Mini prusa
Revision as of 17:44, 15 August 2011 by Myndale (talk | contribs) (Rodding)
Mini Prusa
Release status: experimental
Mini Prusa
GPL
Prusa Development
Introduction
This is my version of a Mini Prusa, The idea behind it was that after building my Mendel-Prusa I thought that the design could be made smaller so it would be more portable. In doing so it the size of the printer is W/H/D 310mm x 310mm x 310mm with a build area of 150mm x 150mm x 90mm. As it is smaller in size with will cost less to build and even use less plastic.
Configuration
  1. RAMPS or Sanguinololu electronics (or any other RepRap electronics),
  2. Aluminium heated bed,
  3. Nema 14 Stepper Motors
  4. Smaller Wade extruder using Nema 14
  5. M6 Smooth and Threaded rods
I also have re-designed most parts to make sure that fit the project goal.
Files
Parts List
Nuts & Bolts
  • 72 - M6 Nuts
  • 4 - M6 Nylon Nuts - X Ends
  • 74 - M6 Washers
  • 8 - M3 x 20mm Bolts - Z Couplers
  • 20 - M3 x 12mm Bolts - Stepper Motors
  • 2 - M3 x 6mm Grub Screws - Pulleys
  • 8 - M3 Nuts
  • 28 - M3 Washers
Rodding
  • 4 - 220mm x M6 Threaded Rod
  • 6 - 265mm x M6 Threaded Rod
  • 3 - 310mm x M6 Threaded Rod
  • 2 - 210mm x M6 Threaded Rod - Leadscrew
  • 6 - 265mm x M6 Smooth Rod
The smooth rod can be cut from two 1-meter lengths, the threaded rod can be cut from four 1-meter lengths:
Length 1: 310mm + 310mm + 310mm         = 930mm
Length 2: 265mm + 265mm + 220mm + 220mm = 970mm
Length 3: 265mm + 265mm + 220mm + 220mm = 970mm
Length 4: 265mm + 265mm + 210mm + 210mm = 950mm
Bearings
  • 6 626 bearings - 3 on the printer, 3 on the extruder
  • 12 LM6UU Linear Bearings
Thin Sheets
  • 160mm x 160mm x 2mm Alum Plate - Will be used as the Printbed/Heated Bed
  • 160mm x 100mm x 2mm Alum Plate - Y Frog
Heated Bed Parts
  • 4 - M3 x 30mm Countersunk Screws
  • 8 - M3 x 10mm Countersunk Screws
  • 24 - M3 Nuts
  • 24 - M3 Washers
  • 4 - 1.2 Ohm 5 Watt Resistors (Alum Clad)
  • Small tube heat transfer paste
Assembly Instructions
After reciving your printed parts they will need to be cleaned and drilled, for this you will need 1 x M6 drill bit aswell as a M3 drill bit. Take your time and drill all the parts. You will also need 2 ??mm spanners.
Frame
X Axis
Y Axis
Z Axis
Electrical
Heated Bed
Endstops
Setup
