MetalicaRap Future Developments
Next
Live build part heuristic simulation Rather than just remove blob errors on every 10th layer, develop a live model of the build progress of the part and update shape with 3D map of error blobs from scanning electron microscope, then modify following layer G code to take in to account existing blobs during the next layer metal addition , and thereby only intervene subtractively when blobs effects outside of the part.
Possible
Solar cell production demands conductive transparent top surface layers Indium tin oxides traditionally uses electron beam physical vapor deposition EBPVD [1]. Gun details required.
Polishing Plasma through the addition of argon and a defocused beam, polishing out roughness from a typical powder printed finish Rq of 25 nm to a polished surface Rq of 4 nm is possible , there are other low tech polishing methods that may be easier eg. Tumble finishing. EBeam Polishing [2]
Ion Pump to remove waste vaporized metal.
Focused ion beam / Ion beam etching gun to take dimensions to sub µ level(1µ over 20mmIT0)(Future development issues, SEM measuring absolute distances over a 300mm depth of field in FIB mode .)
