> ';  //
	out += ' <span style="color:grey;font-size:50%">  X Deflection coil scan sate ignoring diffusion limit: </span>' + (rasterXScanRate(depth)).toPrecision(5) + ' <span style="color:grey;font-size:50%">Hz .... X deflection coil scan rate taking in to acount diffusion limit </span> ' + (maxThreadExposureXScanRate(depth)).toPrecision(5) + '<span style="color:grey;font-size:50%">  Hz ....  </span> <br/>';
	out +=  '<span style="color:grey;font-size:50%"> Cube melt time no diffusion limit </span>' + (meltTime(depth)).toPrecision(4) + '<span style="color:grey;font-size:50%"> S    Cube melt time with diffusion limit </span> ' + (maxExposureDuration(depth)).toPrecision(4) +'<span style="color:grey;font-size:50%">  S .... </span> <br/>';
	out += '  <span style="color:grey;font-size:50%"> beam speed :</span> ' + (beamspeed).toPrecision(5) + '<span style="color:grey;font-size:50%">  m/s          .....    </span>   ';
	out += '  <span style="color:grey;font-size:50%"> Time spent on moving beam across non-treated areas: </span>' + (passtime/60/60).toPrecision(2) + ' <span style="color:grey;font-size:50%"> hours </span><br/> ';
   out += '<span style="color:grey;font-size:50%"> Checks; </span><br/> ' ;
   out += ' <span style="color:grey;font-size:50%">      solid phase: </span>' + meltTime( depth ) * 1000;
   out += '  <span style="color:grey;font-size:50%">  μs        melting phase:  </span> ' + meltingTime( depth ) * 1000;
   out += ' <span style="color:grey;font-size:50%">   μs        liquid phase:  </span> ' + boilTime( depth ) * 1000;
   out += ' <span style="color:grey;font-size:50%">   μs        boiling phase:   </span>' + boilingTime( depth ) * 1000;
   out += ' <span style="color:grey;font-size:50%">   μs      </span> ';
   out += ' <span style="color:grey;font-size:50%">   δT     <sub>solid</sub>  </span>' + solidTemp( meltTime(depth), depth ) + '   ' ;
   out += ' <span style="color:grey;font-size:50%">  T           <sub>melting</sub>      </span>  ' + ( solidTemp( meltTime(depth), depth ) + getValue('preheat') ) + '  <br> ' ;
   out += ' <span style="color:grey;font-size:50%">  practicle_build_speed_factor_output via scnario sub routine with max raster rate check </span>' + (diffusionDeflectionHardwareLimitsOnBuildTime(depth)).toPrecision(3)  + ' <br> <span style="color:grey;font-size:50%"> The upped multipass scan rate is this amout larger than the entered scanrate limit ( limited by hardware )     </span>  ' + (practicalDurationMultiplicationFactor(depth)).toPrecision(3) +'   <br>';
   out += ' <span style="color:grey;font-size:50%">  multipass_build_slow_down_power_down_factor (when none = 1) </span>' + (diffusionDeflectionHardwareLimitsOnBuildTime(depth)).toPrecision(3)  +'   <br>';
   out += ' <span style="color:grey;font-size:50%">  cube Power Reduction Required To Avoid Vaporiseation (when none = 1) </span>' + (cubePowerReductionRequiredToAvoidVaporiseation(depth)).toPrecision(3)  +'   <br>';
   out += ' <span style="color:grey;font-size:50%">  achievable Cube Power Drop To Avoid Vaporisation Through Beam Scan Speed Increase </span>' + (achievableCubePowerDropToAvoidVaporisationThroughBeamScanSpeedIncrease(depth)).toPrecision(3)  +'   <br>';
   out += '<br/>' ;
   out += '<table border="1"><tr><th>Time</th><th>Temperature of unit cube</th><th>Stage</th></tr>';
   for ( i = 1 ; i <= getValue('steps'); i++ ) {
      var t = i * getValue('timestep');
      var res = calcTemp(t, depth);
      out = out + '<tr><td>' + t + '</td><td bgcolor="#' + color + '">' + res + '</td><td>'+ stage +'</td></tr>';
   out = out + '</table>';
   return(out);
function mass(depth) {
   return(getValue('density_solid') * depth * depth * depth ); // get mass of box KG ,cubing lenght each lenght from cm to m to get volume x density giving mass kg
function WallSocketPower() {
   return power = getValue('current_beam') * getValue('voltage_gun')*(1/(getValue('wallplugefficiency')/100));
function BeamPowerLeavingGun() {
   return power = (getValue('current_beam') * getValue('voltage_gun'));
function beamPower() {
   return power = (getValue('current_beam') * getValue('voltage_gun')*(getValue('BeamToMetalAbsorbtionEfficiency')/100));
function preheatTime(depth) {
   var d_T =  getValue('preheat') - getValue('InitialRoomTempinK'); //   all Kelvin  To det the duration up to preheat temp first remove the starting temprature ie room temp 18C 291 from preheat temp
   return(d_T * mass(depth) * getValue('shc_solid') / beamPower() );  // mass KG beam W  required change in temprature times specific heat solid divided by supplied beam power
function meltTime(depth) {
   var d_T = getValue('melting_point') - getValue('preheat');
function meltingTime (depth) {
   return( mass(depth) * getValue('heat_of_fusion_melt') / beamPower() );
function boilTime (depth) {
   var d_T = getValue('boiling_point') - getValue('melting-point');
   return(d_T * mass(depth) * getValue('shc_liquid') / beamPower() );
function boilingTime (depth) {
   return( mass(depth) * getValue('heat_of_fusion_boil') / beamPower() ); //  checks on temp transition values
function vaporizeTime (depth) {
	return (99999);
function solidTemp (time, depth) {
   var d_T = time * beamPower() / ( mass(depth) * getValue('shc_solid') ); //  checks on temp transition values
   return ( getValue('preheat') + d_T );
function liquidTemp (time, depth) {
   var d_T = time * beamPower() / (mass(depth) * getValue('shc_liquid') );
   return ( getValue('melting_point') + d_T );
function thermalDiffusivity() {
	var a= ((getValue('thermal_conductivity')) / (getValue('density_solid')*getValue('shc_solid')));
	return (a); // ok
function maxExposureDuration(depth){ //all the following routines caculate limits imposed from vaporisation avoidance and hardware scan rate limits.
	var time=((Math.PI)/(thermalDiffusivity()))*(((getValue('melting_point')*getValue('thermal_conductivity'))/(2*((beamPower())/(depth*depth)))) *((getValue('melting_point')*getValue('thermal_conductivity'))/((beamPower())/(depth*depth))));
	//   Time to vaporise is solution of Fourier 2nd law; which says
    //	second difeerential (ie accleeration of change) of Temperature T with depth z is equal to one over the thermal difussivity times fist differential of temperature T against Time t
    // under steady state conditions with different tempratures at ends of a virtual section or rod or cooling path, temperature across a long cyclinder/rod/cooling path  	at any point is constant as emergy flows through bar
    //  So temperature only changes when  the rate of heat flow changes (SECOND DIFFERENTIAL ) that thus produce chages in bar
    // solved for initial state z= 0  surface of bar and z= infintie where no change of temprature
    //and in case where t= 0 then current temprature is equal to initial tmeprature
    // So you get above formula ; formula(5.3) see p256 - p258  in William M steen Laser material processing (version 4) chapter 5.3
    // analytical models of one dimensional heat flow   Ie one dimension is beam spot on metal; which flows in x y and z directions are analyzed,
	return(time);
function rasterXScanRate(depth) { // this routine calculates scanrate (Hz) based on time taken to process x axis lenght of cubes * 2 ignoring latent heat fusion
	var melt_cubes_across_X_lenght_in_part = (((getValue('object_side_length_x')/100)/(getValue('depth'))))
	//this rate and the following subroutines are beimg compared with rate from Fourier 2nd law that does not take in to account latent heat of fusion
	// So we have to ignore latent heat of fusion as that only applies whereupon the melt temprature has been reached
	// but we are using this for the scan rate for all preheating and heating up to melt temprature,
	var period = 2*(melt_cubes_across_X_lenght_in_part*((meltTime(depth)))); // shouold this be maxExposureDuration(depth)
	return ( 1/(period));
function maxThreadExposureXScanRate(depth) { // this routine caclulates the upped scan rate (Hz) caused my the need for multipasses of beam.
   var multi_pass_period = (((maxExposureDuration(depth)))*((getValue('object_side_length_x')/100)/(getValue('depth'))));
   // .toFixed() ROUND UP DOES NOT WORK CHECK WITH PROGRAMMERis a round up form of command  cubemelttime/max exposure duration for thread
   return ((1/(multi_pass_period)));
function cubePowerReductionRequiredToAvoidVaporiseation(depth) { // this routine caclulates the required cube power down ratios to avoid vaporisation.
   var ratio_required_for_cube_power_input_to_drop_below_vaporisation= (((meltTime(depth)))/(maxExposureDuration(depth)));
   return (ratio_required_for_cube_power_input_to_drop_below_vaporisation);
function achievableCubePowerDropToAvoidVaporisationThroughBeamScanSpeedIncrease(depth) {
var   ratio_power_input_drop_achievable_by_beam_scan_rate_doubling = ((getValue('max_hardware_limited_raster_scanrate'))/(maxThreadExposureXScanRate(depth)));
   // each bite at the cherry with no vaporisation is done at freq.of maxThreadExposureXScan Rate(depth) Hz how many of these can fit in Max hardware limit scan rate
   // If say 8 bites at the cherry are required to transfer enouch heat to cube,
   // than a 8x maxThreadExposureXScan Rate(depth)Hz value of Max hardware scanrate would mean that no consequential delay.
   // this case only works for max hardware scan rate being bigger than depower factor times rasterXscanrate
   //(meltTIme/max exposure)
   // If max hardware scan rate is smaller ie returned ratio_power_input_drop_achievable_by_beam_scan_rate_doubling < 1
   // then must apply (1<) cube reduction required to duration in main subroutine.
   if ( ratio_power_input_drop_achievable_by_beam_scan_rate_doubling < 1 ) {
   // It can be low for two reasons,
   //1)  if max hardware is low / nearly 0  it will still just times build by factor required
   //2)   and max threadexposure scan is high ( which is commmen )
   // when max hardware is low we want it to increase duration and this fraction of 1 shows how far too low
   // need to hand back how far too low.. Also still need to test for the remaining factor to times build speed
   // by setting ratio_power_input_drop_achievable_by_beam_scan_rate_doubling=1  but not here do in main subroutine.
    // no doubling of beam speed possible so reduction must be achieved through build duration lengthening.
    } else {
    // doubling of beam speed possible use above calculated value rounded up DO rounding later LATER &&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&
	// result should be 2 or higher  what happens when not all needed need another check?
	// So caclulate required factor then
    //	IF achievable factor is higher set achivable equal to required.
var	ratio_power_input_drop_achievable_by_beam_scan_rate_doubling=(ratio_power_input_drop_achievable_by_beam_scan_rate_doubling).toPrecision(2)
	   if ( (cubePowerReductionRequiredToAvoidVaporiseation(depth)) < ratio_power_input_drop_achievable_by_beam_scan_rate_doubling ) {
     //  all the required power drop can be achieved through increased beam speed / increased raster speed.
var  ratio_power_input_drop_achievable_by_beam_scan_rate_doubling=(cubePowerReductionRequiredToAvoidVaporiseation(depth)) ;
        } else {
    // the increased beam speed cannot account for all required reduction,
	//ie need to lenghten build duration by the outstanding amount & drop or pulse power
   return (ratio_power_input_drop_achievable_by_beam_scan_rate_doubling);
function practicalDurationMultiplicationFactor(depth) { // this calculates how many times higher the upped scan rate is compared to the max hardware limited scan rate
   var factor = (maxThreadExposureXScanRate(depth))/(getValue('max_hardware_limited_raster_scanrate')); // .toFixed() needs to be rounded up TOP not bottom put back in later?
   return ( factor );
function diffusionDeflectionHardwareLimitsOnBuildTime(depth) { // these calculations ignore the latent heat effects as vaporisation time Fourier 2nd law ignores it too.
   if ( (meltTime( depth )) < (maxExposureDuration(depth))) {
      // No Need to take a second pass  or extend build time with pulseWidthModulatebeampowerdrop, var practicle_hardware_build_speed_factor=1; practicle_build_duration_message1=''; practicle_build_duration_message2='';
     var  multipass_build_slow_down_power_down_factor=1;
		  practicle_build_duration_message1= ' Multi passes not required';
	      practicle_build_duration_message2=' Current delfection scan rate hardware limit is '+ ((getValue('max_hardware_limited_raster_scanrate')).toPrecision(7)) + ' Hz   '; // kug
  	      practicle_build_duration_message3='  Required deflection coil scan rate hardware limit (Hz) would need to be ' + ((rasterXScanRate(depth)).toPrecision(7)); // how can I add so outputs desired_scan_rate_possible_new_redesign design= practicalDurationMultiplicationFactor(depth)*rasterXScanRate(depth)
           scenario=' A   Coil drivers can achieve required speed & metal diffusion limit not reached, so no multipass required ( design could be pushed harder?)';
   } else {
            // If cube melt time is above max exposuire duration; So Need to take a second pass or extend build duration at reduced power, so as not overload metal diffusion rate
            // or will multi pass demand too higher speed of deflection coil; So need to increase build duration and drop power.
			// Reduction by ratios "ratio_required_for_cube_power_input_to_drop_below_vaporisation" (rounded up) "ratio_power_input_drop_achievable_by_beam_scan_rate_doubling"
		    // remaining requirement achieved through extending build duration & power drop Pulse Width Modulated beam power drop
	   	    // =  (needs1<)ratio_required_for_cube_power_input_to_drop_below_vaporisation/(or limited to required amount) ratio_power_input_drop_achievable_by_beam_scan_rate_doubling = multipass_build_slow_down_power_down_factor
             // calculate remaining cube power drop thats required after increasing the beam speed up as much as posible ( or as much as needed so result is 1 for multipass_build_slow_down_power_down_factor)
           if ( achievableCubePowerDropToAvoidVaporisationThroughBeamScanSpeedIncrease(depth) > 1 ) {
	    var   multipass_build_slow_down_power_down_factor=((cubePowerReductionRequiredToAvoidVaporiseation(depth))/(achievableCubePowerDropToAvoidVaporisationThroughBeamScanSpeedIncrease(depth)));
			   if ( multipass_build_slow_down_power_down_factor < 2 ) {
	              // No build & power slow down is required, all achieved through beam speed up
                       practicle_build_duration_message1= ' Multi passes required , deflection coil hardware can cope with beam moving faster, ';
               var     multipass_build_slow_down_power_down_factor =1;
	                   practicle_build_duration_message2=' Delfection scan rate is '+ (((maxThreadExposureXScanRate(depth))*(achievableCubePowerDropToAvoidVaporisationThroughBeamScanSpeedIncrease(depth))).toPrecision(7)) + ' Hz   '; // + maxThreadExposureXScanRate(depth)     add later
				   scenario=' B     BeamSpeed/Scanrate rate increased coil drivers can cope with increase';
       		    } else {
                  // multipass_build_slow_down_power_down_factor >= 2 So need both deflection coil increase and build time lenghtening with power drop
                     practicle_build_duration_message1='  To avoid lenghtened build duration (above), caused by deflection coil hardware being too slow, increase maximum hardware deflection coil speed by improving coil drvier circuits (more expensive drivers running coils at incresed volatges and currents ) ';
					 practicle_build_duration_message2='  Current delfection scan rate is '+ (((maxThreadExposureXScanRate(depth))*(achievableCubePowerDropToAvoidVaporisationThroughBeamScanSpeedIncrease(depth))).toPrecision(7)) + ' Hz   '; // + maxThreadExposureXScanRate(depth)     add later
					 practicle_build_duration_message3='  To avoid build time lenghtineing required deflection coil scan rate (Hz) would need to be ' + ((practicalDurationMultiplicationFactor(depth)*rasterXScanRate(depth)).toPrecision(7)); // how can I add so outputs desired_scan_rate_possible_new_redesign design= practicalDurationMultiplicationFactor(depth)*rasterXScanRate(depth)
                  scenario=' C   BeamSpeed/Scanrate rate increase & Increase build duration  Coils cannot go fast enough use pulsed power';
		   } else {
		   // find how far too low max hardware scan rate is; 1/ratio_power_input_drop_achievable_by_beam_scan_rate_doubling  give as duration lengthening factor & multiply with maxThreadExposureXScanRate(depth) the freq based on maxdurationTIme on cube
 		var  multipass_build_slow_down_power_down_factor= (1/(achievableCubePowerDropToAvoidVaporisationThroughBeamScanSpeedIncrease(depth)));
	                 practicle_build_duration_message1='  Coils operate so slow that they cannot even meet a multipass scan rate,  increase maximum hardware deflection coil speed by improving coil drvier circuits  (more expensive drivers running coils at incresed volatges and currents ) ';
					 practicle_build_duration_message3='  Scan rate required to achive even multipass scanrate deflection coil scan rate, hardware limit (Hz) would need to be ' + ((multipass_build_slow_down_power_down_factor*(getValue('max_hardware_limited_raster_scanrate'))).toPrecision(7))+'  Hz     To achive no extension in  build duration a single pass scan rate, deflection coil scan rate hardware limit (Hz) would need to be ' + ((multipass_build_slow_down_power_down_factor*(getValue('max_hardware_limited_raster_scanrate'))*cubePowerReductionRequiredToAvoidVaporiseation(depth)).toPrecision(7)); //
                  scenario=' D    Increase build duration, Coils cannot go fast enough use pulsed power';
		   // let it equal 1 to caculate remainder
		   //NOT NEED? ratio_power_input_drop_achievable_by_beam_scan_rate_doubling = 1;
		    // multipass_build_slow_down_power_down_factor=(cubePowerReductionRequiredToAvoidVaporiseation(depth))/ (achievableCubePowerDropToAvoidVaporisationThroughBeamScanSpeedIncrease(depth));
       return (multipass_build_slow_down_power_down_factor);
function calcTemp(time, depth) {
   var res = 0;
   var time_solid = meltTime( depth );
   if ( time < time_solid ) {
      stage = 'solid A'
	  color = 'ffffff'
      // Solid
      res = solidTemp(time, depth);
   } else {
      time = time - time_solid;
      var time_melting = meltingTime( depth )
      if (time <= time_melting) {
          // Melting
      stage = 'solid B'
	  color = 'ffffff'
          res = getValue('melting_point');
      } else {
          time = time - time_melting;
          var time_liquid = boilTime( depth );
          if ( time < time_liquid ) {
		stage = 'Melting C'
	  color = '0000ff'
             // Liquid
             res = liquidTemp(time, depth);
          } else {
             time = time - time_liquid;
             var time_boiling = boilingTime( depth );
             if (time <= time_boiling ) {
             stage = 'Liquid D'
	  color = '0000ff'
	        // Boiling
           	res = getValue('boiling_point');
			} else {
				time = time - time_boiling;
				var time_vapor = vaporizeTime( depth );
				if (time <= time_vapor) {
					stage = 'Vapor E'
	  color = 'ff0000'
			// Vaporised
                res = 'gone';
				} else {
					alert('error');
   return(res);
function selectmetal(s) { // s = metal choise field    STILL TO GET FIGURES FOR Cobalt chromium , copper  , gold and molybdenium, 006 before decimal means not got number yet
	if(s == "titanium")
		setValue('preheat', 1648);//  K                       complete data
		setValue('BeamToMetalAbsorbtionEfficiency', 85);//  %
		setValue('density_solid', 4510);//  kg/m^3
		setValue('melting_point',1668);//  K   T
		setValue('boiling_point', 3260);//  K   T
		setValue('shc_solid', 519);//  J/kg/K
		setValue('shc_liquid', 519);//  J/kg/K
		setValue('heat_of_fusion_melt',437000);//  J/kg
		setValue('heat_of_fusion_boil', 9000000);//  J/kg
		setValue('thermal_conductivity',19);//  W/m/K      K
		setValue('thermal_diffusivity', 0.0000081);// m^2/s   check factor of 10 out?
	}else if(s == "aluminium")
		setValue('preheat', 640);//  K                          complete data
		setValue('BeamToMetalAbsorbtionEfficiency', 0085);//  %
		setValue('density_solid', 2700);//  kg/m^3
		setValue('melting_point',660);//  K
		setValue('boiling_point', 2450);//  K
		setValue('shc_solid', 900);//  J/kg/K
		setValue('shc_liquid', 900);//  J/kg/K   check
		setValue('heat_of_fusion_melt',397000);//  J/kg
		setValue('heat_of_fusion_boil', 9492000);//  J/kg
		setValue('thermal_conductivity',226);//  W/m/K
		setValue('thermal_diffusivity', 0.000093);// m^2/s
	}else if(s == "cobalt_chromium")
		setValue('preheat', 001667);//  K
		setValue('density_solid', 004350);//  kg/m^3
		setValue('melting_point',1491);//  K
		setValue('boiling_point', 003260);//  K
		setValue('shc_solid', 00622);//  J/kg/K
		setValue('shc_liquid', 00622);//  J/kg/K
		setValue('heat_of_fusion_melt',00440000);//  J/kg
		setValue('heat_of_fusion_boil', 009830000);//  J/kg
		setValue('thermal_diffusivity', 0.000095);// m^2/s
	}else if(s == "copper")
		setValue('preheat', 1063);//  K   copper type; C10100 name; oxygen free elctronic coppper,
		setValue('BeamToMetalAbsorbtionEfficiency', 0085);//  %aplication  for bus tube, conductors, vacuum seals ,
		setValue('density_solid', 8900);//  kg/m^3  glass to metal seals wave guides (Use C65100 for heat exchange electrical conduits)
		setValue('melting_point',1083);//  K
		setValue('boiling_point', 002260);//  K
		setValue('shc_solid', 385);//  J/kg/K
		setValue('shc_liquid', 385);//  J/kg/K
		setValue('thermal_conductivity',391);//  W/m/K
		setValue('thermal_diffusivity', 0.000095);// m^2/s ok Source: wikipedia
	}else if(s == "gold")
		setValue('preheat', 1295);//  K
		setValue('BeamToMetalAbsorbtionEfficiency',85);//  %
		setValue('density_solid', 19300);//  kg/m^3 19.32Mg/m^3
		setValue('melting_point',1335);//  K
		setValue('shc_solid', 131);//  J/kg/K
		setValue('thermal_conductivity',300);//  W/m/K
	}else if(s == "iron")
		setValue('preheat', 1516);//  K                        complete data
		setValue('density_solid', 7870);//  kg/m^3
		setValue('melting_point',1536);//  K
		setValue('boiling_point', 3000);//  K
		setValue('shc_solid', 460);//  J/kg/K
		setValue('shc_liquid', 00460);//  J/kg/K
		setValue('heat_of_fusion_melt', 275000);//  J/kg
		setValue('heat_of_fusion_boil', 6362000);//  J/kg
		setValue('thermal_conductivity',50);//  W/m/K
		setValue('thermal_diffusivity', 0.0000138);// m^2/s  ok Source: wikipedia
	}else if(s == "molybdenium")
	}else if(s == "stainlesssteel")
		setValue('preheat', 1430);//  K    stainless steel 304   complete data
		setValue('density_solid', 8030);//  kg/m^3
		setValue('melting_point',1450);//  K
		setValue('shc_solid',500);//  J/kg/K
		setValue('shc_liquid',500);//  J/kg/K check
		setValue('heat_of_fusion_melt',300000);//  J/kg
		setValue('heat_of_fusion_boil', 6500000);//  J/kg
		setValue('thermal_conductivity', 21.4);//  W/m/K
		setValue('thermal_diffusivity', 0.000005);// m^2/s ok tainless 304
	}else if(s == "tungsten")
		setValue('preheat', 3390);//  K                             complete data
		setValue('melting_point',3410);//  K
		setValue('boiling_point', 5930);//  K
		setValue('shc_solid', 140);//  J/kg/K
		setValue('shc_liquid', 140);//  J/kg/K  check
		setValue('heat_of_fusion_melt',185000);//  J/kg
		setValue('heat_of_fusion_boil', 4020000);//  J/kg
		setValue('thermal_conductivity',164);//  W/m/K    K
		setValue('thermal_diffusivity', 0.0000607);// m^2/s
	}else if(s == "prg_test_1kg_1k_titanium")
	    setValue('object_side_length_x', 6.12);// this defines 6.12 cude which weighs 1Kg
	    setValue('object_side_length_y', 6.12);//
	    setValue('object_side_length_z', 6.12);//
	    setValue('depth', 0.0612);//  this is the whole 1Kg cube in one go
		setValue('preheat', 1667);//    This is for testing this program is reasnable acurate. ADD X Y Z DEPTH
		setValue('current_beam', 1);//   So ignore frequency calculation results as treating 1kg titanium block as one cube
		setValue('voltage_gun', 731.77);//this is set to specific heat capacity unity settings ie 622Watt at 1Kg Titanium at 1K
		setValue('timestep', 0.5);// s
		setValue('steps', 40);//
</script>
</head>
<body>
<form id="calcForm">
<h1>Build Speed Calculator <select name="metal_selector" onChange="selectmetal(this.value);" style="font-size: 90%;"> <!-- "this" is just the selectbox alert('titanium'); -->
	<option value="aluminium">Aluminium</option>
	<!--                       <option value="cobalt_chromium">Cobalt Chromium</option>  ENTER FIGURES ABOVE    then remove comment arrows -->
    <!--                       <option value="copper">Copper</option>                    ENTER FIGURES ABOVE    then remove comment arrows -->
    <!--	                   <option value="gold">Gold</option>                        ENTER FIGURES ABOVE    then remove comment arrows -->
	<option value="iron">Iron</option>
    <!--	                   <option value="molybdenium">Molybdenium</option>          ENTER FIGURES ABOVE    then remove comment arrows -->
	<option value="stainlesssteel">StainlessSteel</option>
	<option value="titanium" selected="selected">Titanium</option>
	<option value="tungsten">Tungsten</option>
	<option value="prg_test_1kg_1k_titanium">Prg Test 1Kg 1K Titan.</option>
</select> How much money should you spend on; Power Supply?  Deflection coil drive circuits?  Digital to Analogue converter? </h1>
Final printed object size: x <input type="text" size="6" name="object_side_length_x" value="30" style="border: solid 1px #FF9900; font-size:110%;"/> y <input type="text" size="6" name="object_side_length_y" value="30" style="border: solid 1px #FF9900; font-size:110%;"/> z <input type="text" size="6" name="object_side_length_z" value="2" style="border: solid 1px #FF9900; font-size:110%;" /> cm
Layer <span style="color:black;font-size:140%">depth</span> defining final print resolution: <input type="text" size="6" name="depth" value="0.000023" style="border: solid 1px #FF9900; font-size:110%;"/> m
Fill: <input type="text" size="2" name="fill" value="20" />% <br/><br/>
Initial Room Temprature in Kelvin: <input type="text" size="4" name="InitialRoomTempinK" value="291"  /> K
Metal preheat temperature ( normally 20C below melt tempreature ): <input type="text" size="4" name="preheat" value="1648" style="border: solid 1px #FF9900; font-size:110%;"/> K <br/>
Wall plug efficiency: <input type="text" size="3" name="wallplugefficiency" value="85" /> %
Beam to metal absorbtion efficiency: <input type="text" size="3" name="BeamToMetalAbsorbtionEfficiency" value="85" /> % <br/><br/>
Wall socket <span style="color:black;font-size:140%">power:</span>: <input type="text" size="2" id="RequiredWallSocketPower" value="" /> W
Gun voltage: <input type="text" size="4" name="voltage_gun" value="100000"style="border: solid 1px #FF9900; font-size:110%;" /> V
Beam current: <input type="text" size="2" name="current_beam" value="0.010" style="border: solid 1px #FF9900; font-size:110%;"/> A
Beam power entering metal: <input type="text" size="4" id="powercell" value="" /> W
      <br/><br/>
Maximum hardware speed to drive Scan Rate for <span style="color:black;font-size:140%">deflection coils :</span> <input type="text" size="6" name="max_hardware_limited_raster_scanrate" value="160000" style="border: solid 1px #FF9900; font-size:110%;"/> Hz ( typical 24000)   &nbsp  <br/>
Maximum beam speed used when skipping nonpart areas: <input type="text" size="6" name="max_beam_speed" value="8000" style="border:  font-size:110%;" /> m/s   &nbsp <br/>
<span style="color:grey;font-size:50%">Constants; Solid density: </span><input type="text" size="6" name="density_solid" value="4350" style="font-size:50%;color:grey"/> <span style="color:grey;font-size:50%">kg/m<sup>3</sup></span>    <!--change 'text' to hidden to hide text on simple version -->
<span style="color:grey;font-size:50%">Melting point: </span><input type="text" size="6" name="melting_point" value="1668" style="font-size:50%;color:grey"/><span style="color:grey;font-size:50%"> K </span>   <!--  -->
<span style="color:grey;font-size:50%">Boiling point: </span><input type="text" size="6" name="boiling_point" value="3260" style="font-size:50%;color:grey"/><span style="color:grey;font-size:50%"> K</span>    <!--  -->
<span style="color:grey;font-size:50%">Solid specific heat capacity:</span> <input type="text" size="6" name="shc_solid" value="622" style="font-size:50%;color:grey"/> <span style="color:grey;font-size:50%">J/kg/K </span><br/><!--  -->
<span style="color:grey;font-size:50%">Liquid specific heat capacity:</span> <input type="text" size="6" name="shc_liquid" value="622" style="font-size:50%;color:grey"/><span style="color:grey;font-size:50%"> J/kg/K</span>    <!--  -->
<span style="color:grey;font-size:50%">Latent heat of fusion/melting:</span> <input type="text" size="6" name="heat_of_fusion_melt" value="440000" style="font-size:50%;color:grey"/> <span style="color:grey;font-size:50%">J/kg </span>   <!-- style="font-size:50%;color:grey" -->
<span style="color:grey;font-size:50%">Latent heat of Fusion/boiling: </span><input type="text" size="6" name="heat_of_fusion_boil" value="9830000" style="font-size:50%;color:grey"/> <span style="color:grey;font-size:50%">J/kg </span><br/><!-- style="font-size:50%;color:grey" -->
<span style="color:grey;font-size:50%">Thermal Conductivity : </span><input type="text" size="6" name="thermal_conductivity" value="226" style="font-size:50%;color:grey"/><span style="color:grey;font-size:50%"> W/m/K </span>   <!-- style="font-size:50%;color:grey" -->
<span style="color:grey;font-size:50%">Thermal Diffusivity: </span><input type="text" size="6" name="thermal_diffusivity" value="0.000095" style="font-size:50%;color:grey"/><span style="color:grey;font-size:50%"> m<sup>2</sup>/s </span>   <!-- <span style="color:grey;font-size:50%"> to get rid of text -->
<span style="color:grey;font-size:50%">Table output Format definition, Time step:</span> <input type="text" size="6" name="timestep" value="0.00000005" style="font-size:50%;color:grey" ;/> <span style="color:grey;font-size:50%">s</span>  <!--  -->
<span style="color:grey;font-size:50%">number of Steps:</span> <input type="text" size="6" name="steps" value="40" style="font-size:50%;color:grey"/> <br/>
<input type="submit" value="Calculate build duration" onClick="document.getElementById('output').innerHTML = makeOutput(); document.getElementById('powercell').value = beamPower(); return(false)" /><!-- document is way to refer whole page java comand getelementbyid .value refers to its value which is set to beampower, return false stops normal referesh of whole page-->
<input type="submit" value="Calculate required wall socket power" onClick="document.getElementById('outputWallP').innerHTML = makeOutput(); document.getElementById('RequiredWallSocketPower').value = WallSocketPower(); return(false)" />
</form>
<p id="output">
</p>
<p id="outputWallP">
</p>
</body>
</html>
You can use this build speed calculator to design your MetalicaRap Its good for deciding your; Power supply size, Beam power,Deflection speed,Build platform size,Layer thickness,Digital to Analogue converter speed for beam power modulation While considering factors like; How these decisions vary between different manufacturing metals used? How wall plug efficiency effects mains supply requirements? How beam to metal efficiency effects process?
(More detailed help; highlighting the text between and including <html> and </html> below then copy (ctrlC) to clip board. ( if your viewing this page in edit mode do not copy the pre and /pre statements at very beginning and end of code), Paste (ctrlV) this in to a blank document in notepad + + and then save this new file as "name.html" . Open this name.html file by double clicking it or by opening it with your browser/firefox/explorer from the file open menu in the browser, Enjoy! ( you can download Notepad++ here [92])
Old information
Completed designs/research tasks
The electron gun (1.KW, 100KV)
Which metals for cathode/anode/wehnelt electrodes? '(tungsten / tungsten /molybdenum,)
Which metal for "soft iron core" surrounding coil windings, unalloyed soft iron for yoke e.g. "Hyperm O", cobalt iron alloys for pole pieces if needed e.g. Permendur Vacoflux
Which thermal conducting material for anode support structure? copper See page 5 [9]
Thermionic emission regime,Tungsten ribbon hot filament tungsten at 2500C 0.3 A/cm2(melts at 3410C)?or Thoriated Tungsten 1.16 A/cm2 or Tantalum 2.3 A/cm2(melts at 2996C)
Nickel(1453 C melt), stainless steel(1400 C melt) and molybdenum (2617 C melt) are best materials for electron guns as (others like brass contain zinc which out-gasses intensely when it gets hot, which can lead to ionization and flash overs.) Ceramic or glass are good for insulating elements and can cope along with tungsten(3410 C melt) at over 2600 C creates a high enough current by thermionic emission.
  • Which insulating washers between cathode and 1st anode (6KV) ? Which ceramic? in a 10<math>^-</math><math>^4</math> Torr vacuum Colored red in this diagram of electron gun [93] owned by username ;...........likely finish date :.........emotional status.......... ceramic insulators, you can use either mullite or alumina. Do not use stuff like teflon (is a sponge for water, and outgasses too much) or macor (machinable glass - too delicate). Your shoulder washers in electron gun support are standard commercial items.
  • Which insulator and structural material for insulating beam between cathode and anode (120KV min), which ceramic? Colored red in this diagram of electron gun [94] owned by username ;...........likely finish date :.........emotional status..........ceramic insulators, you can use either mullite or alumina. Do not use stuff like teflon (is a sponge for water, and outgasses too much) or macor (machinable glass - too delicate). Your shoulder washers in electron gun support are standard commercial items.
Rejected designs/research tasks
  • If we went down the cheap window development path then it would have to be a 5-50µ Ti foil window, which is a factor of a thousand times too poor at conducting heat away, so multi guns from different angles would not work, moving beam and spinning build platform might work ( quantify rotation needed ) but alignment and weight 230kg of powder is impracticable?
  • Thermionic and field emission regime with field emission cathode disadvantage requires 10 − 7 Torr vacuum, At this vacuum mechanical feed through s need to be magnetic as o rings no long work at this vacuum, the over 35Nm torque required for the build platform is pushing the design probably too hard so this is an obstacle for moving to the thousand times longer lasting expensive filaments like IrCe. At this vacuum baked-out Vacuum systems are required, the Vacuum system is heated up to 200 C for 24 Hr under vacuum but give the advantage of electrical break down no longer regarded as a threat.
  • Schottky emitters, requires 10 − 7 Torr vacuum / Zr coated tungsten tip ?, e.g. IrCe or LaB6 80 A/cm2// Difficult to stop it reacting with its own support material.
What insulator for surrounding the central stalk that makes the internal electrical connection to the hot IrCe metal ring which goes up through the cathode stem? Do later on UHV version. NiCr Alloy (10-16)
Old on going tasks
  • Familiarize yourself with Software, choose either Universal Accelerator Library (UAL) or Code_Aster familiarize with API environment, With Universal Accelerator Library (UAL) develop methods to create "lens coil" focus control dependent on X,Y beam position and "X Y deflection coil" raster control (CRT style raster). Or with code_aster develop thermal model to track temperature in build volume SOFTWARE DEVELOPMENT
  • Researching the sourcing/ price of components suppliers for our mechanical vacuum and high voltage challenges?' What limited out-gassing cheap 4A cable e.g. tefelon coated , limited out-gassing cheap Signal cable , and 15KV cable exterior 1KW cable is available ? In chamber these need to be limited outgasing required [95][96]units Torr Liters Per Square Cm. Per Second' INTERNET RESEARCH
  • Use your network to help us find more technical specialists, the technical specialists we currently have are very busy people already and needed in electron gun & material science design area." NETWORKING
  • Follow the links on our website and try out our design questions ! PHYSICS & ELECTRONICS RESEARCH
  • Help us research the scanning electron microscope signal processing and image processing." See Topographic SEM solution for metalicarap [97] MATHS RESEARCH
  • "Help us get technical drawings for existing electron beam welding gun designs from contacts or patent listings, great for new ideas" ENGINEERING NETWORKINGGeneral vacuum material science book here [98] or [99]
Old general infomation
SEM ( part assumed to occupy 1/9 of whole print area; 1/9* 300*300=10 000<math>mm^2</math> measurement at every 10µ, SEM picture 500x500 pixel so 5mmx5mm, So for 10,000<math>mm^2</math> need 400 SEM pictures 10,000/25= 400 4x pictures from 4 picups gives effect of different angles? for 3D picture reconstruction so real distances, 400 5mmx5mm pictures, 250ms a picture = 100sec. plus time of mechanical movement of electron gun between .024m square patches at .03m per second is 12y strips each 0.3m strip takes 10 seconds to travel, so in all takes 120 seconds to cover build area( Risk of underestimate factor x100 ) 100+120=220 or 3.66 min Remove metal by Vaporization 1ms per 70µ diameter spot area 4000x10-6<math>mm^2</math> ( 850µs duration & 150µs beam movement) 1/10 of part high(Risk of underestimate factor x2) ( 1/10*10 000mm2/ 4000x10-6 <math>mm^2</math>= 1x105 spots 1x105 spots*1ms= 100Sec 1.66min
Part B
Material; Aluminum Size; 300x300x20mm Weight; 1.5Kg Aluminum 15Euro 10µ powder, melt print 100µ Z layer thickness
Time 20* Z correction layers 5.33 Min each + 180 printed layer 1min each = 287 Min 4.8 hours
Cost 27 Euro materials 22 Euro Electricity 5 Euro
Further manufacturing walk through
Powder
injection molding powder
Aluminum powder 15 Euro/Kg 10µ
Carbon chromium 40Euro a kg. 74µ
Stainless powder 40Euro/kg 10µ
Some say the "lots of small rigid parts joined together" approach -- illustrated on the right -- has "too many joins" for a vacuum chamber. Would a relatively soft material in the gaps between parts -- like the Pb lead between parts of a stained-glass window -- compress enough to make it air-tight? Normally use copper wire to make up "CF flange".[100]
As the main consideration is avoiding non MetalicaRap conventional machining, can you make the copper wire pinch/seal of a CF flange out of the edge of a purchased plain rectangular plate? Is there a better approach? Print the coper flange then uncoil?
NB. It can also weld finished parts together placed in the chamber, the chamber is twice as wide XY as build area approximately, as it needs space for removable metal powder hoppers!, can you use this extra space?,
Chamber 1.3m high, 1m wide, 0.6m depth powder build chamber is 0.3m High 0.3m Bredth 0.3m wide
Door size is up to you, could be a full side eg 1.3m by 1m.
Outstanding questions,
Which insulator for cylinder holding 100KV terminal in electrical feed-through in to chamber ? PTFE? See page 5 [7] Which insulator to secure tungsten wire? Which ceramic?
Which wire for coil windings ? (4A) telflon coated copper? Maybe? Which thermal conducting material for anode support structure? copper 20100 alternatives? See page 5 [9] What insulator for surrounding the central stalk that makes the internal electrical connection to the hot IrCe metal ring which goes up through the cathode stem?
  • Self study the material science to help us with its development free at this site[101]'' STUDY
Rejected design approaches
  • Cartesian Electron Gun A 600W (60KV 10mA) close to build platform on Cartesian X,Y support. Providing subtractive micro vaporizing and vision system
So we are no longer restricting the design to known 2 gun technological solution, (i.e. 2 guns. One close to the target and one far from the target, 1m away (having functions SEM / Micro vaporizing and melting across build area respectively)) Carbon nanotube coated needles have been used and may be worth investigating
.General material issues;
The materials usually have limited lifespan due to sublimation at higher temperatures.
Design Tools
Electron Gun Collector(/cathode) Simulation Software (not for the faint hearted!)
Some people suggest the most acurate way for Electron gun design is it to be done manually with formula through consideration of 3 effects on electrons; Electromagnetic fields, laws of motion, Space charge (electrons pushing on each other). Here are two formula explanations and manuel calculations of pierce guns,; first a large non filament gun example See here [102], Second an example of Pierce weld gun See fig.3 [103] ), See final equations to give velocity of electron in equation(1.9) and beam current as (equation 2.10)See equations here [104] .
Others argue simulation software is accurate enough and necessary it was used 1980's onwards to refine design of the electron gun, See example design process of a gun cathode See page 19 here [105].
Cathode voltage choice controls minimum penetration depth of electrons energy in to the metal powder/target, beam current choice influences power transfer rate from electron beam to metal, once cathode voltage and max beam current are decided, Electron Gun Collector/cathode Simulation programs are used to design the appropriately cathode anode surface shapes to achieve the said max beam current at the applied cathode voltage, while maintaining at the gun crossover point the required beam power (Watts) at the optimum gun crossover diameter (cm) (gun crossover is situated in the middle of the anode see main electron gun diagram above), the gun crossover diameter is the primary factor controlling the final beam spot size on build platform/target ( other negative effects come from coil imperfections and aperture electron wave interference patterns) .
  • For comparison try to get hold of open source charge particle/electron trajectory analysis programs, some times called electron gun computer simulation programs, like SAM or ULTRASAM (USAM) (By m Tiunov BINP russia )or maybe TREDI with modification?Get here[106], ( # -indicates confirmed as currently for commercial sale with no useful free trial version, #EGUN [107] / #EGN2w, windows version/ #EGN2w is currently seen as obsolete but will work fine for us, byBill Herrmannsfeldt, Reinard Becker University of Frankfurt/M, [108]) or #TRAK or #MAGIC). GENERAL RESEARCH
But for now we will try with a general magnetostatic program like Poisson for tracking through coils and calculating resultant forces on coils ( later we track beam live with UAL see above ) and unfortunately we have no solution for cathode anode design as we require space charge calculations and temperature and field regime "Schottky emission" which this CPO student limited version blocks, but you can get to know the principles behind it by play with CPO, ( CPO Boundary element method simulation program student version for standard pierce gun cathode shape/ solutions, Download CPO here [109] install and run in XP compatibility mode! (right click properties / compatibility tab) , Pictures [110] Installation help[111]).
Poisson/Superfish are a suite programs for Unix or Windows, containing the key subprograms called; automesh and poisson and pandira the suite is available from Los Alamos Accelerator Code Group (LAACG) First Register your name on the download page and then the download site offers instant Download, Download page here [112], Due to the complexity of the input file format of automesh (AUTOMESH.IN) two "helper" programs Geometric modeler download Poisson/superfish here[113] and ViewGraph download here [114] are essential for input and output respectively. So using Geometric modeler to create the input file to Automesh which combines the settings list and mesh shape to produce the problem file which is then analyzed by running subprogram POISSON. Which output file is plotted by ViewGraph or Geometric modeler.
So in general terms Run Geometric modeller to aid the production of the required input files for automesh, upon running automesh the problem set up is achieved. Once automesh has finished running and creating the problem file ( XXXXXXXXX.T35 ) then the solver program Poisson acts on this file to do the simulation of the design, The Gun simulation is an magnetostatic problem so is solved through Poisson equations ie uses subprogram called "Poisson"( We do not use RF cavities in the electron gun so ignore programs for tuning them, with FISH in the program name) . See summary of POISSON suite input and output files here input & output files using POISSON suite. You can confirm you output with approximate hand calculations at centers of coils See formula here , Deflection of beam by coil here [115] , coil Magnetic field B calculations [116], Background Coil design[117].
Old self replication method
Possible self-replicated vacuum chamber: Anders used Blender to draw this rough sketch of a vacuum chamber made from hexagonal parts printed in a MetalicaRap.
Hexagonal x40 halfhexagonal x16 endpieces x16, 384 bolts (what does this mean?), copper wire, main door can use a Viton O ring perhaps, or a metal to metal seal with vacuum oil or vacuum wax as a sealant. old solar cell material deposition rate of a few micrometers per minute / electron beam heating evaporation deposition EBPVD [118] / possibly a micro pulsed electron deposition process,
Calculations for 1m cubed box design - too expensive Step 1 - Required thickness approximation
I've calculated plate thickness, constrained by maximum deflections of 0.01 & 0.03 inches = 0.254 & 0.762 mm and pressure differential of 1 atm sea level for the largest dimension plates, ie electron gun tube length 0.80 diameter .032 on top ; H 0.8 x W0.8 x Depth 0.4 (assuming smaller plates will have less deflection)
Online calculator for fixed rectangular plate (Bypass calculation limit by clearing your cookies)[119]
old links before TWI blocked pages 1. http://www.twi.co.uk/content/spasaug2006.html
1A.http://www.twi.co.uk/content/eb_variants.html#ref3
Simple just plate chamber with electron gun tube length .080 diameter 0.32 on top ; H 0.8 x W0.8 x Depth 0.4 area 2.56
Material
Stainless Steel 304 (check this)
Youngs modulus E GPa Stainless Steel 207
Poissions ratio v 1 0.3
Uniform loading p Pa 101325
Individual plate sides of chamber given 0.253097 mm max plate deflection
Width Lx mm 800
Length Ly mm 800
thickness needed TBA
Width Lx mm 400
Length Ly mm 800
Width Lx mm 400
Length Ly mm 800
Individual plate sides of chamber given 0.761671615 mm max plate deflection
Width Lx mm 800
Length Ly mm 800
thickness needed 15.8 ( 15.8mm ( 5/8inch)( deflection 0.683mm) 2098 euro per m sq.)2.56 x 2098 do again BAD PRICE? = 5370 euro(( do we need to go up to 316 stainless?)
Width Lx mm 400
Length Ly mm 800
Width Lx mm 400
Length Ly mm 800
Material
Aluminium
Youngs modulus E GPa 62.053
Width Lx mm 800
Length Ly mm 800
thickness needed
Width Lx mm 400
Length Ly mm 800
Width Lx mm 400
Length Ly mm 800
Width Lx mm 800
Length Ly mm 800
thickness needed 25 Aluminum plate (deflection .583mm) 2.56 m sq. 2000 euro[120]
Width Lx mm 400
Length Ly mm 800
Width Lx mm 400
Length Ly mm 800
another possible chamber with no electron gun tube.
Simple just plate chamber no electron gun tube ; H 1.6 x W0.8 x Depth 0.4
Material
Width Lx mm 800
Length Ly mm 1600
thickness needed 40.6 do again
Width Lx mm 400
Length Ly mm 1600
Width Lx mm 400
Length Ly mm 800
Width Lx mm 800
Length Ly mm 1600
thickness needed 28.2 do again ( 1inch 25.4mm 1200 euro per m sq.) so 6.4m x 1200 = 7680 euro(( do we need to go up to 316 stainless?)
Width Lx mm 400
Length Ly mm 1600
Width Lx mm 400
Length Ly mm 800
Material
Aluminium
Width Lx mm 800
Length Ly mm 1600
thickness needed 59.3
Width Lx mm 400
Length Ly mm 1600
Width Lx mm 400
Length Ly mm 1080
Width Lx mm 800
Length Ly mm 1600
thickness needed 41.1 40mm Aluminium plate 6.4 m sq 4708 euro[121]
Width Lx mm 400
Length Ly mm 1600
Width Lx mm 400
Length Ly mm 800
thickness needed TBA next steps - Material prices ?? - using next larger standard dimensions ?? - factoring in compressive stresses from edge loading (buckling)
