Mini prusa
Revision as of 03:13, 27 June 2011 by Auzze (talk | contribs) (Created page with '{{Development <!--Header--> |name = Mini Prusa |status = experimental <!--Image--> |image = N/A <!--General--> |description = Mini Prusa |license = GPL |author = Auzze |reprap = …')
Mini Prusa
Release status: experimental
Mini Prusa
GPL
Prusa Development
Introduction
This is my version of a Mini Prusa, The idea behind it was that after building my Mendel-Prusa I thought that the desgin could be made smaller so it would be more portable. In doing so it the size of the printer is W/H/D 310mm x 310mm x 310mm with a build area of 150mm x 150mm x 90mm. As it is smaller in size with will cost less to build and even use less plastic.
Configuration
  1. Sanguinololu electronics,
  2. Aluminium heated bed,
  3. Nema 14 Stepper Motors
  4. Smaller Wade extruder using Nema 14
  5. M6 Smooth and Threaded rods
I also have re-desgin most parts to make sure that fit the project goal.
More to follow
