Microcontroller Firmware Hints
Revision as of 04:33, 3 October 2008 by 212.84.101.86 (talk)
Compiling and downloading Arduino Firmware using Windows
Fresh Install Arduino version 011 software.
Copy sub directories in reprap-arduino-firmware-1.3/library directory to Arduino hardware/libraries directory.
You should end up with 14 sub directories below /libraries.
Open Single_Arduino_SNAP.pde in arduino.
Compile.
You will see an error regarding obsolete header file.
BUT it will compile without error.
If you change a file in libraries which you invariably have to do to match your thermister/thermocouple delete the object file ?????.o
Otherwise it will not recompile using the changes
