MiniRambo development
RAMBo Pages: RAMBo .:. RAMBo v1.0-1.1 .:. RAMBo v1.2 .:. RAMBo Firmware .:. RAMBo Development .:. MiniRambo .:. MiniRambo Development
This page contains information relevant to the development of the Mini-Rambo PCB. You can find general info at MiniRambo.
Pins
The extension headers are in the format "Extension Name" "Pin Number" "Function". Example: MX1-5 Direction = "Motor Extension 1" "Pin 5".
Pin Number | Pin Number | Arduino Pin Name | Function |
1 | PG5 ( OC0B ) | Digital pin 4 (PWM) | Bed Heater |
2 | PE0 ( RXD0/PCINT8 ) | Digital pin 0 (PWM) (RX0) | USB – serial comms |
3 | PE1 ( TXD0 ) | Digital pin 1 (PWM) (TX0) | USB – serial comms |
4 | PE2 ( XCK0/AIN0 ) | RamboDigital pin 78 | |
5 | PE3 ( OC3A/AIN1 ) | Digital pin 5 (PWM) | P2 1 |
6 | PE4 ( OC3B/INT4 ) | Digital pin 2 (PWM) | nAC_FAULT, J19 3 |
7 | PE5 ( OC3C/INT5 ) | Digital pin 3 (PWM) | Heat 0 |
8 | PE6 ( T3/INT6 ) | RamboDigital pin 79 | |
9 | PE7 ( CLKO/ICP3/INT7 ) | RamboDigital pin 80 | |
10 | VCC | VCC | VCC |
11 | GND | GND | GND |
12 | PH0 ( RXD2 ) | Digital pin 17 (RX2) | P3 5 |
13 | PH1 ( TXD2 ) | Digital pin 16 (TX2) | P3 3 |
14 | PH2 ( XCK2 ) | RamboDigital pin 84 | P1 10 (LCD Beeper) |
15 | PH3 ( OC4A ) | Digital pin 6 (PWM) | Fan 2 |
16 | PH4 ( OC4B ) | Digital pin 7 (PWM) | |
17 | PH5 ( OC4C ) | Digital pin 8 (PWM) | Fan 1 |
18 | PH6 ( OC2B ) | Digital pin 9 (PWM) | P1 9 (LCD BTN Click) |
19 | PB0 ( SS/PCINT0 ) | Digital pin 53 (PWM)(SPI-SS) | J19 5 |
20 | PB1 ( SCK/PCINT1 ) | Digital pin 52 (PWM)(SCK) | P2 9, J19 11 |
21 | PB2 ( MOSI/PCINT2 ) | Digital pin 51 (PWM)(MOSI) | P2 5, J19 12 |
22 | PB3 ( MISO/PCINT3 ) | Digital pin 50(MISO) | P2 10, J19 9 |
23 | PB4 ( OC2A/PCINT4 ) | Digital pin 10 (PWM) | Z Min Endstop |
24 | PB5 ( OC1A/PCINT5 ) | Digital pin 11 (PWM) | Y Min Endstop |
25 | PB6 ( OC1B/PCINT6 ) | Digital pin 12 (PWM) | X Min Endstop |
26 | PB7 ( OC0A/OC1C/PCINT7 ) | Digital pin 13 (PWM) | LED |
27 | PH7 ( T4 ) | RamboDigital pin 85 | P1 4 (LCD D6) |
28 | PG3 ( TOSC2 ) | RamboDigital pin 71 | P1 3 (LCD D7) |
29 | PG4 ( TOSC1 ) | RamboDigital pin 70 | P1 5 (LCD D5) |
30 | RESET | RESET | Reset |
31 | VCC | VCC | VCC |
32 | GND | GND | GND |
33 | XTAL2 | XTAL2 | XTAL2 |
34 | XTAL1 | XTAL1 | XTAL1 |
35 | PL0 ( ICP4 ) | Digital pin 49 | X Direction |
36 | PL1 ( ICP5 ) | Digital pin 48 | Y Direction |
37 | PL2 ( T5 ) | Digital pin 47 | Z Direction |
38 | PL3 ( OC5A ) | Digital pin 46 (PWM) | |
39 | PL4 ( OC5B ) | Digital pin 45 (PWM) | |
40 | PL5 ( OC5C ) | Digital pin 44 (PWM) | |
41 | PL6 | Digital pin 43 | E Direction |
42 | PL7 | Digital pin 42 | |
43 | PD0 ( SCL/INT0 ) | Digital pin 21 (SCL) | P3 6 |
44 | PD1 ( SDA/INT1 ) | Digital pin 20 (SDA) | P3 8 |
45 | PD2 ( RXDI/INT2 ) | Digital pin 19 (RX1) | J19 6 |
46 | PD3 ( TXD1/INT3 ) | Digital pin 18 (TX1) | J19 8 |
47 | PD4 ( ICP1 ) | RamboDigital pin 81 | |
48 | PD5 ( XCK1 ) | RamboDigital pin 82 | P1 7 (LCD RS) |
49 | PD6 ( T1 ) | RamboDigital pin 83 | |
50 | PD7 ( T0 ) | Digital pin 38 | |
51 | PG0 ( WR ) | Digital pin 41 | X Chipselect |
52 | PG1 ( RD ) | Digital pin 40 | |
53 | PC0 ( A8 ) | Digital pin 37 | X Step |
54 | PC1 ( A9 ) | Digital pin 36 | Y Step |
55 | PC2 ( A10 ) | Digital pin 35 | Z Step |
56 | PC3 ( A11 ) | Digital pin 34 | E0 Step |
57 | PC4 ( A12 ) | Digital pin 33 | |
58 | PC5 ( A13 ) | Digital pin 32 | SPI Flash Chipselect |
59 | PC6 ( A14 ) | Digital pin 31 | |
60 | PC7 ( A15 ) | Digital pin 30 | |
61 | VCC | VCC | VCC |
62 | GND | GND | GND |
63 | PJ0 ( RXD3/PCINT9 ) | Digital pin 15 (RX3) | P2 4 (LCD SD Detect) |
64 | PJ1 ( TXD3/PCINT10 ) | Digital pin 14 (TX3) | P2 6 (LCD BTN_EN1) |
65 | PJ2 ( XCK3/PCINT11 ) | RamboDigital pin 72 | P2 8 (LCD BTN_EN2) |
66 | PJ3 ( PCINT12 ) | RamboDigital pin 73 | J19 7 |
67 | PJ4 ( PCINT13 ) | RamboDigital pin 75 | |
68 | PJ5 ( PCINT14 ) | RamboDigital pin 76 | P3 9 |
69 | PJ6 ( PCINT 15 ) | RamboDigital pin 77 | P2 7 (SDSS) |
70 | PG2 ( ALE ) | Digital pin 39 | Y Chipselect |
71 | PA7 ( AD7 ) | Digital pin 29 | X Enable |
72 | PA6 ( AD6 ) | Digital pin 28 | Y Enable |
73 | PA5 ( AD5 ) | Digital pin 27 | Z Enable |
74 | PA4 ( AD4 ) | Digital pin 26 | E0 Enable |
75 | PA3 ( AD3 ) | Digital pin 25 | |
76 | PA2 ( AD2 ) | Digital pin 24 | Z Probe Thermistor |
77 | PA1 ( AD1 ) | Digital pin 23 | |
78 | PA0 ( AD0 ) | Digital pin 22 | |
79 | PJ7 | RamboDigital pin 74 | |
80 | VCC | VCC | VCC |
81 | GND | GND | GND |
82 | PK7 ( ADC15/PCINT23 ) | Analog pin 15 (69) | Y Diag |
83 | PK6 ( ADC14/PCINT22 ) | Analog pin 14 (68) | Z Diag |
84 | PK5 ( ADC13/PCINT21 ) | Analog pin 13 (67) | Z Chipselect |
85 | PK4 ( ADC12/PCINT20 ) | Analog pin 12 (66) | E Chipselect |
86 | PK3 ( ADC11/PCINT19 ) | Analog pin 11 (65) | E Diag |
87 | PK2 ( ADC10/PCINT18 ) | Analog pin 10 (64) | X Diag |
88 | PK1 ( ADC9/PCINT17 ) | Analog pin 9 (63) | |
89 | PK0 ( ADC8/PCINT16 ) | Analog pin 8 (62) | P3 10 |
90 | PF7 ( ADC7/PCINT15 ) | Analog pin 7 (61) | P1 8 (LCD Enable) |
91 | PF6 ( ADC6/PCINT14 ) | Analog pin 6 (60) | |
92 | PF5 ( ADC5/TMS ) | Analog pin 5 (59) | P1 6 (LCD D4) |
93 | PF4 ( ADC4/TMK ) | Analog pin 4 (58) | |
94 | PF3 ( ADC3 ) | Analog pin 3 (57) | |
95 | PF2 ( ADC2 ) | Analog pin 2 (56) | Thermistor 2 |
96 | PF1 ( ADC1 ) | Analog pin 1 (55) | Thermistor 1 |
97 | PF0 ( ADC0 ) | Analog pin 0 (54) | Thermistor 0 |
98 | AREF | Analog Reference | |
99 | GND | GND | GND |
100 | AVCC | VCC | VCC |
Digital Pin Locations
Here is a image that shows the locations of digital pins for the p1 p2 and p3 pin headers.
Source
Development is taking place on Github
Fuses and lockbits
32u2 fuses - BODLEVEL = 3V0; HWBE = [X]; DWEN = [ ]; RSTDISBL = [ ]; SPIEN = [X]; WDTON = [ ]; EESAVE = [ ]; BOOTSZ = 2048W_3800; BOOTRST = [ ]; CKDIV8 = [ ]; CKOUT = [ ]; SUT_CKSEL = EXTXOSC_8MHZ_XX_16KCK_4MS1
EXTENDED = 0xF4; HIGH = 0xD9; LOW = 0xEF
2560 Fuses BODLEVEL = 2V7; OCDEN = [ ]; JTAGEN = [ ]; SPIEN = [X]; WDTON = [ ]; EESAVE = [X]; BOOTSZ = 4096W_1F000; BOOTRST = [X]; CKDIV8 = [ ]; CKOUT = [ ]; SUT_CKSEL = EXTXOSC_8MHZ_XX_16KCK_65MS
EXTENDED = 0xFD; HIGH = 0xD0; LOW = 0xFF;
Lock bits for both only set BLB1 = LPM_SMP_DISABLE (0x0F).
Changelog
- 1.3a
- Moved the serial label next to Power Input plug on the top side of the PCB. Lots of minor adjustments to create extra space.
- Switched to UL listed fuse holders
- 1.2a
- Added two 2x5 pin headers for compatibility with RepRap Discount LCD standard cables
- Removed Miregli expansion IO connectors
- Silk screen fixes
- 1.1b
- Early release version
