Mixtape mendel
Release status: experimental
Description | Prusa/Sells Mendel Based
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Background
Mixtape Mendel is designed from the ground up to be as parametric as possible. It is inspired by the work of many people. Current development is being done in the github repository. The current focus is on a complete version 0.2 release. To do so we are working on ironing out the configuration files for a Mendel and Huxley class printer, as well as completing the tool head designs. We want to make it as easy to specify what you are going to use in the configuration file.
Design Goals
- Use 1.75mm filament
- Support double extruders/multi tools.
- Support a Sharpie mount for easy PCB etching.
- Have a better printable volume to printer volume ratio.
- Simple and complete configuration file.
Pictures
Version 0.2x
The version 0.2x model is designed to push the limits of what can be done with parametric modeling. It is made in the Mendel and Prusa Mendel's image.
Version 0.3x
Reboot in August 2011.
Development Road Map
Version 0.1 (Unreleased)
- Was a rough mockup for ideas and geometry (Well documented in the blog).
Version 0.2 Prototype (Complete, Printing)
- All designs completed
- Issues are known. Will be fixed in the Release
Version 0.20 (Unreleased, development rolled into version 0.3)
- Cartesian platform (complete)
- Extruder/ Bowden couplings
- Document/cleanup
- Huxley Class config
- X end bushing mounts turned 90 degrees
- Better x belt routing (Possibly Version 0.2)
Version 0.30
- Linear Bearings
- No Tapping
Mendel Instructions
RP (Rapid Prototype) Parts
bar-clamp (6)
vertex (2 regular, 2 mirrored)
top-piece (2)
Hardware (incomplete)
M8 Nuts - 48
608 Bearings - 2
M3x10mm - 12
M3x12mm - 4
M4 set screws - 4
Smooth Rod
330mm
360mm
400mmx2
270mmx2
Threaded Rod
333mm x 8
360mm X 2
420mm x 2
230mm x 2 Cutting from 1m lengths...
1: 333mm, 333mm, 333mm
2: 333mm, 333mm, 333mm
3: 333mm, 333mm, 230mm
4: 420mm, 420mm
5: 360mm, 360mm, 230mm
MDF
260mmx140mm (Lower bed)
260mmx230mm (Print bed)
