Mini3dprintercontroller
Revision as of 04:56, 11 January 2015 by Glenn (talk | contribs) (wiki)
mini3dprintercontroller Electronics Board
Release status: experimental
the mini3dprintercontroller Electronics
Creative Commons BY-NC-SA 3.0
GitHub
(none)
The mini3dprintercontroller Board is part of Mini3dprintercontroller Electronics. This is the central part of mini3dprinter Electronics. A board with all the features required to run a printer in a very small board 50 X 50 mm and also including a header to plug in driver boards for stepper motors control and lcd and micro sd cardreader too. This version have 2 heater for a struder and bed, also power for fan, 3 limits and 2 for temperature sensors like termistors and serial port for the USB-TTL adapter.
The mini3dprintercontroller electronics is a low-cost electronics solution for reprap and other CNC devices.Using ATMEGA 644p though a ATMEGA1284 like Sanguinololu or Gen 7 is easily dropped in. Its 3 axes and extruder motors are powered for external drives like polulus compatible or many others like mini3dprinterdrives.
The board is designed to be flexible in the user's power sourse availity, allowing for an ATX power supply to power the board for 12v.
