Minitronics SmartLCD/fr
Revision as of 09:24, 3 August 2014 by Pascal m (talk | contribs) (Câblage Breadbord)
Minitronics extension board SmartLCD
how to add a SmartLCD on Minitronics
This page represents an example development page and showcases many features that can be used in creating new development pages.
Résumé
Cette page vous aidera à adapter un SmartLCD sur une carte Minitronics, la carte n'ayant pas suffisamment de broches, nous utiliserons un expendeur I2c pour contourner cette limitation. Vous trouverez ici comment adapter un SmartLCD RepRapDiscount , créer une carte interface I2c et adapter le firmware Marlin... ]
Xxxxx
Texte texte
Schema
PCB
Câblage Breadbord
Mise en place des napes
Connexion à la minitronics
La carte interface est reliée fil à fil avec la carte minitronics par 2 napes.
Carte Interface Minitronics
ICSP ICSP
AUX AUX
Modification de la configuration Marlin
configuration.h
Activer l'option :LCD_I2C_SAINSMART_YWROBOT
//I2C PANELS
#define LCD_I2C_SAINSMART_YWROBOT
pin.h
#if MOTHERBOARD == 702
 #define KNOWN_BOARD 1
 #ifndef __AVR_ATmega1281__
 #error Oops! Make sure you have 'Minitronics ' selected from the 'Tools -> Boards' menu.
 #endif
 #define LARGE_FLASH        true
 #define X_STEP_PIN 48
 #define X_DIR_PIN 47
 #define X_ENABLE_PIN 49
 #define X_MIN_PIN 5
 #define X_MAX_PIN -1 //2 //Max endstops default to disabled "-1", set to commented value to enable.
 #define Y_STEP_PIN 39 // A6
 #define Y_DIR_PIN 40 // A0
 #define Y_ENABLE_PIN 38
 #define Y_MIN_PIN 2
 #define Y_MAX_PIN -1 //15
 #define Z_STEP_PIN 42 // A2
 #define Z_DIR_PIN 43 // A6
 #define Z_ENABLE_PIN 41 // A1
 #define Z_MIN_PIN 6
 #define Z_MAX_PIN -1
 #define E0_STEP_PIN 45
 #define E0_DIR_PIN 44
 #define E0_ENABLE_PIN 27
 #define E1_STEP_PIN 36
 #define E1_DIR_PIN 35
 #define E1_ENABLE_PIN 37
 #define E2_STEP_PIN -1
 #define E2_DIR_PIN -1
 #define E2_ENABLE_PIN -1
 #define SDPOWER -1
 #define SDSS 16
 #define LED_PIN 46
 #define FAN_PIN 9
 #define FAN2_PIN -1
 #define PS_ON_PIN -1
 #define KILL_PIN -1
 #define HEATER_0_PIN 7 // EXTRUDER 1
 #define HEATER_1_PIN 8 // EXTRUDER 2
 #define HEATER_2_PIN 9 // thermo couple <--------------------------------------modification---------
 #if TEMP_SENSOR_0 == -1 // <---------------------------------------------------modification---------
 	#define TEMP_0_PIN 5 // ANALOG NUMBERING <------------------------------modification---------
 #else // <---------------------------------------------------------------------modification---------
 	#define TEMP_0_PIN 7 // ANALOG NUMBERING
 #endif // <--------------------------------------------------------------------modification---------
 #define TEMP_1_PIN 6 // ANALOG NUMBERING
 #define TEMP_2_PIN -1 // ANALOG NUMBERING
 #define HEATER_BED_PIN 3 // BED
 #define TEMP_BED_PIN 6 // ANALOG NUMBERING
 #define BEEPER 19 // <---------------------------------------------------------modification---------
 #define LCD_PINS_RS -1
 #define LCD_PINS_ENABLE -1
 #define LCD_PINS_D4 -1
 #define LCD_PINS_D5 -1
 #define LCD_PINS_D6 -1
 #define LCD_PINS_D7 -1
 //buttons are directly attached using keypad
 #define BTN_EN1 26 // <---------------------------------------------------------modification---------
 #define BTN_EN2 30 // <---------------------------------------------------------modification---------
 #define BTN_ENC 25  //the click // <--------------------------------------------modification---------
 #define BLEN_C 2
 #define BLEN_B 1
 #define BLEN_A 0
 #define SDCARDDETECT 15	// Megatronics does not use this port // <--------modification---------
   //encoder rotation values
 #define encrot0 0
 #define encrot1 2
 #define encrot2 3
 #define encrot3 1
#endif
Search for the page
