Microcontroller Firmware Hints
Revision as of 12:26, 6 October 2008 by 212.84.101.86 (talk)
Compiling and downloading Arduino Firmware using Windows
  • Fresh Install Arduino version 011 software.
  • Copy sub directories in reprap-arduino-firmware-1.3/library (or any later version downloaded from sourceforge https://reprap.svn.sourceforge.net/svnroot/reprap) directory to Arduino hardware/libraries directory.
  • You should end up with 14 sub directories below /libraries.
  • Open Single_Arduino_SNAP.pde in arduino.
  • Compile.
  • You will see an error regarding obsolete header file.
  • BUT it will compile without error.
  • If you change a file in libraries which you invariably have to do to match your thermister/thermocouple delete the object file ?????.o
  • Otherwise it will not recompile using the changes
